Originally Posted by jsampsell
I bought the BP-8060STs, the CS-8080HD and the SR-8080s and am running them off of an Emotiva XPA-5 with my Denon AVR-4311CI as the pre/pro. I am only using a PS3 for my Blurays but I have been seriously impressed as well with this setup. The speakers sounded great run off of the 4311 but when I added the XPA-5, man it just took it all to a new level. I also came from Polk Audio: Monitor 70 front L/R, CS20 center and RM7 satellites from my previous RM85 satellite system. I was also running two Infinity PS212 subs. I initially tried the 8060s by themselves and was blown away at the bass output. I have since added the PS212s back into the mix just for additional help. I'm running the 8060s as small with the lowest crossover that the 4311 allows. I haven't had enough time to tinker and find out what setup really works best but overall I am so excited about my new stuff. This is the best my movies have ever sounded.
On the downside, the movies sound great but two-channel music doesn't sound so good and I don't know why yet. I'm still hoping for some time to look into that too.
You might want to look at the final Audyssey XT32 settings for two-channel. If you want, you can choose "Custom" and set Subwoofer=yes, crossover at whatever setting you have for the regular setting (knowing Audyssey, that would be 40 Hz). Then the subs will always be "on" the way they are for multichannel content.
However, I should point out that you should experiment with a crossover of 60 or 80 Hz to see if the bass is better (meaning deeper and more integrated soundstage) in the 40 to 80 Hz region by having your subs handle it. If you're using standard Audyssey (vs. Pro), you can raise your crossover from the ones that Audyssey set. You just can't lower them from what Audyssey came up with.
FWIW, you'll find a lot of guys on the Audyssey & 4311 threads that run their mains, DefTech BP and Mythos towers included, at 80 Hz crossover. I've seen CS-8080HD crossover ranging from 60 Hz to as high as 90-100 Hz. I did a lot of agonizing, and utimately found that with my ULS-15s, the 90/100 Hz crossovers actually sounded better at the end of the day. YMMV, depending on your room and setup.
Edited by sdrucker - 3/14/13 at 11:07am
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
Good luck with figuring out your problem, and if you're at all interested PM me!
