AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › BenQ 8720 Hints & Tips
post #1 of 813
Having almost 200 hours in my 8720, I thought it would be a good idea to provide some tips for this pj (since some of you might consider buying it after the price-drop )
1) During the first 10 hours you might experience some image noise. It is related to the lamp and it will go away after that time.
2) If you want to enter the service menu, all I have to say that the procedure is the same with the BenQ 7700 (I am not sure if it is ok to disclose the key combination)
3) In any case, it is ESSENTIAL to enter the secret menu in order to fully enjoy this pj in its full glory, because for a strange reason the Benq technicians have set the overscan rate at 93% instead of 100%! This is even worse with this pj because if the 8720 is not at 100% then you do NOT have 1:1 pixel maping! So, you just have to enter service menu, then select:video signal, overscan rate where you have to set it to 100.
4) If you want to calibrate it by using the user menu gamma settings, first of all you have to select normal preset, because user1 and user2 preset do not allow to save any changes made to gamma settings!
5) If you want to playback PAL material and you own an OPPO dvd player, bad luck! They don't like each other!
6) Through HDMI, this projector only operates at 7,5 IRE. So if you want not to have crushed blacks and whites, you have to set your DVD player at 7,5 as well.
No problems connecting with HTPC's.
7) In my setup I prefer to have the lamp at full (250W) and the iris set at 24/38. This way I can have a very punchy imaqe with great blacks and more than enough light.Of course I had it D65 calibrated.
As you can see, most of the above issues are firmware related (my unit has the first firmware edition). As long as it may take for BenQ to release a new firmware with this problems solved, I suspect that the 8720 might find my tips helpful!
I just hope that someone from BenQ is reading..
PS This PJ is the best single-chip 720p I have ever experienced!
post #2 of 813
What was the key combination for the 7700??
post #3 of 813
Thanks Takisot
Thankyou very much for the info.
Ben
post #4 of 813
Ben, you are welcome!
Willbur, as I said I am not confortable disclosing such info, but I am sure you will find it easily in this forum.
post #5 of 813
Hi!
what ansi lumens did you measure or is it bright ? i like this machine a lot (dont have one yet). i find the 7700 punchy in brigthness, is the 8720 also ?
the motorized lens zoom focus is also a real ++
post #6 of 813
It is very bright (as 7700) but it has the iris to "control the beast"!
post #7 of 813
Hello Takisot
Is there a way to check what firmware version a pj will have (8720)
Ben
post #8 of 813
I believe it is noted somewhere in the service menu. I will try to find mine as well..
post #9 of 813
My demo PE8720 will be here tomorrow. I ordered it directly from BenQ to get the latest and greatest firmware. I have spoken to my rep and a technician and the new firmware is supposed to fix any and all oddities, color balance and gamma issues with the PJ. They stated they have tried to make the 8720 as close to perfect as they can get right out of the box. As with any PJ, manufacturing variances will prevent perfection on each unit so I will calibrate the PJ fully and report back. I will check on all the things takisot mentions and see if the firmware update has repaired them. If you have an older unit, I would contact BenQ to get the update. From my conversations, it sounds as if it can be loaded in the field by the end user but I did not ask or verify this. Also, the update review is up on projector reviews.
post #10 of 813
Greetings all,
I'm surprised this is such a quiet thread (less than 300 posts).
I see Eric (awtryau89) has one coming in. He should be impressed. I reviewed an almost production 8720 just about the time they started shipping and found the projector to be exceptionally sharp, but having serious gamma problems. (You can find the review and images on my site).
I had the opportunity to work with BenQ engineers in the US (they are 15 miles from me) and by conference call, with Taiwan, especially relating to the high gamma numbers and some minor things. A couple of days before new years, they invited me up to pick up the latest firmware, and met with them just last week at BenQ's US HQ.
I am pleased to report that the newest version, is awesome. The gamma is now very good, and some other changes, less critical are also visible. I find this now to be a finished product, with performance in many ways comparable to the highly regarded Marantz VP12S4, which sells for $14.5K.
