Originally Posted by Joe@Definitive
Hello Low, we usually recommend 2-3 feet away from the back and side walls for the BP 8000 series products. They have rear-firing drivers, and the sound stage is noticeably better when you pull them out a bit. If you mean the CS 8060 HD center channel (which is not bipolar, but forward-firing), even a conventional speaker may sound a bit better if it isn't butted up against a wall or cabinet. I hope this helps - best, Joe
I kind of thought that,thank you Joe. Do the rear firing drivers really make any difference?
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
Sound stage is definitely a Def Tech strength! Glad you are enjoying them.
