Room is about 20 ft wide by 17 ft !! Open in back to kitchen with all hardwood!! I have a Yamaha 473 receiver right now so don't have 2 sub ports !! Would say probably 300-500.00 and prefer a coupon code or deal if u have any
Energy make a good one?
The new energy subs are not going to fill that room at all. In that budget, the only thing that comes to mind is the outlaw sub (plus) when it's on sale. My advice is save up more money and get something like this http://www.powersoundaudio.com/collections/power-x/products/xs15. You have a sub, so you can use that for now until you save up more $. You can also check the used market (eBay, Craigslist, audiogon, avs classifieds). With that size room I'm thinking at least 1 15" or 2 12" subs.
The velodyne I have rocks this room like crazy on 30% gain... Do i really need a 12 or 15??? I just want a bit lower frequency and something tighter!! But this current sub rattles everything !! Edited by benca1 - 1/22/13 at 8:07pm
You can ask anybody who's upgraded from a small (8 or 10") sub to a 12 or 15" ID sub and they will all say that it goes lower and is much tighter. Instead of things rattling and the sub dancing across the room, the bigger subs will pressurize the room, making you feel the clean bass. With a pair of subs you can set the crossover higher without easy localization. In my living room I have the veritas 2.2i's crossover @ 100 and 2 seaton subM's handling the low stuff. I'm still breaking in my 5.2's. I'm thinking tomorrow ill run them with the epik legend and play with the crossover. And then Friday night run them with the subM's.
One reason budget subs rock everything is that they produce a lot of distortion in the low frequencies. When you step up to a better sounding sub, you definitely notice more refined bass effects.
That LFM-1 Plus is definitely a good sub. However, if you are happy with how much volume the Velodyne can put out, go for the SVS PB1000. It's a 10" that will have better SQ, definitely more volume than the VX-11 (in case you need it), but will go down to 20hz where you get all those nice bass effects for movies. One of the guys over on the SVS subwoofer forum reviewed it and thought it has way more output for a 10" sub than it should (and he's tried a lot of subs). There's a thread devoted to the PB1000 and the SB1000. Check it out: http://www.avsforum.com/t/1439755/new-svs-sb1000-pb1000-subwoofers
And then after you get one . . . add a second PB1000 later on
Ok I have my crossover on my yamaha avr set at 60hz for the veritas with sub wide open on crossover!!! But will need a new avr to run two subs correct ? Or should I run a y adapter on the back (avr ) sub port ??
Of course, if you buy a good sub, you won't be running the VX-11 any more. So you wouldn't need to worry about it for a while
And no. You wouldn't need to buy a new receiver. Most of the 7.2 receivers just have an internal splitter. Just by a y adapter.
Thank u so much !! I understand now sorry!! I don't mind going lm1 plus or the ex !!! I just want it to be done right !! So do I need to update the avr so it has two sub port jacks on back ?
If you can go for the Plus (and persuade the wife, because they are a little big--21.50" x 15.0" x 22.0"), get that because it is a step up from the PB1000. I have the LFM-1 EX, which is the big brother of the Plus (EX has the same driver, same amp, bigger enclosure). They do sound awesome!
One other thing in the Plus's favor. It's a downfiring sub. So no ports in the front to put food inside (lol). No exposed drivers to poke with a toy. Very child friendly.
I think that the 797 will be plenty powerful. The fact that it doesn't have modern features like HDMI and room correction says nothing about its amp quality; in fact, in an older unit like that you would expect the amp quality to be much better than a typical mid-level model nowadays. I believe that model was even THX certified, and googling the specs it looks like it was rated at 100W/ch and weighs 35lbs. I think it will have plenty of grunt to drive the 2.2's, especially in an office where presumably you won't be cranking it to insane volume levels.
No, there is no way to have a separate calibration for "B" speakers. You can configure the "B" speakers as dedicated 2ch specialists (as you know) but they will not be included as part of the main Audyssey calibration unless you actually want them active as your primary front speakers in multich modes as well. So in a way this supports the plan to move them into the office unless you want to do your primary "critical" 2ch listening in the main room.
Thanks, batpig. My main reason for hoping I could include the 2.2i's in the calibration is that they're extension doesn't quite match what [understandably] a tower, or bookshelf + sub can do.
I've put them on 2.1ch stereo with the s12.3, but it doesn't sound nearly as clean or integrated as I think it would with the calibration. If I compare, the bass sounds much tighter and refined in "pure direct" 2.0ch listening than with the s12.3...though the bass doesn't extend as far down as what the sub could do.
Any ideas, aside from pretty much making them my mains & leaving my poor APS 5+2's without a proper home?
You're definitely right, in that there is the Onkyo 797 in the other room, but that room doesn't have a sub at all, and I'm guessing they still wouldn't seem to reach down as deep as with a sub.
LASTLY...! (haha) -- here's some pics of my main room setup right now (cheap photos from phone...will have to upload some better ones sometime!).
