Originally Posted by UofAZ1
James my version of lobing is when two speakers are transmitting the same info and you get cancellations of signals. With both forward and rearward speakers transmitting the same signal I would assume that some cancellation is going on. Lobing is more prominent when two separate speakers are transmitting the same signal and they cross each other out on certain frequencies and was wondering if your noticing that effect with the center speaker back drivers conflicting on the front drivers.
I actually asked Chet about disconnecting the rear drivers he suggested leaving them. Also asked about the passive he said if I could get 2'' clearance thats fine.
It sound normal to me but not really to sure what to be listening for to tell you the truth.
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
