Originally Posted by
theficus
I know on the Mac there's a program called Virtual D-VHS that will communicate the streams over firewire to a TV. I wouldn't be surprised if there's a solution for Linux or Windows, but you can't just hook it up and expect it to work, you have to have some software that will handle the communications over IEEE1394. Hope this helps!
Hi, thanks for the reply-
I can config mythtv to use firewire as an input, config the node and port- it just seems like there isn't anything coming over the wire.
plugreport 'sees' a device on node 0 using broadcast channel=63
I've set the TV tuner to a digital station and config'd it to use 'passthrough'
from command line I execute:
test-mpeg2 > test.tl
without error. however the file produced is 0k.
This is the process used for getting the firewire digital mpeg2 data from an STB into myth. I just can't prove that the TV is sending
anything out via the firewire. pressing the i.link button on the remote gives 'no i.link model available'.
has anyone gotten a linux box to talk to this TV? Or vice versa? Any tips are appreciated.
