AVS › AVS Forum › Audio › Speakers › Energy Owners Thread
Energy Owners Thread - Page 1214
post #36391 of 47782
Originally Posted by mphfrom77 View Post
Again, congrats caper. What kind of amp is it / how strong? How much $ you got in your diy sub?
Dayton SPA500 - 540W max into 4 ohms. Keep in mind the size of this box affects the amount of power required by the driver, and is actually a little more than is required, but I bought the parts first and changed my desgin later, to the 24" instead of 20" box.
As for my totals, I was going to do them this weekend but I guess I will try and figure it out now. I will round to the nearest $5 for ease.
  • Parts: Trio12 driver, 2 PRs, plate amp, floor spikes, and all mounting hardware: $600 including shipping and taxes.
  • Sheet of MDF: $40
  • Glue sticks: $5
  • Gorilla Glue: $5
  • Primer: $10 (See Note 1)
  • Duratex Cabinet finish: $80 with tax & shipping
  • Say $10 for shop supplies (Carpenter's Glue, wood screws, sandpaper, nylon nuts, etc)
  • Weatherstrip: $10
That's a total of : $760
I also joined the wood hobby club specifically for this, so my personal total would include:
Membership to wood hobby club: $75
My grand total: $835
Note 1 = Primer is not required. I wasn't sure how much duratex would be needed, but there is about 3/4 gal left over and it is self priming, so I could have used that instead.
post #36392 of 47782
Hey I have all towers.3 RC-70 up front. 2 C-9 for surrounds and 2 bose 701 for surround backs. I love it. I would never go back to smaller speakers.
post #36393 of 47782
Originally Posted by FieldingMelish View Post
V minis have not disappointed in any way as they make themselves aware mostly with effects sounds and I am not distracted as though hearing a different tone than I thought it should be
Right now I put my CB-20s as surrounds instead of my CB-10s. I did not make before/after comparisons but listening to 5.1 sources, I didn't notice much difference acoustically. Esthetically though, the CB-20s look huge on bookshelves. I think I'd like smaller bookshelves. The RC-10s at least look smaller than the CB-20s even if they're actually a tad taller; but they're much slimmer.
So yeah maybe a pair of V-Minis could be interesting. The standard price in Canada (at FutureShop) is 250; not sure how low they go. That could be significantly cheaper than the RC-10s, available in Canada for a long time, etc. So it's definitely worth considering. Are they closer to the CB-10 in size or more CB-5 size?
btw, my setup is 5.1; my room shape and dimensions is not applicable to any more speakers than this. I don't have the height for height speakers as well.
Same thing here. I could probably put heights or wides but the WAF would be low on this -- the living room is sufficently cluttered as it is now. The problem for surround backs was that my couch was up against a bay window. But I managed to find a solution. I had two older, unknown quality bookshelves laying around. I decided to try them behind the couch, firing up. I find the end result excellent as the sound is reflected multiple times by the couch, wall and bay window, resulting in a very diffuse sound. Exactly what we're looking for in surrounds. They blend in very well with the surround sides; in 5.1 sources both sides and backs are sent the same content and the effect is very enveloping. In 7.1 sources (e.g. PS3 games), the content sent to surround sides and back is continually changing and the continuity is good. So if you have a foot of clearance behind your couch, this could be a valid solution for a 7.1 setup. I just don't thing this would be worth doing with expensive speakers though.
Interesting datapoint The voice of reason is generally well counter-balanced in this thread! So do you listen mostly to multi-channel music on that setup or do you find it improves movies / games significantly as well?
post #36394 of 47782
Consider this for heights or surround back:
post #36395 of 47782
Hey All - As promised, I have attached some pics of my v6.3 surround setup for you. I use the grills on them, but I took them off for the pictures (except for the first pic) so you can see more of the speaker.
Attachment 234777
Attachment 234778
Attachment 234779
Attachment 234781
Attachment 234782
post #36396 of 47782
Next step is to enjoy them!! Those are great speakers. Can't believe you were able to resit using them and have them sitting around They should shine on good music (the higher quality the better). For music you should just play in 2 ch mode and make sure they are playing full range and not using the sub.
