The problem is the C-50 is a far worse center than your RC-30 towers. The tweeters are better in the RC series. You need to step up to the RC-LCR. I sincerely doubt you'll have the same issues with a much better center.
The problem with running a phantom center is that you need to sit in the sweet spot for best results. If you're sitting off axis to the sides the center channel imaging wont work as well. Try it yourself, sit where your other guest may sit and see how it sounds. If you think its fine from everywhere in the room then maybe you don't need a center speaker.
I ordered the RC-30s from Vann's yesterday. I'm probably crazy, since I LOVE the RC-10s, but the price was crazy low and I couldn't pass it up. I'll have 3 across the front in my secondary system, keeping 2 RC-10s for rear surround duties.
