Originally Posted by jjcook
I went with the AVR 1713 and am very happy with it. I chose 1713 over 1913 as the 1713 has Audessey XT (as does the 2113) but the 1913 only Audessey non-XT.
With my Mythos 8's above the fireplace, I am currently auditioning a procenter 1000 (wife/placement issues) and have not been impressed yet but I'm giving it a chance to break in -- my initial REW measurements show > 10db drop in output below 150hz but Audessey set the crossover at 120hz. Once I get my sub I'll see if localization is an issue with such a high crossover with the sub in the rear.
Thanks for your input. I agree with you on the Audyssey XT; basically, it's why I thought the 2113 would be a better choice than the 1913. The 1713 also looks good, and is on the less expensive side. My only qualm is that the 1713 only supports 5.1, and I'm unsure whether or not this will be enough for the room I described.
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
