AVS › AVS Forum › Audio › Speakers › Definitive Owners Thread
Definitive Owners Thread - Page 873
post #26161 of 30942
Thanks for the tip josh What about speaker calibration and crossovers?
post #26162 of 30942
What receiver are you using?
post #26163 of 30942
Onkyo 805
post #26164 of 30942
Onkyo 805
Have you looked at the Audyssey thread? Off the top of my head first thing I would do is set the front three back to small with an 80 crossover. Audyssey works fine with my bipolars so it's probably a setup issue.
post #26165 of 30942
audyssey set them up all large..
post #26166 of 30942
Yeah it does that with most badass def techs. Look at the Audyssey thread or even google ask Audyssey...9 times out of 10 they recommend all speakers set to small regardless of what the calibration says. You're using an outboard sub right? If so definitely try the fronts as small.
post #26167 of 30942
Yes I have a Klipsch 12" down firing sub.. My onkyo doesn't have settings for small per se'.. Just hz.. Why set them to small?
post #26168 of 30942
don't set them small...otherwise the subs in your towers are wasted in my opinion....leave them large and let them do there thing...
post #26169 of 30942
I agree with that Josh. It doesn't make sense to neuter the subs.. Unless that doesn't affect them.
post #26170 of 30942
https://audyssey.zendesk.com/entries...udyssey-set-up
Straight from the horses mouth. Check the Audyssey thread out and you'll find lots of knowledgeable, helpful folks over there. I'm also going to guess the onkyo will let you adjust speaker size....apparently you have to choose a certain crossover for the onkyo to consider a speaker large or small. Weird...
post #26171 of 30942
check out the bass management link on the ask audyssey site. I think it will clear some things up for you guys
post #26172 of 30942
So what would be considered small on my onkyo.. There is no small setting,just 40hz and up..
post #26173 of 30942
Got me there. Im a denon owner. Might head to the 805 thread and ask.
post #26174 of 30942
40hz is actually a great setting for the powered DT towers. Everything below 40hz would then be directed to your sub(s). Set at 40hz you're not neutering your towers. Rather just running them where they really shine - the rest/lower goes to your sub where hopefully it really shines.... :-)
Cheers.
post #26175 of 30942
Now that makes sense Smitty..
post #26176 of 30942
Originally Posted by otk View Post
of course and an acoustically transparent screen to put the 3 main bp7000s behind and a nice 4K projector
Don't forget to inlcude a nice home in the hills, with a great view, to enhance the listening experience...plus a fully stocked refrigerator.
post #26177 of 30942
The bipolar speakers bounce off the wall behind the speakers right? How far from the wall behind the speaker should the speaker be?
Hello Low,
We usually suggest 2-3 feet from the rear wall, and 2-3 feet from the side walls. But again, as per the discussion before, this is room dependent. They sound good closer to the walls too, but not all rooms (and significant others) can accomodate much distance from the walls. So the best suggestion is to experiment, and see what works in your room.
One of the benefits of the BP 8000 Series design is that they are a bit more "room friendly". The rear firing output is down by 6 db compared to the fronts, which makes them easier to place. I hope this helps - best, Joe
post #26178 of 30942
Cheers.
+1. You beat me to it.
You need to look at the frequency response of the speakers and the sub. The crossover determines what frequency goes to the speaker vs the sub.
post #26179 of 30942
I generally run my towers(7001) at 40hz with my center(CLR1000b) and BPX's at 60hz. Small on an Onkyo is any crossover 40hz and up.
post #26180 of 30942
Thanks guys. What about my 8060HD center.. It has an 8" powered sub in it..
post #26181 of 30942
I have my CLR-3000 (with 10" sub) crossed at 60 Hz. KJSmitty and others have done the same.
post #26182 of 30942
Cool ty,I'll try that..
post #26183 of 30942
Because my pioneer reciever only supports a single global crossover setting I use 50hz for all channels. If I could cross each channel individually I would also run my 8060hd at 60hz and the towers at 40hz.
post #26184 of 30942
I used to hve an Onkyo 805 driving my 7001's, clr 3000's bp20's and bpvx's. I also had three subs at the time. Audyssey set my 01's to large, I changed that to 40hz. It set my 3k to large, I changed it to 60 hz. It set the bpvx's to 60, I left that, set my 20's to 40, left that.
post #26185 of 30942
Wouldn't it make sense to put the rear of the 8060st's right in front of the wall ,wouldn't that disperse the sound better?
post #26186 of 30942
which do you think are better tower speakers def tech bp 10s or energy rc 50
post #26187 of 30942
No one has bought the new bookshelf speakers?
No reviews yet?
post #26188 of 30942
No reviews yet?
Hi Mac Daddy, we have already sold out of the first production run. We are trying like mad to build more, as we have plenty of orders. I will post the reviews next (although you are looking for AVS reviewers, I'd guess). Best, Joe
post #26189 of 30942
Hello Low, we usually recommend 2-3 feet away from the back and side walls for the BP 8000 series products. They have rear-firing drivers, and the sound stage is noticeably better when you pull them out a bit. If you mean the CS 8060 HD center channel (which is not bipolar, but forward-firing), even a conventional speaker may sound a bit better if it isn't butted up against a wall or cabinet. I hope this helps - best, Joe
post #26190 of 30942
If anybody is looking for SM350's, NEWEGG has them half price for a pair with code EMCNGHN32.
  Back to Forum: Speakers