Originally Posted by masterkaj View Post
Hey guys, I just installed some v1.8 towers to my onkyo 608, they are bi-amped and set at 80hz crossover and it sounded pretty good. I have had these speakers sitting around for a while and finally was convinced that the 608 could handle them, albeit not at all optimal.
My question is, what should my next step be? Upgrade to a more powerful receiver or will I have to use the preouts and get an external amp? Right now my receiver doesn't have preouts, so I will have to upgrade receivers either way. Any recommendations from fellow v1.8 owners?
As of now I am in 5.1 for HT use mostly, I do listen to music occasionally though.
post #36397 of 47782
Drool !
post #36398 of 47782
Attachment 234777
Attachment 234778
Attachment 234779
Attachment 234781
Attachment 234782
I'm envious!!!
post #36399 of 47782
Hello Energy fam. I love you guys.
Now. I'm looking to complete my audio upgrade, spanning 11/2010 through some time in 02/2012. It all ends on a stereo (2.1) pair in my guest room.
My question: How relevant is Audyssey in a small room that houses a 2.1 set? I am adamant about not filling up the room with speakers--it's going to be the only major room in my home without black boxes in every direction. I want to think that a simple, quality stereo receiver (with a dedicated subwoofer out) is the best choice. However, as you all know, it's nearly impossible to find a stereo receiver that has any built-in room correction.
So it's a conundrum. Do I spend an additional $300 on an above-entry-level, multichannel AVR-type receiver that has pre-amp out, or save my pennies on a basic but quality stereo amp? The stereo amp I'm looking at has all the network and other connectivity features that make modern AVRs so convenient. But no Audyssey. What do you guys think?
I know this really belongs in the Amplifiers section but that's a side of the site that I've not really explored, and I could take literally weeks scouring the threads for the info I'm trying to find. So I figured... since we's family and all...
post #36400 of 47782
masterkaj,
Hank has been extolling the virtues of the 1.8's for a while now, so any advice from him for you should be golden.
Your 608 should be fine for general listening, but if you want to get the most out of the 1.8's, you should at least consider getting a higher end receiver. I think the Denon 4311 and Onkyo 3009 or 5009 are well liked. I think Hank drives his 1.8's with a Luxman M-117 and an older Luxman pre-amp. Going with discretes is probably going to let you get the max out of those speakers. If you search a little bit, you will see a lot of the advice Hank has given to new 1.8 owners. The other consideration that Hank has noted is the fact that these speakers need a lot of room, around 4 ft or so. Don't place them close to walls.
post #36401 of 47782
Originally Posted by jjl4004 View Post
I think the RC-10s are acutally too laid back and kind of muddy or congested while playing certain types of music.
Originally Posted by deano86 View Post
I totally get that you think the RC-10s might be too laid back for your taste, but describing their sound as sometimes being muddy and congested; they definitely are not....
I actually agree with jjl, and said as much when I discussed my experience with the V2.1's vs the RC-10's.
I don't think he was knocking the RC-10's, they are not muddy speakers, but they definitely can struggle to maintain that sense of clarity and separation with "complex" or "busy" rock type music. They are wonderful speakers but they aren't perfect, and to me that's their biggest flaw. Perhaps it's the 2-way design, the amount of bass output from the small enclosure size, the crossover design... who knows?
Personally, I do NOT think they are too laid back, I love a laid back speaker... but when you hear them a/b with a speaker that is even more transparent, it's pretty obvious. You can have a speaker that is as laid back but has even better clarity, transparency, etc. There is a "thickness" to the RC-10 sound that sounds absolutely luscious with acoustic music, jazz, female vocals, etc.... but to my ears gets a little TOO thick with the complex rockin' loud passages.
So anyway, I don't think it's an insult to them to point out their one major weakness I think we can all agree that the sound quality they deliver at the price point is fabulous (especially at the $300 sale price) and also that someone who prefers a speaker with "sparkle" may like something else better. Compare that review the one dude did with V5.1, Ascend Sierra, etc.... he clearly has a taste for clear, detailed, bright treble and he hated the RC-10's but loved the 5.1's.
post #36402 of 47782
awesome!
can you talk about the C-9's vs. the RC-70's? not many people have had the flagship model of both lineups in the same room to compare.
post #36403 of 47782
Audyssey can still very much help a 2.1 setup but it's certainly not as vital... without it you are basically hoping that the room + speakers interact well and sound good, which may mean futzing with acoustics and/or trying different speakers until you find a pair that works with the room.
