AVS › AVS Forum › Display Devices › Rear Projection Units › Bulb Life 2006: All Microdisplay owners please vote
post #1 of 129
I originally posted a poll on this back in March '05. I figure now a lot of people have put more hours on their sets and I figured I'd re-poll.
Here's last years poll http://www.avsforum.com/avs-vb/showt...hreadid=516125
CCourtney
EDIT: Corrected URL to point to last years poll instead of a picture of my TV
EDIT: Adding information about Service Menu's so users can find their lamp usage.
Most people can find the hours on their bulb by going into their Service Menu (SM). If people send me a PM I'll post links threads indicating how to get into the SM of various sets.
Instructions for entering the SM of various HDTVs
Samsung DLP Sets: With power off, using the remote Mute, 1, 8, 2, Power will get you into your service menu.
Caution: Before changing settings in the SM it is strongly advised that you write down all the settings in the SM. There have been reports of people damaging sets by making changes in the SM, so if you're not comfortable don't do it. Browsing the SM to find the bulb usage does not require the changing of SM settings.
SM Picturers:
JVC D-ILA
http://www.avsforum.com/avs-vb/showt...&&#post6454176
Mitsu 1080p
http://www.avsforum.com/avs-vb/showt...&&#post6201460
Panasonic
http://www.avsforum.com/avs-vb/showt...&&#post5677129
Hitachi LCD
http://www.avsforum.com/avs-vb/showt...&&#post5144531
Samsung DLP
http://www.avsforum.com/avs-vb/showt...&&#post3841704
Toshiba DLP
http://www.avsforum.com/avs-vb/showt...&&#post4864441
Owner Threads:
HP Pavilion DLP
http://www.avsforum.com/avs-vb/showthread.php?t=592933
Qualia 006
http://www.avsforum.com/avs-vb/showthread.php?t=498008
RCA HDxxLPW162
http://www.avsforum.com/avs-vb/showthread.php?t=474836
Toshiba xxMX195
http://www.avsforum.com/avs-vb/showthread.php?t=597364
Sony SXRD xxBR1
http://www.avsforum.com/avs-vb/showthread.php?t=584936
Toshiba 1080p
http://www.avsforum.com/avs-vb/showthread.php?t=541611
Hitachi LCD V500
http://www.avsforum.com/avs-vb/showthread.php?t=351829
Samsung 1080p
http://www.avsforum.com/avs-vb/showthread.php?t=559872
Thanks go out to Videobruce for most of the links here.
CCourtney
post #2 of 129
Here's last years poll http://www.avsforum.com/avs-vb/attac...chmentid=32310
CCourtney
the url is a picture.....no results
post #3 of 129
Need to bump this back up to the top
post #4 of 129
Needs to be a 'sticky'! Request submitted to the 'powers to be'.
post #5 of 129
This is an excellent poll. Can administrators sticky is to always be on top?
A sister poll would be to ask average daily viewing hours or length of time before bulb pops.
post #6 of 129
There also needs the be the ability to change your vote or at the least vote again. Say, for example, I vote that my lamp is still working on the original from 2-4K at 2500 hours and I vote accordingly. Six months later it goes out at 3500 hours. I would want to change my vote or add an additional one. Just a thought.
post #7 of 129
I tried and it was shot down..............
post #8 of 129
Wish this poll was more granular because the ranges are too large to be real meaningful. Big difference between 2000 hours and 3999.
post #9 of 129
I think we all have lots of wish's for this poll. But with the restrictions of 'vote once - no update', 10 questions maximum, and the potential for abuse if you use the 'multiple choice' option. This was the best I could come up with.
CCourtney
post #10 of 129
Your choices were fine. Too bad more don't vote.
Possible solution is to post 'How Tos' for the SM for the more popular sets.
post #11 of 129
I just voted; 6K+ on orignal lamp. I've held off fearful that I'd be jinxing myself. (Tomorrow is Friday the 13th afterall).
Anyway, I ordered my replacement lamp already and expect to be swapping it in this weekend. My strategy is to use the new one within its 90 warranty and store the new one, that I am hoping will still work, as a backup should I have bulb failure.
YMMV
EDIT: I have a 42 inch GWIII RP that was purchased in October 2003.
Finally did it with 6,488 hours on the original. Placed it in box and stored it as a spare just in case.
post #12 of 129
Is there a serial number ot a date code on these lamps??
IOW's how can anyone tell when it was bought' made and installed?
post #13 of 129
I find this strange, maybe I'm trolling...
With 52 votes in only 4 of them have replaced their bulb. That's 7.7%. With all the complaining about having to replace our bulbs and the cost and the short life span and 'only people with problems read these forums' and related talk on this board you would think it would be much higher. I also figure 4K-6K hours is reasonable life for these bulbs, I know I don't always treat my bulb well. So less than 4% (so far) have had an early failure, and likely replace under warranty.
Not bad - so far.
post #14 of 129
Not bad - so far.
Your assessment is fair, and consistent from what I've read on other forums. However, both Sony and Sammy, and others to some extent, had bulb and ballast problems, early on. But I would say 2005 was break in that pattern with those sets being repaired and others acquiring displays since late 2004. Still, not one failure in less than 2000 hours. I am sure there have been a few, but mostly attributed to what I said previously.
post #15 of 129
Got less than 3500 on the first bulb, less than half that on the second. Not sure about the third one ... still going ....
post #16 of 129
Um how do people know how many hours are on their bulbs.Do the sets have some counter in there you can reset or something?I can't imagine the average guy would log his hours.I sure don't.And if no counter in the tv then these are all just best guess data and might be very off.
post #17 of 129
Most TV's do log the bulb time, but is usually accessable from the service menu. My number was a guess. Based on 3-5 hours of use per day. Some days are more others are less, but that is pretty close. Works out to about 1275hr a year, for me.
post #18 of 129
Maybe the owner of the thread could edit his 1st post to include mentioning the SM and thread links to some of the more popular models.
post #19 of 129
videobruce,
If you got the links send me a PM, and I'll post them. I'm sorry but I don't have the time at the moment to do the searching
post #20 of 129
Since I don't have a set to watch , I guess I can take a look..............
post #21 of 129
I voted 4-6K original bulb, but to clarify, I had gotten 4-6k out of my original bulb. Then I only got about 1800 hours on the second bulb at failure. I will also toss out my personal opinion...no projection TV set ever again...has since been replaced with a Hitachi 55" Plasma. I love it.
Good Luck,
Mark
post #22 of 129
Have just under 3000 hrs on my Sony 55WF655 and still going strong....hope I didn't just jinx myself.
post #23 of 129
I updated the Samsung link for entering the SM, since it wasn't there orginally.
post #24 of 129
Over 5000 hours on the original bulb. I need to be proactive and purchase a spare.
post #25 of 129
Buy a new one, and save the original for a spare. Never buy 'spares' . Warranties are typically only 90 days on replacement lamps.
post #26 of 129
I put my 60WF655 on low power mode from day one. I have 3500 hrs on it so far.
However, I just picked up a spare off ebay the other day just in case.
post #27 of 129
And if your old bulb goes out at 91 days, the new one would be out of it's 90 day warranty.
post #28 of 129
Seeing how it's an "unused" ebay bulb from a private party, I seriously doubt the word "warranty" even applies here. Got an excellent price on it though so hopefully it works out.
post #29 of 129
You did not explain that before. Good luck with that!
post #30 of 129
bump
  Back to Forum: Rear Projection Units
