Most will sell in the $250-$275 range. $175-$225 is typically the lowest found for "mint"
Is that all That seems low considering what the cost for the new line of rear speakers are being offered. A friend just sold a pair for >$350 in good shape.
Advice please: I helped my cousin buy a pair of 7002's CLR 2002 and a pair of BPX's. He now wants to know is his system complete. I told him adding a sub would improve the preformace of the 7002's, am I right? If so, what sub should he get, the room is 16x25x9. He does not want to spend over $1000
that's a nice sized room. not sure a $1000 sub is going to sound much better than the dual subs of the 7002s. you'll probably get a tad more extension but not much more output at that price point
i might try and talk him into another $500 and go with one of these
or maybe a single empire nearfield and add a 2nd down the road
just look at ID brands like HSU Epik Ed SVS and pick the best sub he can afford
just remember that once he sets his 7002's to small he's taking dual 12" subs with quad passive radiators out of the mix and replacing with a single $1000 sub for a larger sized room. he really should try and up the budget a bit. sometimes waiting longer and saving up for a better sub pays off
if he goes with a store bought sub that will make things even harder
as far as people using the speaker level (high-level) input/outputs every sub is different. check the specs and the manual if possible
i'm pretty sure all the def tech subs use a Non Variable 6 dB/octave @ 80 Hz crossover
6db is a first-order slope and has a very gentle roll-off so you should make sure your speaker is flat to at least 40hz which will only be down 6db from 80hz and 20hz only down another 6db
Hello OTK, once again you are on it.
1. Our high-pass crossover point is typically 80 Hz @ 6 dB per octave, fixed
2. It is active only on speaker level inputs, keeping the sats from trying to reproduce low frequencies that they won't handle well
3. The exceptions: ProCinema 600 and ProCinema 60, which cross over at 100 Hz, and the ProCinema 400 which crosses at 120, for better blending with the sats. I hope this helps - best, Joe
It is hit or miss. $350 from a sellers stand point is great for a pair of used 2X's. But for that price you typically get a pair of used BPX's. I tend to watch the used DT market pretty close in my neck of the woods as well as eBay. There was a pair of 2X's that just went for a bit over $300 on eBay - definitely mint with box and manuals. Local Craigslist however I have yet to see a pair listed for over $275, condition pending of course.
Cheers
My 10 month old BP 2X pair sold for $319 + shipping on ebay a few weeks ago. So it does seem like their prices have gone up since they were discontinued.
$1000 could go a long way if he looks at "pre-owned" subs. I got my SVS 16-46pc+ for $500.
Yeah I'm in a similar situation. Our LR is about 25'x15' with one side opening to kitchen and sloped 11' ceiling. Got a good deal on a new Outlaw EX bout a month ago for $475 but there was little improvement, if any, over dual 7001's in the room. Over the weekend I removed the sub, reran Audessey, it set mains back to large and I dare say it does a better job of filling the room. Of course I could have got another EX but I decided it would be better to just save up for some Ultra's or a Submersive and sell the EX.
Hmmm..... I'm confused otk.
I always thought most of the time it was recommended to set any BP supertower to small, cross them at 40/60hz (depends on the model), and have a dedicated sub to do the ultra low bass duty?
I'm at the planning stage for my new HT (15'x20'x9'), and was planning to purchase a PB12+ sub and cross my BP7002 @ 40hz. From what I read from the above statement, may be I should set it to Large then?
Everyone's room, expectations are different. When I had my 7001's up front, I set them at 40 hz and let my subs do the heavy lifting. When listening to music, I only use my svs pb12+2 and turn the other three off. The svs hits notes (pipe organ etc) the the 7001's simply cant when set to large. Again, this is in my room, ymmv.
It's always a good idea to experiment.
If I may, I believe what otk was referring to is that given his (Plex's) large room and plans for a single standalone sub, cutting his 7002's even at 40 hz may not be the best option. It may sound better to let the 7002's work as much of their magic as they can in the below than 40 hz range to "facilitate" the other $1000 sub. Now if his standalone sub was a performance beast or Plex had twins, cutting the 7002's at 40 or 60 hz would/may be best etc.
That's another reason however why I like the RCA/LFE connection to my towers (near 100% HT use however,,). Whether I add a crossover point or not I know I can still direct/utilize low frequencies and LFE out of the built in subs etc.
yeah my post had nothing to do with large or small setting
the point was when you get your new sub and set your towers to small, you're taking away dual 12" subs and replacing them with a single sub (in the $1000 price range) you "might" not get the improvements you're hoping for in a very large room
I understand with a lesser sub, it doesn't make sense to cross the supertower. In my case, in my old HT, I have BP7002 & a SC1, I ran the BP7002 in Large + Sub 'cos I know the SC1 isn't much, if any, better than the BP7002. If I cross them, I might end up with less output and/or extension.
But I saw otk had a VTF-15 in his $1000 list! May be that what made me confused as we all know the VTF-15 is one of the best sub for the money with very good output & extension.
if anyone is into the Titanic there are a lot of specials on the history and science channels. i believe Sunday is the 100 year anniversary of it's sinking
H2 (history 2) is running a marathon right now
There's also a good BBC mini-series entitled "Titanic" from the same folks who produce the Downton Abbey series that should be airing stateside soon.
I saw a mint bp2x pair listed for $200 on Philly Craigslist. Take a look if you are local.
Just joined the DefTech club by getting a pair of outdoor AW6500 speakers. I am actually using them in an unfinished basement, supplemented by a 12" sub. They sound good and can take a lot of power from the amp.
Cool. I have some on my patio and love them. My neighbors, well,.......
Welcome Pete. I can verify that Abraham LIncoln did, in fact, say that "The problem with quotes on the internet is that you never know if they're real." I know this because he told me so himself over a couple of Bud tall-boys.
