I have 106" diag for PAE900U projector. I have stretched blackout cloth over a wooden frame then sprayed it with Goo Systems Screen Goo. There are two coats of basecoat and two coats of the silver/grayish topcoat. The screen LOOKED awesome!! Now, after three weeks the screen material is starting to sag a bit. I need to pop off the trim and kind of give it a face lift.
I am wondering if my restretching of the fabric will cause any cracking in the Screen Goo? Any body have experience with this issue?
BTW, just a friendly tip. Do not store and assemble your DIY screen in 30 degree weather and then expect the screen material to be as "tight" when you mount your screen in a 75 degree home.
Thanks all
Dave
Thanks all
Dave
