Originally Posted by Cnemie
I just ordered a set of RC-10s to replace my Take Classic L/R fronts. My next question is about the center channel. I have serious space limitations, and I need some input.
I have a recessed niche with a 36 inch high built-in base cabinet (with a solid front and no open spaces), and a built in shelf above measuring about 71 inches high. The LCD sits on the base cabinet with about 2 inches of space between the top of the LCD and the shelf. This means I am terribly limited in what I can do with a center channel below the LCD. I have about 5 inches of space without blocking the screen.
I see two possible set-ups. I can use an RC-Mini center channel and place it below the LCD and be done with it, or I can use an RC-LRC and place it above the LCD on the shelf at 71 inches high and angle it down to the seating position. The seating position is about 12 feet away.
Anybody have any experience with these set-ups and how well will each of them work out? I cannot afford the trial and error method.
I had the same issue sort of issue with my tv over my mantle. Very little space between the mantel and the bottom of the tv. I have RC-10's in my living room with a RC-Micro Center Channel and it sounds surprisingly well. The RC-Micro centers are hard to find separate from the 5.1 package but you can find them on ebay every once in a while. I paid $50 for mine. I've seen them go for $80 as well. My brother and I both found them. Just keep checking ebay. I also have the RC-LCR in my basement and it's an awesome center but you pay for it and it's bulky to mount on a wall. Either way, I don't think you can go wrong.