In fact the BenQ does better on shadow detail (the marantz better on highlight detail).
But the bottom line, they got it right.
Check out the review on my site. It consists of a new update page, the original pages (overview, image quality, performance, warranty), and an updated Summary Pros Cons page.
A slightly strange way to do it, but I just didn't have the time to rewrite the whole thing.
PS. I bought the sucker! It's being installed tomorrow. I was going to (go with Optoma's H78DC3, but the BenQ is significantly sharper, and I sit close to my 128" screen.
Good luck.
PS. There is no gamma adjust to my knowledge on the US version user menus. I saw a thread indicating there was on Takisot's comments above. -art
post #11 of 813
The 8720 is on my short list but as I'll be using it in both a light controlled room (for movies) and with ambient light (everything else), actual D65-calibrated light output is important to me.
Has anyone measured light output and on/off contrast with the iris in its most closed position? How about lumens and contrast with iris open?
You mention that the 8720 is as bright as the 7700 but I only find one measurement of the 7700 which is 350 lumens @ D65 in low power lamp mode. Is this what the 8720 puts out with iris fully open?
post #12 of 813
Hi Art!
In all 8720's I have seen in Greece (4 in total) , there is a Gamma & Color Temp section in the service menu. Can you tell me your firmware version?
Even with the first firmware version, we were able to obtain an almost perfect gamma response in all IRE during calibration and by using the Home theater mode as a starting point.
post #13 of 813
Lungan, I do not have any measurments numbers, but I can assure you that it has PLENTY of brightness even when it is D65 calibrated! That's why I choose to have the IRIS at 24/38 to maintain a very good black level.
post #14 of 813
Got the 8720 in today and just finished getting it hung. Unfortunately BenQ shipped me a unit with the August firmware. I am already working on obtaining new firmware but after speaking with my rep, most all issues corrected in the new firmware can be solved with a good calibration in the service menu as takisot mentions. I still plan on trying to update it though.
Initial impressions are this thing is bright. Much brighter and sharper than the Panasonic AE900, Sony Ruby and JVC HX-1 which I have all had in my room lately. I even have the iris closed down to about 26/38 and lamp on low (200watt). I am using a 110" diag Da-Lite HCCV screen and was thinking of a High Power but that is out of the question with this PJ. I value my retinas and think I would burn them. Color balance looks decent in Cinema Mode and Normal color temp. I will let everything settle in and calibrate this thing over the weekend. I am expecting some great results.
post #15 of 813
Originally Posted by awtryau89 View Post
Initial impressions are this thing is bright. Much brighter and sharper than the Panasonic AE900, Sony Ruby and JVC HX-1 which I have all had in my room lately. .
Oh my god!
God help us if TRYG sees this. You know how he feels about the Ruby/sxrd.
I havent seen the Ruby yet and dont plan too. There is no point going goo goo ga ga over something that is not suitable for your set up. But I do agree that the Benq is quite bright and sharp image. This will help offset the slightly softening on my Prismasonic H1200r lens.
Ben
post #16 of 813
How does one know if they have the latest firmware?
post #17 of 813
Thanks takisot!
I'm not really concerned that it won't be bright enough if I open up the iris, I just want to know if it's bright enough to use with the iris closed. Since I'm quite happy with my current black level it would also be nice to know the actual contrast with the iris closed.
Is motion blur/panning artifacts visibly reduced if you switch to Whisper Mode and 4x colour wheel speed?
post #18 of 813
Lungan, I do not use whisper mode, as this pj is already vey quiet, and also it only operates in 200W when in whisper mode. I prefer 250W with the iris semi-closed.This way the picture is punchier and the blacks are great!
post #19 of 813
You have to enter the service menu.
BTW, mine is:
TWN RM 103 1.04
Aug 12, 2005
MCU version 0.4
post #20 of 813
BenQ, MUST release the new firmware ASAP for all 8720 owners with the previous version, because there is not only the gamma issue but a lot more as I mentioned in my first post!
post #21 of 813
takisot, what screen size and material (gain) do you use?
post #22 of 813
I use a ScreenLine Othello 110' at 1,2 gain.
post #23 of 813
Well I spent most of my day with the 8720 yesterday and I get more impressed the more time I have with it.
