AVS › AVS Forum › Audio › Speakers › Definitive Owners Thread
Definitive Owners Thread - Page 877
post #26281 of 29330
Originally Posted by sivadselim View Post
Either way, "joking" is the operative word, here.
Almost all speakers are designed with a vertical orientation for a reason. If horizontal speakers worked better, that's what we'd all use. We don't.
Maybe so. Not that I doubt you, but all this technology must be helpful
"includes state-of-the-art features like high-definition polymer coned cast-basket bass/midrange drivers, wide dispersion tweeters, and complex Linkwitz-Riley crossover networks"
post #26282 of 29330
Any thoughts on the ideal size dedicated theater room I may be moving and need to build one in the basement. I have a 81" tv, 7002 towers clr 3000 center, 4 bpvx surrounds, and a vylodyne sub. It would be quite smaller then my set up now witch is in my living room. Just a rough guess would be 13x17 for the new room.
post #26283 of 29330
incase some of you missed it I have some vids on youtube of my 8060-st towers playing music and a few movies....this is just for fun....I just recently got the matching cs-8060 center....if anyone would like to hear a specific movie or song ill do requests...
http://www.youtube.com/watch?v=qF_LBvXu0qo
http://www.youtube.com/watch?v=wCH25...eature=channel
post #26284 of 29330
Originally Posted by josh6113 View Post
Well I couldn't wait...lol...found a store that had the 8060 center and picked it up....didn't get home till late so can't test fully til tomorrow but the little testing I've done it seems like an amazing center...can't wait to crank it...
Sweet thx...I'm useing 14 Gage now but just bought 12 Gage and new bananna plugs from monoprice...also the center is amazing!..voices are pronounced and crystal clear...damn fine center
Also a quick question for those with to 8060 center...how do you have it hooked up?...I see you can use speaker wire or an RCA into the reciever pre pro...is one a better hook up or offer a better connection?...thx for any imput
thanks Josh. cool videos
i just use speaker wire. i have tried RCA's and noticed no difference
if you do try it on your center, make sure you use the center pre-out and not the subwoofer output and make sure you recalibrate the sub section of your center speaker because you will be getting a hotter signal from the RCA
personally i don't think it's worth the trouble
post #26285 of 29330
Originally Posted by g_bartman View Post
Joe makes a good point. I was very disappointed with my audition of the 8060's but I'm sure they were not even close to being calibrated properly. Even some "high end" shops seem to be clueless, it's a real shame. I have heard some bad sounding speakers from some first class companies in too many cases.
Hello G Bart,
Many folks just don't realize how much difference placement can make - even me! In 2004, I was hired by Velo and brought home a new sub. I was amazed to find that my previous sub (a good one) was in the wrong spot in my living room the whole time. I put the Velo where the old one was, wasn't impressed... and found that a foot and a half to the right made all the difference. Lesson? Always experiment! Thanks for owning Definitive - best, Joe
post #26286 of 29330
Originally Posted by Joe@Definitive View Post
Hello G Bart,
it's a good thing Velo didn't find out you had your sub in the wrong spot before they hired you
post #26287 of 29330
Originally Posted by LowTech1 View Post
Joe,everyone has their opinions on where to cross the def techs at.. What should the 8060's be at and the 8060 center.. 60hz,80hz full band?
Hello Low, rule #1 is to experiment! The recommended THX standard is 80 Hz. But with lots of small speakers, you get a better blend at 100 Hz or even 120, letting the sub fill in what the small sats cannot do. But... the higher you cross over the sub, the more directional it becomes, and easily localized bass is irritating bass. So with bass capable speakers like BP 8060 and CS 8060, I suggest experimenting with 60 or even 40, assuming you have a sub. You can try them full range too, but my guess is that in most rooms, you'll get your best result at 60 or 40. I hope this helps - best, Joe
post #26288 of 29330
OTK, you funny! Yep - I thought I knew a lot about subs before I worked there. I soon found out how much I didn't know! Life's for learning, right?
post #26289 of 29330
Why not put the front 3 speakers at full,surrounds at 80 and sub at 80? I was watching Transformers last night and with the front 3 on full,it sounded better. Optimus voice had that deep resonance that it didn't on 60-80 hz..
post #26290 of 29330
So then keep it at that....... If it sounds better to you then why change it because of what other people do? Like a previous poster said:
"Hello Low, rule #1 is to experiment!"
post #26291 of 29330
That's what I did.. But when other people tell you religiously to put it at 80 fronts,100 center and surrounds and 120 sub.. It makes you second guess yourself.. Ya know.
post #26292 of 29330
Listen to other people's opinions, then experiment and do what sounds best to you. I run all my channels full frequency except the rear surrounds and it sounds great. If I had taken most everybody else's advice, I wouldn't have done so.
post #26293 of 29330
All I know is when I put the front 3 to full,it sounded much better and full. Optimus Primes voice just resonated,sounded great. The sub was still going full bore also. Just filled the whole room..
post #26294 of 29330
i run all my channels large. love it. wouldn't have it any other way
yet
post #26295 of 29330
I'm calling the Crossover Police.
post #26296 of 29330
No Crossover is the Best Crossover.
