Originally Posted by wryan
I'm thinking my plan B is to use the 20lbs-rated OmniMount ceiling mounts - http://www.amazon.com/gp/product/B00006LHDV/ref=oh_details_o02_s00_i00
- and attach a piece of wood to the back of the speaker via two of the existing holes, then screwing the metal plate that comes with the kit to that piece of wood.
I have spent a couple of hours searching the forums for an answer to this, but haven't come up with anything good. There is one guy on this thread who posted in May of last year about ceiling mounting a couple of V-Minis, so I sent him a PM.
It may be easier than that... first check the thread size against the v-mini when you get the omnimount, it might match. Even if it doesn't, one reviewer at amazon used an adapter:
The product is very good, however be sure to check the thread size on the back of your speakers. Many speakers that you will find for your home will have a 1/4" - 20 mounting thread in the back of the speaker. The Omni-mount 20 lbs mounts (both wall and ceiling type) will have 3/8" - 16 threads. Personally, I used the 20 lbs mounts and added a 3/8" - 16 female to 1/4" - 20 male thread adapter (also called a standoff sometimes) in order to mount my speakers. If you are mounting wood speakers with no pre-installed threaded insert for mounting, than the thread size doesn't matter since it comes with the required parts for screwing into the back of the wood frame speaker.
