AVS › AVS Forum › Audio › Speakers › Energy Owners Thread
Energy Owners Thread - Page 1547
post #46381 of 51590
Originally Posted by audit13 View Post
Personally, I am not a fan of using direct-radiating speakers at or near ear-level as surrounds. I had RC-30s and Thiel floor-standers as surrounds and they were okay. I then replaced those with wall-mounted Energy di-pole surrounds (can't remember the model number but I bought them off Craigslist for $60). I then tried Mirage OMD-5s and settled on the VS running in di-pole, wall-mounted above ear level.
Oh. Never tried it but I thought for the bass on the rc70s would be good. I guess a second sub would do that. My vminis will be up over ear level just below the ceiling as fill ins.
Edited by eah9 - 3/31/13 at 8:37am
post #46382 of 51590
Originally Posted by caper_1 View Post
Speaking of these, I was thinking about maybe buying a pair, and sanding and refinishing them to match my room. I am just finishing laying hardwood, paint, and trim everywhere, and black-ash will not match anything in the room. I wondering how hard it would be to remove all the drivers, plug the holes, and sand and refinish them. For $350 a pop, it is a crazy good deal. Does anyone know what wood is under that black ash ? Is it wood or MDF ?
ANYONE !?
post #46383 of 51590
its black ash veneer on top of MDF.
pretty much all speakers are MDF. Most will put a vinyl finish on top but RC series uses a real wood veneer.
How hard will it be for you to refinish your speakers? Depends on your skill level.
Edited by afrogt - 3/31/13 at 11:41am
post #46384 of 51590
Hmmm. Not going to try veneer on them as a first attempt. I would stain and spray varnish them if they were wood, or even spray-paint something similar to the room (espresso). I can spray really well without leaving drips/runs.
I assume the drivers are all easy to remove, but what about the magnets for the grills? Mask them maybe? Hmmmm. Found some espresso spray paint, then I could gloss finish them...
post #46385 of 51590
Anyone have a pair of Energy VS's in good shape they want to sell?
post #46386 of 51590
If you remove the drivers, can you re-use the same screw holes when re-installing the drivers? I've never taken one apart.
post #46387 of 51590
Baron2,
I dont know if you noticed, but Acoustic Sound Design has the VS Surrounds NIB for $275 ea. It appears according to amazon inventory engine that they have 50 / or 25 pairs. Not sure if thats out of your range, but there it is anyways. ASD quiety posted some inventory on amazon over the last week>
They also have V-minis for $149.00 ea.
V5.1s for 249.00 ea.
V6.3 Rosenuts for 799.00
Energy Veritas V-S 3-Way Surround Speaker Piano Black$275.00 Quantity: 50 Change Sold by: AcousticSoundDesign Home Theater Experts Gift options not available.
post #46388 of 51590
Originally Posted by nc88keyz View Post
Baron2,
That's a good price for the V-S Surrounds. Much more reasonable than some prices I have seen.
post #46389 of 51590
yes, people have replaced drivers in their RC speakers before.you would use the same screw holes. Actually folks have take apart the speakers just to see how they were built.
post #46390 of 51590
Baron2,
Just checked their website no VS surrounds will check through amazon, thanks
post #46391 of 51590
I would not take the drivers out ever........unless you have to. I had to once to determine if it was a bad bass driver........but it ended up being a bad crossover...........
The drivers are mounted sooooo tight that they do not want to come out.......and you risk damaging the finnish........around the edges of the driver............like peaces break off !!!
post #46392 of 51590
I hear you there. A xacto or utility knife around the mounting surface first, to loosen the finish before popping it off. Even if I did splinter it a bit, a little fill and sandpaper before refinishing them would do the trick anyway. I am so stuck right now. The savings alone in refinishing some 70's over buying 6.3's just for the "look" is insane. Even Martin Logan Montion 40's are almost 1,100 a pop.
post #46393 of 51590
I was able to find this: http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=4065&sc=65
Amazon link: http://www.amazon.com/gp/offer-listing/B005C2QW8K/ref=dp_olp_0?ie=UTF8&condition=all
Edited by audit13 - 3/31/13 at 3:00pm
post #46394 of 51590
painting over wood veneer is a really bad idea, a option is if you have a really good skills with wood ,remove the veneer and replace it for another one.
post #46395 of 51590
Just got an email from Acoustic Sound Design pointing me in the direction to purchase from them.
