But I would have to agree about the Trim, Your right should actuall be less of a Negative or even in the Positive if you are trying to boost it.
Something kinda stupid but could be making some of a difference. I see you have a plant behind that Right Tower. Keep in mind that anything behind your BiPolar speakers is going to refract sound. Just to grins try moving the potted plant and see if that helps.
The other thing is if you are looking to move the tower over to the right I would say the same you need something behind it to reflect the audio off of a wall. If you have the room you could try a Foldable Partition, that may help some.
Unfortunately you have your Gear in a really bad spot. Sure it looks cool setting on that small divider wall. But for HT, not the best set up for your speakers.[/quote]
Thanks for the input. I had a little concern about just increasing the Right channel level to compensate after the MultiXt calibration for fear of messing something up with the cal, but I will give it a shot. Being inexperienced, I was leaving the Audyssey as is.
I'll start with moving the plant first and then look at a partition. If I get to the point of needing a partition, does it need to be anything special or something found at a Staples or Office Depot?
I agree that the location is far from ideal. My first thought was to have the TV over the fireplace with the center under it- but that was shot down by the wife last year. Also, I was a little concerned about the heat and sports bar position of the TV- looking up.
I can see that if the speaker gets any closer to the center- no panning to the right really happens. It's already noticeable.
What I'm hoping to do is slowly take over the living room, one piece of diamond crusted jewelry at a time!
As a side note- I really appreciate the knowledge you guys have here. Not only that, but the manner of discussion is almost always productive. With your help, I was able to put together a bedroom set of 5 SM450s for a ridiculously good price when one store was just about giving them away. Not only that, but I will probably try to set the living room up as a good 5.1 rather than the crappy 7.1 I have now as the speakers in the back are way too high. Anyway, thanks.
- Jason
- Jason
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
So with that, here ya go.
) Once I've drawn the cutline, I drill holes at all the corners with a portable drill. Then I thread a coping saw blade through and saw my rough cuts just inside the lines. Finally, I clean them up with a Dremel.
When I was ordering a lot of IEC inlets, connectors, and raw cable (for making my own power cables), I figured it'd be simpler to just get them all in the grounded versions (C14 and C13 respectively), as I wanted a bunch on hand without knowing how many of each type I'd end up needing. The grounded version is "universal," since you make it ungrounded by simply not connecting the ground pin inside the component. The ungrounded versions, on the other hand, can only be used for ungrounded connections. This has proven to work really well.....I never have to worry about whether I have the right kind of cable or parts for my mod projects...they all use the same thing.
