Originally Posted by
bigblockhead
I had thought in the 5.0 setup that the rear surround could hang on the back wall. our couch is up against the back wall and i was going to place the speakers on each side of the couch on the back wall.
That's what I do with my 170SE surrounds, which sit on two shelves mounted on the back wall to the sides of the viewers and above ear level, and point directly toward the central viewing location (as though they were mounted on side walls).
bigblockhead
if i was to buy regular surround speakers instead of book case ( like the ones HTD sells) would that work?
If by that you mean bipoles and dipoles, then I seriously doubt that they would work properly in such a configuration because they depend on having a wall behind them in order to reflect sound in two directions symmetrically, and a close back wall would only make things even more asymmetrical for them. Besides, in my view these types of speakers are obsolescent anyway in this age of discrete digital stereo surround channels. For more discussion on this topic, read through the following:
http://forum.ascendacoustics.com/showthread.php?5156-Any-chance-we-see-some-Ascend-surround-Bipole-Dipole-speakersQuote:
bigblockhead
one more thing what would work better with the 340's Denon 1913 0r the 890?
I don't see much of a difference regarding how they would handle the speakers. You may want to consider the 1713, if it has all of the features that you need, because it has a better version of Audyssey than either of those.
