I thought about finding some custom L brackets and putting mine right above my TV pointing down. It was just easier to put it on the floor and adjust the angle using 1/4" bolts. Only cost 30 cents vs. having custom L brackets made. Knowing my luck I'd come home and see that the CLR3000 came loose from the wall and crashed onto my TV.
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
Loving the metal dome tweeters vs the silk domes in the speakers the DefTechs replaced. Now to finish replacing the rest of the setup. I did finally find a factory refurb CLR 2002 for my center, so thats on its way soon! Considering some BP1X for surrounds. Another question on the surrounds, would it be ok to use them in a 5.1 setup with them mounted straight to the side of the listening position without any room behind the listening position, aka the couch is against the backwall, since they are bipolar? Thanks and Im glad I made the switch to DefTechs!
. Having said that, it's OK to put an SM 65 horizontally for a center channel speaker. The bass radiator will be fine (assuming you are not going into a cabinet in which it fires directly into the side of the cabinet). Compared to the CS 8060HD center, it's less money... but the CS 8060 has a powered subwoofer. That really helps with center channel vocal and left - right scenes. Thanks for your interest in DT! Best, Joe
