AVS › AVS Forum › Audio › Speakers › Energy Owners Thread
Energy Owners Thread - Page 1410
post #42271 of 48198
Originally Posted by chi_guy50 View Post
Originally Posted by losservatore View Post
I'm sorry I'm just trying to figuring out why you didn't get the veritas,Is practicably a gift.
Lots of factors to consider besides sound, among which are cost, space, reliability, system compatibility, and aesthetics. I'm looking for the best all-around solution and the good folks here have been kind enough to provide me with much useful information and opinion.
BTW, I see that the V6.2's are still available new from an eBay reseller for $900 a pair. And WW has the V-mini-C listed for $180 and the V-5.2C for $250 (also on eBay). So the door is still open, you see--although we ARE talking two to three times the cost of my current 7.1 speaker set-up!
Okay good luck.but remember it could get to the point that you could get ignored.
post #42272 of 48198
Originally Posted by kgallerie View Post
Chi-guy.....you are right to assume that there would be a bias toward energy in an energy owners thread.....so take any thing here with a little grain of salt. Batpig (a very, very well respected member on here, you should check out his denon site if you havent yet......batpigworld.com) didnt say that the monitors are garbage, he said that he thinks they sound like garbage. So it was just his opinion on how they sound.......probably one of the many that feels they are overly bright like I was talking about earlier. Some people like that type of sound....so you might be one of them.
As for the veritas being way more expensive, the V6.2's were only $299 and the V5.2C was only $219. Thats $817 total. Less than the $9XX that you paid. But to get a sub and matching surrounds would have cost you more.
Again, good luck with the polks! We are always happy to provide input if you decide you dont like them.
Yeah, batpig has been a godsend to us over at the Denon threads; I give a lot of weight to his opinion.
And thanks again to you for all your feedback!
post #42273 of 48198
Hey Batpig.. sorry to inform you i dont know anything about your website. sorry about that...
post #42274 of 48198
here you go..... great informative website.
www.batpigworld.com
post #42275 of 48198
wow tons more reading Batpig... thanks for the link eh...
heres a question for you sorry for my ignorance...
it says for sub set up
8.If your sub has an 'Auto-on' setting on its power control, remember to turn this OFF before running MultEQ. If not, the sub might fail to 'wake up' when it is first pinged and this will throw off the calibration.
if i turn it off how is it going to work? or do they mean put it at the on position instead of auto on...?
for direct line input .. sub... where do you put the put the low pass filter at 40 or 120hz.. etc didnt mention..
i did the multq thing at these setting for the vs10 sub,, power on, volume 12oclock low pass 12 oclock .. but not much boom coming out of it when running... movie or music..
any tips?
post #42276 of 48198
yes, they mean turning it to "full on" so it is sure to be "awake", not literally turning the sub off.
if you are using the "direct" input then it doesn't matter where the LPF is set because the whole point is to bypass the filter, but regardless, as it clearly states in the setup guides you want the crossover/LPF on the sub bypassed or turned all the way up.
after running Audyssey make sure to reset speakers to "small" and make sure the crossovers are 60-80Hz or higher, otherwise not much is getting redirected to the sub (which could be while you are not hearing much boom). Also remember that "boom" isn't necessarily good, a lot of people are used to flabby, overexagerrated bass. Audyssey will flatten the bass, plus the Veritas sub is specifically a very 'clean" sub with low distortion, so it may not sound "boomy" like you think it should but it is actually more accurate.
post #42277 of 48198
Well my RC-70s are already gone (sold ),I still have 1 RC-LCR center, 2- RC-R and 2- RC-10.Any one interested just pm me.
post #42278 of 48198
My CB20's just arrived and I see that they have a 3/8" diameter-16 thread per inch threaded hole on the back. The owner's manual is practically useless as a guide of any sort. So, is there a good quality (read STRONG) wall mount that can be used to attach this thing to a wall?
