Originally Posted by batpig
The benefit would be if the excessive bass from the center speaker (due to physical location) causes the dialogue to become muddy and unintelligible. I plug the ports on my RC-LCR because it's less than a foot from the back wall and I found dialogue was much clearer with the ports plugged.
With ports, it's really a case-by-case thing, you have to try it both ways and see what sounds good to you. I think the "default" should be ports open (since that's the way the speaker was designed to operate) and the port plugs should be viewed as a potential solution should a problem arise.
Out of curiosity have you tried swapping the V5.2C with the dented tweeter with one of the other ones, just to make sure the tonality difference you are hearing is not simply due to the acoustic position of the speaker?
Cool, thanks. For now i'll leave it open, sounds better for me.
I have not tried that, however i will when i get home later.
