Originally Posted by HeLLSpiRE
I would be using the Emotiva for both. I think I used the wrong term but I intend to use my current Onkyo as a procressor strictly. I'll take the 2.2i's into consideration but depending on the price difference between them and the 2.4i's, I might get the 2.4s instead as I do listen to quite a bit of music too.
As for the sub suggestions, I would need to find Canadian stores that sell them, right now i have contacts at two stores that carry Velodyne and Energy hence I would be able to get them a tad cheaper although I find Velodyne prices are hard to swallow
I'll check again tonight at the cost of the 12".
My room size I beleive I would say is roughly 15x30-40
I'll check again tonight at the cost of the 12".My room size I beleive I would say is roughly 15x30-40
If you are going to use your receiver as process then you need an amplifier to take the amplification for the channels. There are a lot of good amplifier options.
If you want to go with 2.4i's for music that is a good idea. But I would recommend going with a different preamplifier than the emotiva.
I would get a dedicated 2 channel preamplifier with HT bypass. That way you get a good 2 channel side and still use a receiver as the processor for the HT side. It works great. I have a Cary SLP 2002 tube preamplifier with HT bypass and this was the best thing I've got for getting the sound quality I want out of my system.
Considering you are buying veritas, I side with Warpdrive and say that the energy sub isn't worth pairing to veritas gear as there is much better out there. Energy subs won't hold a candle to decent boutique manufacturers of subs like SVS and HSU. Velodyne make some great subs but they are pricey as you mentioned. Paradigm Servo's are good and made in Canada, but a little pricey compared to SVS. SVS is now distributed in Canada. Check out sonic boom audio. You can't go wrong with them. They offer huge quality and bang for the buck. But getting reference level quality bass isn't overly cheap. But it is a lot cheaper than it was a couple of years ago.
That is a huge room. I'd recommend getting two PB13 ultra's or something capable of that kind of output in order to get to reference SPL bass. A properly sized sub (generally subs) in HT can make the HT experience unforgettable. IMO, it is probably the most important piece of the HT puzzle.
Good luck.....
kw.........
