Have you tried running the HDMI straight to the projector and digital audio to the receiver? Not sure if the PS3 does this.
Scott
Scott
; INF file generated by Monitor Asset Manager, 3/13/2010
; Copyright (c) EnTech Taiwan, 1995-2009.
; Internet: http://www.entechtaiwan.com
[Version]
Signature="$WINDOWS NT$"
Class=Monitor
ClassGUID={4d36e96e-e325-11ce-bfc1-08002be10318}
Provider=%MFG%
DriverVer=3/13/2010, 1.0.0.0
;CatalogFile=YourSignedCatalogFile.cat
[DestinationDirs]
DefaultDestDir=23
[SourceDisksNames]
1=%DISC%
[SourceDisksFiles]
;YourColorProfileFile.icm
[Manufacturer]
%VENDOR%=EDID_OVERRIDE,NTx86,NTamd64
[EDID_OVERRIDE.NTx86]
%PRODUCTID%=OVERRIDDEN-EDID.Install, MONITOR\\OTM4844
[EDID_OVERRIDE.NTamd64]
%PRODUCTID%=OVERRIDDEN-EDID.Install.NTamd64, MONITOR\\OTM4844
[OVERRIDDEN-EDID.Install.NTx86]
DelReg=DEL_CURRENT_REG
AddReg=OVERRIDDEN-EDID.AddReg, MODE1, DPMS
CopyFiles=OVERRIDDEN-EDID.CopyFiles
[OVERRIDDEN-EDID.Install.NTamd64]
[OVERRIDDEN-EDID.Install.NTx86.HW]
AddReg=OVERRIDDEN-EDID_AddReg
[OVERRIDDEN-EDID.Install.NTamd64.HW]
[OVERRIDDEN-EDID_AddReg]
;Base EDID
HKR,EDID_OVERRIDE,"0",0x01,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x3E,0x8D,0x44,0x48,0x19,0x04,0x00,0x00,0x2B,0x10,0x01,0x03,0x80,0x00,0x00,0x78,0x0A,0x0D,0xC9,0xA0,0x57,0x47,0x98,0x27,0x12,0x48,0x4C,0xAD,0xCE,0x00,0x81,0xC0,0xD1,0xC0,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x1D,0x80,0x18,0x71,0x1C,0x16,0x20,0x58,0x2C,0x25,0x00,0xC4,0x8E,0x21,0x00,0x00,0x9E,0x8C,0x0A,0xD0,0x8A,0x20,0xE0,0x2D,0x10,0x10,0x3E,0x96,0x00,0x13,0x8E,0x21,0x00,0x00,0x18,0x00,0x00,0x00,0xFC,0x00,0x4F,0x70,0x74,0x6F,0x6D,0x61,0x20,0x48,0x44,0x38,0x31,0x0A,0x20,0x00,0x00,0x00,0xFD,0x00,0x18,0x3C,0x0D,0x44,0x0F,0x00,0x0A,0x20,0x20,0x20,0x20,0x20,0x20,0x01,0x3A
[DEL_CURRENT_REG]
HKR,MODES
HKR,EDID_OVERRIDE
HKR,,MaxResolution
HKR,,DPMS
HKR,,ICMProfile
[DPMS]
HKR,,DPMS,,0
[MODE1]
HKR,,MaxResolution,,"1920,1080"
[OVERRIDDEN-EDID.AddReg]
HKR,"MODES\\1920,1080",Mode1,,"13.0-68.0,24.0-60.0,+,+"
[OVERRIDDEN-EDID.CopyFiles]
[Strings]
MFG="EnTech Taiwan"
DISC="Monitor EDID Override Installation Disk"
PRODUCTID="OTM Optoma HD81 (EDID Override)"
VENDOR="OTM"
Monitor
Model name............... DTR-9.9
Manufacturer............. Onkyo
Plug and Play ID......... ONK0899
Serial number............ n/a
Manufacture date......... 2007, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.625 - Ry 0.340
Green chromaticity....... Gx 0.280 - Gy 0.595
Blue chromaticity........ Bx 0.155 - By 0.070
White point (default).... Wx 0.283 - Wy 0.298
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 13-68kHz
Vertical scan range...... 24-60Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #1....... 720x480p at 60Hz (4:3)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 720p at 60Hz - VESA STD
1920 x 1080p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
DTV underscan............ Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 1
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #2....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.350 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #3....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
CE video data (timings supported)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1440 x 576p at 50Hz - DVD (4:3, 8:15)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
2880 x 480i at 60Hz - Console (4:3, 2:9-20:9)
2880 x 576i at 50Hz - Console (4:3, 2:15-20:15)
2880 x 576p at 50Hz - Console (4:3, 4:15)
2880 x 480p at 60Hz - Console (4:3, 2:9)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 8-channel, 640k max. bit rate at 32/44/48 kHz
DTS 8-channel, 1536k max. bit rate at 44/48 kHz
SACD 6-channel at 44 kHz
DD+ 8-channel at 44/48 kHz
DTS-HD 8-channel, 16-bit at 44/48/88/96/176/192 kHz
DVD-A 8-channel at 44/48/88/96/192 kHz
CE speaker allocation data
Channel configuration.... 7.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. No
Front left/right center.. No
Rear left/right center... Yes
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 3.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Report information
Date generated........... 3/16/2010
Software revision........ 2.44.0.825
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,3D,CB,99,08,00,00,00,00,00,11,01,03,80,00,00,78,0A,0D,C9,A0,57,47,98,27,
12,48,4C,AD,CE,00,81,C0,D1,C0,01,01,01,01,01,01,01,01,01,01,01,01,01,1D,80,18,71,1C,16,20,58,2C,
25,00,C4,8E,21,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,13,8E,21,00,00,18,00,00,00,FC,00,44,
54,52,2D,39,2E,39,0A,20,20,20,20,20,00,00,00,FD,00,18,3C,0D,44,0F,00,0A,20,20,20,20,20,20,01,7D,
02,03,39,71,50,13,10,11,85,04,02,14,06,15,1F,1D,0E,0A,19,25,23,38,09,7F,07,0F,7F,07,17,07,50,3F,
06,C0,4D,02,00,57,06,00,5F,7E,01,67,5E,00,83,4F,00,00,66,03,0C,00,13,00,80,01,1D,00,72,51,D0,1E,
20,6E,28,55,00,C4,8E,21,00,00,1E,F3,39,80,18,71,38,2D,40,58,2C,45,00,C4,8E,21,00,00,1E,01,1D,00,
BC,52,D0,1E,20,B8,28,55,40,C4,8E,21,00,00,1E,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,87
