Finally jumped on a pair of SM350 to upgrade from my Pioneer C21 in my main home theater. So now, the upgrading of center and surrounds are to follow. The question is: are all the DefTech timbre matched or is it series by series match? Thanks for any input!
post #27631 of 29303
12/19/12 at 8:04am
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
Loving the metal dome tweeters vs the silk domes in the speakers the DefTechs replaced. Now to finish replacing the rest of the setup. I did finally find a factory refurb CLR 2002 for my center, so thats on its way soon! Considering some BP1X for surrounds. Another question on the surrounds, would it be ok to use them in a 5.1 setup with them mounted straight to the side of the listening position without any room behind the listening position, aka the couch is against the backwall, since they are bipolar? Thanks and Im glad I made the switch to DefTechs!
