AVS › AVS Forum › Audio › Speakers › Definitive Owners Thread
Definitive Owners Thread - Page 882
post #26431 of 29315
Originally Posted by Joe@Definitive View Post
Welcome Pete. I can verify that Abraham LIncoln did, in fact, say that "The problem with quotes on the internet is that you never know if they're real." I know this because he told me so himself over a couple of Bud tall-boys.
You're such a fibber!! Lincoln hated Budweiser.......!
post #26432 of 29315
He's a Sam Adams guy. The Abe sure could put em down, funniest lamp shade dance I've ever seen.
post #26433 of 29315
Rightfully so! No one should drink that Belgian crap otherwise known as Budweiser!!!
Heineken, Dos Equis and Newcastle are the way to go!!! :shameless plug:
post #26434 of 29315
Yep. He looked like a 6'4" Elaine Benes with a beard...and a lamp shade...
post #26435 of 29315
Yikes! Not a real beer in that bunch Newcastle comes closest but still......seriously
post #26436 of 29315
I am in the market for a new pair of Def Tech side surrounds to compliment my BP-30's +C/L/R-2000. Due to having to take another round of chemo, money is tight so my budget is $250.00 and under. Of course I would love to have a pair of BPVX's or SR-8080bp's but I do not have the money to spare. Having to take chemo, I feel really terrible most I'd the time, but, when I sit back and watch a movie on my Def Techs, it makes me feel sooooo much better! Here are my choices for side's. Opinions on which one I should go with?
SR-8040bp (new model surrounds in case you aren't familiar)
BP2x
BP1.2x
BP-1 (old school Def Tech surrounds from several years ago)
post #26437 of 29315
Wow Marty, I'm sorry to hear about what you are dealing with and wish you a speedy recovery. Glad your system gives you some needed relief. I used to have bp2x's (since replaced by bpvx's) and thought for their size, they did a very good job. If I see any deals on some, I'll pm you.
post #26438 of 29315
i just gave my friend my pair of sm-350's
i'm thinking a nice center for those would be a pro center 2000 or a CLR-2002, a 3rd sm-350 or even a clr1000b
if anyone happens to see any of those dirt cheap please let me know. he's on a very tight budget
he loves the sm-350s by the way coming from a really old htib
post #26439 of 29315
Marty, I also agree with g_bartman recommendation. I replaced a pair with some BPVX/P's a couple months back but those 2X's are great surrounds. Good luck in your recovery.
post #26440 of 29315
BP2x
BP1.2x
hope you get better soon
post #26441 of 29315
i also went from 2x's to bpvx's...juice and g-bart are spot on...great surround speakers
my sister-in-law went thru chemo at 39 yrs old...3 weeks ago she celebrated her 43rd birthday. she's doing great!
good luck marty...all the best!!
post #26442 of 29315
Thanks guys. I am actually pretty young to have gotten this. Under 30 years old
post #26443 of 29315
Looking for opinions on which sub to pair with my CLR2000 to get that full range, CLR3000 performance. I've got a Super Cube III & Pro Sub 600 laying around. How do those subs compare to each other, and which would come the closest, or surpass the performance of the CLR3000, when paired with the CLR2000?
post #26444 of 29315
Hi Felton,
The SC III is a more powerful sub, with a bigger amp. It can play louder, and play deeper notes, than the ProSub 600, which is a fine sub in its own right - but is a less expensive product. So the SC III is the better bet to give you the best performance from your CLR2000. I hope this helps - best, Joe
post #26445 of 29315
Hang in there Marty! I was 34 when I was diagnosed, and that's 20 years ago. We're praying for you. Best, Joe
post #26446 of 29315
try them both and see which one sounds best. be careful with the calibration. you don't want the sub too loud on the center channel. it should be as carefully blended as possible
the standalone subs will probably have better bass performance (more output and extension) over a clr3000 but where the clr3000 has the advantage is the mid-range drivers are in a sealed chamber where the clr2000 mid/bass drivers share the same ported box plus the clr3000 has the advantage of having it's woofer seamlessly and flawlessly blended to the mids
if i were going to add a subwoofer to my center channel, i would probably look for a small sealed forward firing sub but that's just me. i'm sure you can use any sub you want
post #26447 of 29315
the BPVX is the best surround speaker on the planet
i would recommend them for use with any other speaker no matter what model or brand
post #26448 of 29315
My Definitive Technology Surround Sound system:
BP3000's
CLR3000
BPVX (sides)
BPVX-P (rear) These were icing on the cake. )So much sound back there I never knew) AVR is Denon 5700, Lots of power per channel, weighs a ton!
AVR Sony STR-DN1010 3D
Oppo BDP-83SE incredible for direct analog output(all formats)
Oppo BDP-93 for 3d (all formats)
JVC DVHS HDTV HM DH40000 Recorder
Pioneer DVD/LD DVL-91 Laserdisc Player Rosewood.
Samsung BD-U5000 BR/HD-DVD player
AppleTV2
Combine above with Optoma HD33 3d front projector and/or LG 47LW6500 passive 3D 240hz hdtv.
I started with just the clr3000 and stuck with it until I had a complete system. Not an overnight thing but worth it all. I must say the addition of the BPVX-P powered rear speakers brought it all together. I am enjoying every audio/video format and until I'm totally deaf it is unbelieveable bar none. When I am unable to blast it, I have to use my Sony DP-RF6000 Surr headphones cranked up. Demo: The Phantom of the Opera, bluray, highs & lows will sell the system.
Enjoy:-)
post #26449 of 29315
Marty, hang in there!
I had cancer treatment 2009 and now fully recovered thanks to Proton Precision Beam Cancer center treatment at M.D.Anderson Hostpital, Houston, tx. Quite an journey at first, but daylight was ahead. Again hang in there!
post #26450 of 29315
Hang in there Marty.
post #26451 of 29315
BP3000's
CLR3000
BPVX (sides)
AppleTV2
Enjoy:-)
awesome set-up BillFree
post #26452 of 29315
BP3000's
CLR3000
BPVX (sides)
AppleTV2
Enjoy:-)
So when are you inviting us over for movie night?! Awesome system! I still need to find some BPVX's to upgrade my BPX's.
post #26453 of 29315
I will be selling a set of BPVX'S and a SVS PB12-NSD sub. I will replace these with another set of BP3000TL's for surrounds
post #26454 of 29315
that's insane. are you out of your mind ?
post #26455 of 29315
Pure CRAZY talk!!
Time for an intervention... Most of these cases can be cured by an unannounced swap of the inflicted's DT towers with a Bose Acoustimass system.....
post #26456 of 29315
Pure CRAZY talk!!
HEY i'm using Bose AM-5's on my computer
i still say we need a tower version of the BPVX. picture a bp7000 twisted into the shape of a BPVX
now THAT'S what the BPVX/P should have been
post #26457 of 29315
Oh, The Horror
post #26458 of 29315
Oh, The Horror
Just messaged you badger
post #26459 of 29315
Hi all, sorry I haven't been around for awhile. Work has been hectic. I have decided to upgrade my surround back speakers. I am selling my black Mythos ST SuperTowers on Audiogon and intend to replace them with a pair of BP7000's to match the front. Here is the link if anyone is interested....
http://app.audiogon.com/listings/def...towers-pair--2
post #26460 of 29315
Must be something wrong with you like myself....lol
  Back to Forum: Speakers