But to me the more important question is how much CRITICAL listening will you be doing in this room? If it's just low-to-moderate volume background music type stuff while you are chilling on the room, I'd just get a cheap stereo receiver. If you are looking to make this your "dedicated" 2ch room, where you can sit there with a glass of wine and close your eyes and really LISTEN to music, then things are a bit different.
The one thing is that electronic room correction isn't a cure-all, and especially with a 2ch setup you can work on room treatments to get excellent results. If this will be your "critical listening" room and you want to make it into a project, it might instead make sense to invest $300 in something like OmniMic, and then start measuring things yourself. Then you would have a new project to keep you busy, trying to perfect the acoustics of your guest room
post #36404 of 47782
Thanks for your quick reply, Bats I'm still pretty green and I've never really gotten my hands dirty with manual config, but I want to think that a product like OmniMic is to be used alongside an equalizer. Pardon my ignorance: I don't see... equalizer function... included in the list of the item's features. Is it not listed because (manual) digital EQ is always there? Is there a chance that I could buy this and find out too late that there's no way for me to fool around with its EQ?
post #36405 of 47782
Hey guys. Just a quick question. As I mentioned earlier, I am using the onkyo nr809 receiver, which supplies 135watts per channel. With my current setup, my speakers have an RMS significantly above that (v6.3-250watts, v5.2c-200watts, v5.1-175watts) except for my surrounds (v-s-125watts). Do I need to be concerned/careful while turning up the volume of my amp? I would assume I would have to almost max out the volume for it to even be a factor, but I wasnt sure.
Is 10watts over the RMS of my 2 surrounds an issue given that it is only 10watts and they are the surrounds (not really used continuously) ? I would assume that the surrounds would be the bottleneck of most surround setups as the other speakers usually can handle much more. Any thoughts? Thanks guys!
post #36406 of 47782
Did you forget to attach something?
Thanks for the info on your sub. I assume there may have been the old canadian price hike on a few items? Any subs from your past that you can compare this one to? Enjoy.
post #36407 of 47782
zdoggz -- you don't actually use the maximum rated power at all times, it's not like you open the hose and 135 watts come pouring out. That's just a specific measurement at a specific threshold of distortion. Most of the time you will probably be using less than 10 watts per channel.
The speaker ratings are just giving you the specs for the MAXIMUM continuous power that you can feed a speaker before it can physically break from thermal/mechanical overload. But you will never actually DO that, certainly not continuously! Just because a speaker is rated to 150W RMS, even if a particular peak in a movie soundtracks calls for a short burst of 175W, it's not like the speaker blows up. You will NEVER feed it that much power continuously (unless you were in a humongous room, which you aren't).
in other words, don't worry about it. Here's the rule of thumb: if it sounds good, you aren't hurting anything.
post #36408 of 47782
first off, who says you have to get THAT product? Personally I would not pay for network features in a stereo receiver, there are so many other devices you can add that can provide the network functions you want, and receiver implementations of network features often suck. Stereo receiver tech hasn't changed much in years so they are just thinking of features to stuff in there to keep selling them... but you can find a nice, cheap stereo integrated on the used market and then add whatever you want (apple tv, ps3, DNLA blu-ray player, etc) to provide the audio / network feed.
second, you don't HAVE TO use an equalizer to accompany a measurement device. You could simply adjust room acoustics (furniture placement, speaker placement, drapes or wall treatments, and especially subwoofer placement) to see what impact the changes have. Not saying you have to go this route, but just a thought if you wanted to make it a fun project (assuming that actually sounds like fun to you ).
and you didn't answer my question: what is the PURPOSE of this setup? casual background music or critical 2ch listening room?
post #36409 of 47782
zdoggz,
Also, that 135 watts rating is most likely not measured with all channels driven. I would not be surprised if it was measured with two channels driven. Like Batpig said, it is most likely not a concern, unless you are doing a lot of listening approaching or above the reference volume.
post #36410 of 47782
Thanks. I guess my confusion came because I was thinking that if a receiver that can output 135watts per channel has its volume turned all the way up then that receiver would be continually sending 135watts of power (since the volume is maxed). That assumption didnt really make sense to me either since I knew that most of the time we dont use anywhere near that much power. So, i guess that the 135watts would be sent out if the volume was nearly maxed AND the content had certain points where it would require such power (ie huge explosions or whatever). Is that more of an accurate understanding?
