Eric,
I'm not sure if your post was a reply to g_bart or both of us but I had a couple questions.
In case you haven't seen what I will(should have the system tomorrow) be setting up below is the list.
Def tech:
8040 towers
8040 center
8040 surrounds
AVR-2112CI
So when using the meter I only adjust the volume level to get 75db on the front left speaker and only the trim level on the rest to get 75db?
You also recommend setting all speakers to small. Would this be the case with my towers as well?
Thx,
Bryan
Def tech:
8040 towers
8040 center
8040 surrounds
AVR-2112CI
Thx,
Bryan
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
