2.doe's the lower raditater appear normale? it appears to be just a big hole and no radiater woofer?
3.which is the front and back?
4.can a tower speaker be cut in half and made into a monitor type speaker?
5. doe's this speaker have the same type of woofer and tweeter as the SM450?
STB
6.I'm thinking these are the orginale BP10 made in 1990?
Edited by stevethebrain - 12/2/12 at 8:43am
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
Remember that phase can only be truly correct at a specific frequency, so it doesn't surprise me that you got that result. Your towers should not cancel each other out if you have them correctly placed, but part of correct placement is getting them so that they are in the best location to not have the woofers fight each other. Thanks for owning DT - best, Joe