Also, does Energy make any kind of floor stands to elevate these to ear height in smaller rooms??? If not, does anyone have any good websites they purchase these kinds of things from?
post #42279 of 48198
Speaker Stand for CB-10 and RC-LCR
Any recommended stand for energy CB-10 and RCLCR....thanks
post #42280 of 48198
Speakers stands are easy to find. Sanus, Pangea Audio, Wood Technology and others make stands in various heights that will fit your CB-20's. just check on Amazon.
Energy and Mirage used to make the Macromount bracket for their bookshelf speakers but they're near impossible to find now. Omnimount also makes a bracket than can hold 20lbs and uses a 3/8" 16 thread screw.
http://www.amazon.com/OmniMount-Stainless-Steel-Speaker-Mount/dp/B00013BNLQ/ref=pd_sxp_grid_pt_0_0
You can also get the Pinpoint and VideoSecu wall mounts that clamp on the side of the speakers.
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-3LH/dp/B000X9O8SI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1354159557&sr=1-2&keywords=pinpoint+am40
http://www.amazon.com/Pinpoint-AM-40B-Clamping-Bookshelf-Speaker/dp/B002UV03MW/ref=pd_cp_pc_0
post #42281 of 48198
thanks Batpig will go try these things out.. these new tech toys so much learning .. i dont even have a cell phone..
i think the audyssey made all my speakers large ... so i have to make em small... its so confusing... so i can set the cut off at 60 or 80 hz..
perhaps this is why the sub is not doing much.. thanks for helping my understanding ..
now just have to figure out the remote to get to these places quick eh..
practice ..
the 6.3s have nice base to me all by themselves.. not super punch but good punch..
definetly need listening / theater room in my basement .. which i will start chipping away at soon... just had my basement spray foamed nice and warm and dry..
floor walls ceiling power raised stage etc will make some good acoustic treatments designs.... the 6.3s are way to boomy in my living room to crank..
thanks Bat..
post #42282 of 48198
just one more question not sure where to find answer..
ok i take off lfe and main..
set to small
adjust to 80
then run audyssey again will it set the speakers back to large?
thanks
post #42283 of 48198
My denon does the same thing, always set my veritas as large not matter how I do the calibration.I have to set then manually as small.
post #42284 of 48198
well i think i got the set up basics for the sound down .. after Batpigs tips and links.. much more helpful than the 200 page manual.. thanks Bat..
yup got some good sound happening out of the sub late last night.. biggrin.gif really good sound biggrin.gif im happy camper biggrin.gif
yeah re ran the audyssey and then set speakers to small..
sub is working much better now...
played the opening scene of top gun for a test of the base and some eric clapton... most excellent..
thanks
ps i guess if you run audyssey with some port plugs and and take em out it would throw off the calculations?
post #42285 of 48198
deleted
post #42286 of 48198
instead or writing "deleted", there is actually a button to delete your post wink.gif
it's the red "X" right next to the "edit" button you pressed to write "deleted" tongue.gif
post #42287 of 48198
set to small
adjust to 80
thanks
Audyssey ignores all settings when you run it and wipes the slate clean, so you can't make the changes and the re-run Audyssey, because it will just reset the speakers back to "large". (or, actually, more accurately, the RECEIVER will reset the speakers to large based on the data provided by Audyssey. If Audyssey was in charge of this speakers would NEVER be set to "large" if you had a subwoofer.)
So AFTER you run Audyssey is when you then make some manual tweaks to the bass management, because the bass management is out of control of Audyssey and the receiver sets speakers to "large" so as not to offend buyers who have tower speakers. The important thing to remember is that the "small/large" setting is a misnomer, it's really just a "bass management ON/OFF" setting.
post #42288 of 48198
Here are some pictures of my new 7.2 Energy Veritas setup - Very happy with it
post #42289 of 48198
Nice set up
post #42290 of 48198
Was wondering what you guys think of using front wides instead of front heights? Is there a real benefit to heights over front wides if placement of speakers is no issue?