My question here is the surround speakers. You can see that with my room dimensions / furniture layout, I've had to put the surround channels quite a bit behind the main listening spot (almost like rear surrounds might be?) -- I'm considering maybe trying to find some Veritas 2.0Ri since they're design & wall mounting might work well ... would these be a nice fit with my other speakers (right now it's the APS 5+2's for L/R, AC-300 center, and C-6 for surrounds, s12.3 for sub)?
I just wanted to get opinions. With my limited experience with bipoles (RVSS surrounds), I have somewhat liked direct radiating more for The RVSS's had great dispersion, but threw me off I could locate them 'at all'.
They by no means sound bad in the main room, but was just curious...since I know they're not necessarily positioned 'correctly' for surround speakers; I do notice a significant difference in the 'presence' of the surround channels when I jump from my main room to my office setup that has the surrounds in proper side-position.
I honestly don't know what a good price for the 2.0Ri's would be, since they're not discussed often on here. The gentleman I bought my 2.2i's from is also selling a 2.0ci , two sets of 2.0Ri's, and 2.4i mains...so I could maybe inquire if he'd be willing to sell the 2.0Ri's for a price you all find to be reasonable; he currently only has a price listed for the 2.4i's.
If I do end up getting the 2.0Ri's for surrounds, would the positioning of the C-6's be good for rear surrounds?
Thank you!
Front view
Looking back...seat you see if main listening spot.
View from behind / left of listening spot. This is entry-way into the sofa area. Not enough room for a C-6, and too close at that [for direct radiating].
View from entering room from the back-left, to get a sense of distance that the C-6's are back (only surround-right visible in pic). Edited by johnb4467 - 1/22/13 at 9:48pm
I have read threads regarding the center (2.0ci) not being as good or not matching. I disagree. I have tested many centers in a previous setup. I like the sounds of the center, produces very nice voices. Also, the speaker blends in fine.
The 2.0Ri's are good as well. Especially for the money that you find them sometimes these days.
BTW. I am using currently a Yamaha to drive the setup. I liked the sound of the Yamaha. I was going to get a new one. However, the newer ones are bigger in size (depth). This would cause an issue for me with the space constraints in my cabinet.
Does your Yamaha have pre-outs? If you like your Yamaha & don't feel a huge need for some of the new goodies like XT32, etc...you could maybe just add-in an amp (like I think you mentioned?) if you have the pre-outs.
While those Marantz's are very nice I would STRONGLY recommend (as batt50 noted) that you get a receiver with MultEQ XT32. Both those Marantz models "only" have MultEQ XT. Those speakers are so nice that they deserve the best.
Those Marantz are also just rebadged Denons, the 7xxx Marantz is the same as the Denon 33xx on the inside. I have heard the Marantz 7005 and the Denon 4311 and Onkyo 3008 back-to-back with the same system, and the XT32 definitely makes a difference. If you can find a Denon 4311 floating around on closeout pricing I would do it, check at local Best Buys and/or call around to authorized internet dealers.
The Denon 4311 seems like a perfect choice. I might running into an issue with my second constraint: depth space in my cabinet. I am already pushing it with my RX-V2400 receiver. The Denon seems a bit deeper.
I am now interested to check with my meter. Have you played some low tones? Quite impressive.
I think the specs for the RC-70s were 34 Hz, not 31. However the exact conditions were never specified, and it's not even clear if that was supposed to be a -3 dB point. I think the only credible measurement of the RC-70's frequency response is found at Home Theater (see the purple trace).
Those are close-mic, quasi-anechoic measurements. They show a peak for the RC-70s at 100 Hz and it goes down rather fast from there. The +/- 3dB band would be breached at 68 Hz according to those measurements, i.e. 68 Hz is already down 6 dB from the 100 Hz peak. Below that, response falls even faster.
The RC-70s have pretty good upper bass (lots of output at 100 Hz) but I don't think I'd use a crossover below 80 Hz with those. I'm lucky enough to use dual subs that sound best on the front stage (just inside the mains), so that I can use a higher crossover frequency without having localizable bass (or anyway it gets localized at the center so it's not much of a problem). I'm currently using 100 Hz as a crossover but wonder if I should set it even higher, considering I have ample subwoofage.
I've been impressed with the RC70's as far as soundstage and imaging. Have you tried running Audyssey/YPAO or whatever your receiver has?
I have messed with switching between 7.2 and 2.2 and I had to get up and check to see if the center speaker was on or not. What else do you have experience with that you are disappointed in the speakers?
I'm running them with an Onkyo 506 (I think, lol) in Direct mode. It's just a 2.0 system as I'm much more a music guy than a movies guy.
Recently I listened to a pair of Tannoy Gold Monitor 15's from the 60s. Driven with old Mac tube amps. Wow, soundstage was unreal. I know it's not a fair comparison, but I was hoping that the Energy's would be maybe 80% of the Tannoy's.
I do
I don't have the RC-70's, or any Energy speaker except for my sub lol. I will say with my towers, towing them in directly towards my seating position made a HUGE difference.
They're currently placed about 6 feet apart, toed in about 10 degrees and 1 foot away from the walls. I very tempted to get a centre just to improve my centre imaging.