First of all, I am very impressed with BenQ customer service. I made a phone call once receiving my unit to them about the firmware issue. Before days end, I had 2 return phone calls with apologies and trying to work out solutions. Unfortunately I was locked up with the PJ so I missed them and was not able to resolve the issue. I will call them back today and see what we can do. I know one call had a RMA for me to return this PJ and another with the new firmware would be overnighted to me. I am still not sure I will do this though. After talking to a few individuals, most of what I glean the firmware fixes are settings in the service menu which can be adjusted with a good calibration. I do know the firmware does not fix the overscan issue or user mode gamma issues takisot mentions in his first post. After talking to presenter and how the firmware was developed, I am pretty sure it is just a recalibration of the PJ for "out of the box" users. My recommendation would for most to get the new firmware if possible but I certainly would not let it stop me from acquiring one of these PJs.
Next, as far as the PQ goes, I am really settling in that this is one of the best 720p DLPs out there. Granted I have not even calibrated it yet but it is truly impressive with everything I throw at it. I have not encountered any of the issues that I thought I would. Dithering and video noise in dark scenes is not there. I have been able to induce some with some wild settings but under normal use in Cinema Mode, its just not there. I have not seen any panning artifacts with normal viewing. The color wheel is fully adjustable in the service menu and the default is 5X. Moving to 4X does not help with anything I could see but that was with limited testing. I did not try 6X with anything. I will be glad to try anyone's torture tests and reply back if they like. Gamma is fully adjustable in the service menu along with the other controls for RGB. You also have completely different settings for each input which allows the calibrator free range for all inputs. I will try to post some good measurements once I get this thing calibrated. Again I am impressed. If you are looking at a 720p DLP you need to take a look at the 8720. IMO it is considerably ahead of any of the new LCDs and a good step beyond the current low priced DLPs to include the Mits HC-3000 which I sell and have had in my room. It is worth the price difference.
post #24 of 813
I do know the firmware does not fix the overscan issue or user mode gamma issues takisot mentions in his first post. After talking to presenter and how the firmware was developed, I am pretty sure it is just a recalibration of the PJ for "out of the box" users. .
Thanks for your report!
Can anyone (Art?) confirm the above? Does the new firmware only fix the out-of-the-box gamma?
post #25 of 813
An other idea: if indeed the only change with the new firmware is "new values" to the pj controls, then it would be helpful if someone with the new firmware could post here the new values and see what happens!
post #26 of 813
BTW, mine is:
TWN RM 103 1.04
Aug 12, 2005
MCU version 0.4
OK, but a previous post indicated that the August firmware is not the latest. One must know what the the latest firmware is before knowing whether one has it or not.
post #27 of 813
Actually my firmware might be the first, as I was one of the first to buy this pj.
I just mentioned it for reference.
post #28 of 813
Tom,
The latest firmware is 1.12 I believe. August is definitely not the latest. As for my earlier comments, I did verify that the latest firmware only changes settings in the service menu to make the PJ more "calibrated" right out of the box. There are no great advancements here and if you have already had your 8720 professionally calibrated I would think twice about loading the new firmware. It will wipe any work that was done in the service menu and replace it with the new settings.
post #29 of 813
The color wheel is fully adjustable in the service menu and the default is 5X. Moving to 4X does not help with anything I could see but that was with limited testing. I did not try 6X with anything. .
Hey Mate (awtryau89)
I noticed your post about chaging colour wheel speed in service menu. I wasnt aware that it did go to 6x. Could you confirm this. I checked the specs from Benq and it states 5x
Takisot could you also confirm this please.
Ben
post #30 of 813
PJ Central just posted a "review" of the 8720. Calibrated lumen output of 260 - 340 is pretty low for a reasonably sized screen. Hmm...
