Originally Posted by
MrHifi
While I seem to be getting the A35 to operate at 24P, I can not get the Panasonic BD30 to do the same. In fact, It will not allow me to select 24p in its software. Thoughts?
Also, this Advanced Audio Codecs thing is not easy to implement. I am not seeing what I should in the Integras 9.8.
Jeff, to be quite honest, I can not see any difference in PQ regardless of the frame rate.
The projector no longer operates on low blower. After a few seconds on low blower I get blue and red blinking light that require an unplug/replug. PIA
This saturation thing is a big deal. Whites are devoid of detail. Maybe the 1000+ hour bulb..
Art,
The HD81 needs 24P sources with forced 24P ability, not sure if the BD30
does this.
I'm sorry that 24P doesn't give you an obvious improvement in motion. I
was hoping it would. Another reason for me to not feel too bad about not
taking delivery of my Samsung combo player.
That's a pain about the LV not working at low power mode. This has never
been an issue with the three HD81's and one LV I've had.
Are your clipped whites on all inputs? Component and HDMI? If just HDMI,
are you using the Integra for HDMI switching? If so, have you bypassed the Integra to make sure it is not causing the clipped signal?
My LV continues to work very well and is stable in all areas, other than a shutdown when connected to a PS/3, but it worked fine for many hours
after that.