For years growing up, I listened to a stereo with 20W 8" full range dual cone paper speakers.
Awesome sound. In fact, that speaker is still in production, even after 30 years.
post #26297 of 29330
You don't need to crossover speakers with subs in them. Just crossover the surrounds,then you will get the benefit of all the bass.. I think the crossover police are rent a cops.. :P
post #26298 of 29330
LOL no need to call them, i think under the "patriot" act, they know already
you think your receiver is just getting firmware updates off the net ?
post #26299 of 29330
back then receivers had subsonic filters and no blu rays putting out 3hz
post #26300 of 29330
There's not right or wrong rule. It's more depends on your equipments & the room I guess. I used to run my 7002 in full along with a SC1 in my old HT. But in my (currently building) new HT, I'm planning to cross them at 40hz when pair them with a SVS PB12+/Ultra13.
So, it's all depends.....
post #26301 of 29330
not using a crossover takes you down a slippery slope
post #26302 of 29330
Meaning? If your surrounds are set at 100hz and your sub is at 120.. Why would it matter if the front three were crossed at 60,80,100? The bass should be getting redirected to the sub because of the surrounds,right?
post #26303 of 29330
ok you didn't get the "slope" joke
but to answer your question. it all depends on a lot of things
first of all i like my bass coming from the channel that the director placed it in
plus in most cases, if your speakers are capable of handling the frequencies, the bass is better blended with perfect slopes and perfect phase
i wouldn't recommend everyone use the large setting. probably only the bp7000 bp2000 and bp3000. most other towers could help from a 40hz 60hz or sometimes even a 80hz crossover unless you're only doing music than pretty much any tower can be set to large.
but every room, every set-up, every listening preference is going to be different so it's best to just listen and go with what sounds best to you
some people live and die by measurements which is fine. whatever floats your boat
everyone has bass management in their receivers so it's free and easy to experiment. just have a seat and pick up the remote
as far as a the center. that will also depend. i have no trouble keeping mine set to large. so far i have only come across one movie where i heard the port breathing heavily and that was from the movie Pulse and only at reference levels plus i was standing near the speaker
another thing to remember with bass management is if you are one who likes to run your subwoofers "hot", you are not just running the LFE channel hot, you are also running the redirected bass from any channels set to "small" hot as well. not a very desirable thing, especially concerning the center channel
one more thing, if your speaker happens to be in a bad spot and you're getting a nasty null in response, you'll probably want to use bass management. EQ can't fix that. a plus for towers is there are dual subs helping smooth response
post #26304 of 29330
Lowtech we both have the same speakers...8060 towers and 8060 center...running our fronts full does sound best..granted I don't have an external sub just towers and center...but hell in my room 2 10 inch subs in the towers and an 8 in the center another sub isn't needed...only thing to cross at 80 or 100 is surrounds...everything else should be full IMO...
post #26305 of 29330
The speakers' actual capability aside, do you guys understand the benefit that crossing over a channel provides at the amplification stage? It can provide a huge increase in available headroom for cleaner reproduction of those frequencies that the amplifier IS asked to amplify. An 80Hz crossover reduces the workload on an amplifier by ~66%.
post #26306 of 29330
my little old Denon 3802 runs 5 bp2000 2 bp30s and a clr3000 all set to large with no problem
back in the pro logic days, the front channels would have 100 watts and the surrounds 20 or 40 but when dolby digital came out, they made the power equal to all channels because the surrounds are now full-range
def techs are not that bad on efficiency. usually around 92db
now if you're planning on running an entry level receiver in a very large room then yes that may be an issue
post #26307 of 29330
This misses the point.
relevance?
relevance?
The benefit is there, regardless.
Granted, owners of powered towers or someone who is trying to run a dedicated subwoofer on their speaker channels (who would do this?!?!?!? ) has a unique situation that could warrant leaving the speaker channels running full-range. But even using a 40Hz crossover setting can provide an appreciable benefit.
post #26308 of 29330
I think it entirely depends on the sound your getting.. If you cross it at 40 or 80 and it doesn't sound as good,what's the point of crossing it.? Also depends on the movie I think also. Going from Iron man 2 to Tron Legacy is a big difference..
post #26309 of 29330
That's why I run mega amplification.
post #26310 of 29330
I think it entirely depends on the sound your getting.. If you cross it at 40 or 80 and it doesn't sound as good,what's the point of crossing it?
I told you the "point". Among other things, it reduces the load on the AVR's amplifiers considerably, allowing the amplifiers to more cleanly amplify those frequencies they ARE asked to amplify.
Have you tried a 40Hz crossover with the speakers you are running full-range?
Regarding the "sound your (sic) getting", the sound you're getting may have as much or much more to do with your room and exact settings (i.e., a tower's sub's volume setting, among many other things) than it does with the crossover point you are or are not using. Definitively determining that you prefer running the speakers full-range over crossing them over would require carefully making sure that you eliminate or reduce as much as possible ANY other variables which are affecting the results. And there are PLENTY of other variables, here.
  Back to Forum: Speakers