Also found a 15% off promo code that works so the total for a pair of the VS surrounds are 467.50
with free shipping. I never followed Vanns pricing on these, any of you think this is a good price for these?
post #46396 of 51590
I also am debating with my cortex layer.....(and hoping there are no apes nearby with any ideas) ...........about snagging two more RC-70's.......I'm in Canada and have some held for pickup at FS. I already have 2 RC 70's as mains on my main setup............Paradigm LCR 450 center...........RC 50's are my rears.......Paradigm Servo 15 sub. But I may want another set of RC 70's for my 2 channel system....I pulled out my DENON PMA-2000IVR amp and am currently listening to it with the 70's and various cd and SACD's...............from the analog outputs of my Oppo 103..........sounds absolutely outstanding.
It really is not much money for such speakers.........have not decided yet..........but did want a really good set for my two channel system (I do have Paradigm Studio 20 V1's that I was going to use but a tower might be nicer......might use the 20's for some surroung channels).
post #46397 of 51590
Mike as ASD is not selling them on is site, More than likely because of the "TV15" code which applies 15%. off.
I noticed this too, only on amazon for the time being, also not on ASD, ebay store.
Correction: He wasn't selling them on is site, not he is. Great to be able to apply coupon .
post #46398 of 51590
I'm sort of in the same boat. I have an unused Marantz receiver sitting in the closet and purchased a cheap pair of Pioneer towers based on many the excellent reviews I read. Now, I'm tempted to get the RC-70s from FS. The Pioneers were only $180 CAD a pair. I must admit the Pioneers sound really detailed, especially in the midrange but they could use a sub. With the RC-70s, no sub required. If I got the RC-70s, what to do with the Pioneers:o
post #46399 of 51590
not bad for a discontinued and really hard to found product you should go for it, did you ask how many they have in stock that could be just a pair ,also I think they are a authorized dealer, 5 years of warranty.
post #46400 of 51590
$369 for a pair seems aweful familiar last year around july / august time frame from Vanns. I could look at my statement, I had returned a pair of VS surrounds.
542021944 Energy VS SURROUND SPEAKER $179.88
Price paid 07/23/12 each
Edited by nc88keyz - 3/31/13 at 3:11pm
post #46401 of 51590
Just curious on that pricing. Buying from Vanns had its advantages, they seemed really good with their pricing. $467.50 for these from ASD seems reasonable with the
free shipping. Not sure what the used market value is for these.
post #46402 of 51590
They are an authorized dealer and if they arrive damage they replace with no return shipping on my part. Sounds good
post #46403 of 51590
according to amazon , 50 or 48 if Baron2, just purchased a set. But you could always just log in to the website, Mike loves to chat.
post #46404 of 51590
For a very short time, they were $149 each, but towards the end they were $179 for quite a while. I have a pair that I was trying to sell (where were you???), but zero interest so I jumped on three of the V5.2C speakers so I would at least have a 5 channel set.
post #46405 of 51590
Washington State.
post #46406 of 51590
Mike from ASD said he has 62 pairs arriving on Wednesday and then thats it for the Veritas line.
post #46407 of 51590
Perhaps a energy owners AVS discount code is in order?
BTW
doesnt look like the V5.1 qualifies for the 15% discount "TV15" code.
Its the only one im seeing that doesnt so far.
post #46408 of 51590
Washington State.
What I meant was, where were you when I was trying to sell them.
post #46409 of 51590
I was right here with my head in the sand. LOL I think at that time I wasnt sure if I wanted to make a 7. veritas system.
post #46410 of 51590
This was also around the time that Vanns was in the process of filing for bankruptcy.
  Back to Forum: Speakers