This is the gear I have to use for my HT set up downstairs.
Pioneer Elite pro-111 display
Pioneer VSX-33
Oppo-83
RC-70 fronts
RCLCR
RC-R for heights or front wides
RC-10 for side surrounds
VSW-10 x2
Also have an extra pair of RC-r's and could if needed for a better sound stage an extra pair of RC-70's
I have been using the extra set of RC-70's for 2 channel music, but also have an extra set of V6.2's I
could use for 2 channel music instead of the RC-70's I should say originally I was using the RC-70's for
side surrounds as well as fronts but replaced the sides with the RC-10's which I was fine with. Sort of
thinking out loud here would you guys use the RC-R's for front wides over the RC-70's for front wides?
Edited by baron2 - 11/29/12 at 11:27am
post #42291 of 48198
Well, first off you should move the RC-R to side surrounds and use the RC-10's for heights/wides. RC-R are much better suited for primary surround duty because of their bipole/dipole dispersion pattern.
Or better yet, if you try wides, go with the extra pair of RC70's because that would be bad ass. biggrin.gif
The height vs. wide thing really depends on the room, the processor, and your preferences. Since you have all the gear you just need to try it yourself and see what YOU like best. If you had a receiver with Audyssey DSX I would definitely say to go for wides first, but Pioneer uses their own proprietary wide/height processing so you really need to try it and see what you like.
If you really want to get crazy, since you have all those speakers, my recommendation would be to sell the Pioneer and find a Denon 4311ci (available for a bit over $1k these days) and go whole hog with a full 11ch setup. RC-70's as front L/R and wide L/R, the two pairs of RC-R's as surrounds and surround backs, and the two RC-10's as heights biggrin.gifbiggrin.gifbiggrin.gif
post #42292 of 48198
I was able to get a set of Energy Veritas 6.2's brand new since I had no luck with obtaining the RC70 or RC50's on the east coast new.
Question that I have is, I already had picked up 2 sets of brand new RC10's and a brand new RC-LCR. Am I going to have an issue with mixing a set of 6.2 Veritas with the remaining RC speakers?
I'm concerned that I made a mistake here mixing styles. Majority of my use is for movies, TV and gaming and Music is last.
post #42293 of 48198
consensus is that RC and V are not a "perfect match" but close enough that you can get away with it. Since you already have the speakers, might as well try them out and see how it goes... if you have a receiver with Audyssey MultEQ (especially XT or better) it will help a lot to smooth out any minor tonal differences.
you always have the option of selling the RC's and picking up the V center and surrounds, although obviously there will be some incremental cost penalty. But I would go ahead and try it out in the meantime and see (hear) how it goes.
post #42294 of 48198
very nice setup, but the stands doesn't look safe ,if those fall on the hard floor redface.gif.
post #42295 of 48198
Thanks appreciate it batpig
post #42296 of 48198
We already have the stands for a while used them with different speakers, they are safe in our house because we do not have small kids anymore so no problem smile.gif The speakers are at the perfect ear height.
post #42297 of 48198
nice to see this setup, I was asking for pictures of 3 front v5.2 setup like this.enjoy them...smile.gif
Edited by losservatore - 11/29/12 at 11:48am
post #42298 of 48198
VERY nice... What does the '.2' look like?
post #42299 of 48198
I see a HSU Research VTF-15H on the first picture, that will be my next purchase but in rosenut to match my rosenut veritas set up.
post #42300 of 48198
I just stood up, hit my head against the wall several times, sat back down and looked at this again. Are you kidding me!? That would be AWESOME!!! I'm not sure whether the bat or the pig came up with that, you are to be congratulated smile.gif
Thinking about this and the guy who stacked RC50's as heights on top of RC70's is like Christmas come early.
  Back to Forum: Speakers