Thanks for the help!
post #36411 of 47782
Originally Posted by torht View Post
zdoggz,
Oh interesting and good point. I wouldnt be surprised either if there really is no set standard/rule that needs to be followed. Every company wants to put the best numbers possible on paper to lure buyers. Gotta love when there are no real standards with rating systems! (similar to the ridiculous dynamic contrast measurments given for today's televisions)
post #36412 of 47782
there is a standard but it's loose and easy to "fudge" for marketing purposes. The spec is generally perfectly accurate when measured at the way they specify it.... but most people don't know enough to read beyond "watts per channel" and look at things like distortion, impedance, number of channels driven, etc.
post #36413 of 47782
That is basically correct. Higher volume setting equates to more wattage required to produce those volumes. If you normally listen at -15db or lower, you probably will not hear any distortion. When you are listening around 0db or higher, certain passages might cause distortion or clipping because they require more wattage than the receiver is able to supply.
post #36414 of 47782
Hm, well, I don't necessarily need those features--it just seemed like a good choice for my needs. Come to think of it, I may move my PC into that room, so some of those features could become redundant. I just really love the connectivity options in my Denon 891, and adding to them sounds like an awesome plan.
As for the purpose, I definitely aim to put together the best 2.1 listening system that I can afford on a modest budget. I'm going to deploy my barely-used VSW10, and I'll probably buy a pair of RC-70s. The room is 12x11.5, which I understand could cause some problems...?
I have two other home-theatery rooms for casual listening. These rooms are powered with receivers that use either 2EQ (bedroom) or MultEQ (living room).
post #36415 of 47782
I have my RC-50s for sale on eBay now. If anybody here is interested in them or has any questions, please shoot me a PM.
post #36416 of 47782
Forget to attach something?? You mean the one on the wall? Wires are all inside the walls where possible. The ceiling wires are now stapled up better too.
Well, I used to have HTiB. Not even worth comparing. Now I have a Monitor Audio RS-w12. very good performer for the size. Retail(ed) at $1,400. Since it is sealed, it can't dig as low as I would like. It does sound amazing for music, which is why it will compliment the RC-70's in the future.
as for price hike, I don't think so much. Everything is on the CSS website, and you get a deal if you buy everything as a package. $460 for a driver, 2 PRs and a 500W plate amp and some grill cloth seems like a pretty good deal (then add tax & shipping). The price is even lower NOW... $410.
post #36417 of 47782
zdoggz,
Hey, I just wanted to confirm that your assumption was correct. The 135watt rating is based upon 2 channels driven. Actually, all the onkyo receivers are based on 2 channels (i'm assuming most receivers are this way)
The specs of the 809 (onkyo.com)
135 W (8 ohms, 20 Hz-20 kHz, 0.08%, 2 channels driven, FTC)
post #36418 of 47782
Originally Posted by Hank Mardukous View Post
I find that there can be a level of risk from speakers that sound exciting as soon as they are first heard. From some experiences, this can wear off very quickly and then there is ear fatigue and sharpness that can almost completely take over. I'm not saying this is the case with the new Veritas, but it can be the case with other speakers. Once these kinds of speakers get past the initial brilliance and on to the sharp stage, there isn't really ever going back to the first impressions.
Great call. That's like when the honeymoon is over, lol.
post #36419 of 47782
More like the Take Classics in size.
V-minis = Dimensions: 4.72" W x 7.48" H x 5.51" D; Weight: 5 lbs.
post #36420 of 47782
Lol, just sent back my RC-10's, so we're both taking measures to get what we want.
  Back to Forum: Speakers
