Originally Posted by
rajdude
Hmm, as the power supply already has issues with heat and possibly overloading, I may want to hook up the 12 volt fans to the existing 20 V wires. I will just use a 7812 on a tiny PCB OR maybe a simple power resistor will do too.
That's a bit silly, the 7812 that regulates power for the PSU fan doesn't do any other work, it will not mind an extra 200mA.
Your PSU is not overloaded, but it's not being ventilated very well, so a better fan and more holes are a good idea.
rajdude
Well, I am REALLY worried about all those connections and me leaving one disconnected by accident and ruining the tubes or the electronics
Don't worry, it's not all that bad, most connectors are impossible to plug in wrong (unless you try) and all you need to do is to go over every connection twice before turning it on again.
rajdude
Plus all the time involved in dismantling and putting it back CAREFULLY.
You don't have to be that careful, if you have ever worked with a PC you know all you need to, don't use any violence and be careful with the tubes and you will do fine.
Remember: These machines are built to be taken apart a lot
rajdude
I will think of another way
Please don't to make the holes you really need to manhandle the chassis, so leaving any electronics or the tubes in the there is a bad idea.
rajdude
Do you really have to take out the tubes for changing the glycol?
Yes, this is what I did (for each tube):
1) Remove lenses (the 3 hex bolts)
2) Remove all connections to tube/neck including the neckboard.
3) Unscrew the long bolts that are used to lock the tube for toe-in.
4) Unscrew the top and bottom pivot bolts.
5) Carefully pull the tube out the front, taking care not to hit anything with the the neck.
6) Open the top plate that covers the expansion bellows.
7) Let rubber soak in bleach and scrub with a plastic brush.
8) Discard glycol.
9) Unmount c-element (remove screws and push on the inside of the element though the fill-hole), put it in soapy water and carefully wash it using nothing but your rubber gloves.
10) Put the tube on the edge of your sink and rinse/wash the inside of the champer and the tube-surface with a plastic brush and warm soapy water.
11) Once all three pieces are absolutely spotless rinse each in demineralized water.
12) Mount the c-element.
13) Fill chamber with bleach and let it soak for a while.
14) Rinse chamber a couple of times with demi-water.
15) Fill with glycol.
16) Mount bellows (I had to use some drops of glue to keep it aligned while mounting the plate).
17) Reverse the mounting procedure and repeat for the rest of the tubes.
The cleaning of the LC chamber takes lots of water and detergents that you don't want anywhere near electionics.
You need to clean the insides of the chamber , changing the glycol is not enough.
rajdude
Yes, I do need to change to glycol. I found a doc with some pretty elaborate instructions.Why
the Silicon caulk and all that cutting??
Forget about it, there is no chaulking or cutting involved, the Ampros use a different scheimpflug system than the normal HD10 setup, on the Ampro the LC champer is fixed to the tube and the rest of the optics is flapping around.
On normal HD10 systems the LC chamber is deformed to provide scheimpflug.
