yeah, buy can be great, amazon can be better and DELL can win over all others with % off and $$ off coupons are added. Dell as well has a great return policy.
post #91 of 112
2/6/06 at 1:14pm
Originally Posted by Expidia
Expidia says: Thx for your comments on the 880. My first cradle was finicky but my replacement cradle is just fine. I would call Logictech and ask for another one.
Nice to hear a software engineer had problems. As other have said it does have a bit of a learning curve to it. With so many issues, the thing I found most annoying was the 20-30 min wait time for me and than another 20-30 min after the first tech put me up to level II support. That was just plain wrong. I went to add one button last night, an "A" on the first screen of my DVR remote so I could delete saved shows from the DVR without having to go to another page (out of 7 pages). Once saved, it would not upload the saved program to my 880. Had to call tech support (another 20-30 min hold time). I even rebooted before I called them and it still would not upload. He had me switch to a different USB port and it started working. Simple issues like this take much of my time. Tells me the software is glitchy. But I did just order a second one for my living room HT ($176 at 6th Ave off Pricegrabber) and it should be interesting to see what happens after my initial upload with my other components once it is delivered. I hope Logitech honors their $50 rebate as my units last 4 #'s are different than the ones on the rebate form as others have pointed out or I'm out another $100 for the two units. Excruciating is an excellent choice of your words for my experience (frustrating works for me too) with the whole setup process. At least the end result, leaves us with a workable, reasonably priced ($126) unit with macros. I have not even tried the custom labeling program yet :eek: I would also agree with your ratings assessment and would give it the same #'s from my experience. |
Originally Posted by czzer
It sounds like you're still trying to use the Harmony as a device based remote. You should be adding that "delete" button to your "Watch DVR" ACTIVITY.
Also, the USB port thing is quite common. For some reason it won't work with the front USB ports of some computers. I have no idea why...I think some motherboards have a different interface between the front and back USB ports which causes issues. The front ports on my computer work fine, so I guess I'm lucky! |
Thanks Angry, now that I found the $50 rebate which brings it down to $129, for that price I'll tweak around with the Damn thing a little more. I know it can do what I originally bought it for but for $179 I was fed up with having to invest all that time to make right which should have been right after I downloaded the component codes.
I'm going to give it one more try as you and others have suggested before it goes to Ebay as soon as the replacement unit arrives. I'll report back on my success or crush it under my boot! I still say I should not have to as you say "persevere" but I'll try once more :) |
Originally Posted by stockmonkey2000
Can any of you 880 owners tell me how long it took to charge your battery the first time you took it out of the box. - Mine lights up when in the charging base, and has been there for 4 hours or so, but when I remove it from the charging base it goes dark and is unresponsive. It seems like it is not charging at all.
Originally Posted by viper69
I am guessing that if you spent one tenth the time trying to use your 880 as you do ranting here you would have the best programmed/working 880 in the world....
Originally Posted by snowjay
Sounds like the original problem I had with mine. The battery isn't making good contact and charging. If you take a piece of paper and wedge it at the bottom of the battery to push it up against the contacts it should work. I did that and then called Logitech and they sent me a whole new one. it only takes a few hours to give it a full charge.
I noticed the loose battery issue after reading the forums. However I wedged the battery with paper so that is is tight against the contacts, and it still does not charge. As soon as I take it off the cradle it dies. The battery is not even warm after sitting for hours. I think mine has a problem.
Originally Posted by jagouar
if its missing switching inputs your timings are probably too low.... there is a "power on delay" under your tv settings which will make it wait longer before processing your tv input commands.
Originally Posted by j.m.
I think you are very unlucky with your components. My 680 had no trouble handling input switching on both my Toshiba RPTV and Denon A/V receiver with no tweaking required. 20 minutes was probably pretty accurate for a workable setup. Now, it took a lot longer to tweak everything to be just how I want it, but most people would have been happy enough after the initial setup.
BTW, the Help button is not designed to and does not make any permanent adjustments to your remotes programming. As you discovered, you have to do that through the web software. I think a large part of your frustration is due to an unwillingness or inability to use some of the advanced features of the programming software. Instead, you rely very heavily on tech support to hold your hand. There is nothing wrong with that, and that is to be expected for a large portion of the users so Harmony should definitely handle that better. However, there are also a lot of other users who are willing to learn the ins and outs of the remote and software and handle things themselves. I believe this probably saves time and frustration in the long run, but it is not for everybody. |
Originally Posted by Allez
I don't think there's going to be any 'resolution' to this back and forth. Obviously some people will have problems with setting up their 880, and some people will not. I personally have had no problems setting up my 880 or the 659 before it. It certainly would be misleading to imply that everybody will have theirs set up within 20 minutes, and I guess that's what started this thread.
As I look at the comments here, the question I have to ask is: Is there a remote that we would rather have, one that can do everything and can be set up for everyone more easily? For me, the answer is no. Through the years I've bought so many remotes in search of 'THE ONE' that would allow me to get rid of the clutter on my coffee table. None of them could do that until I got my 659 (now operating my downstairs equipment). On my coffee table I now have my 880. That's it. My wife can operate it. My kids can use it. Expidia, I gather that you like what your 880 can do as well - otherwise you wouldn't have gotten two. You had problems setting yours up, and you had problems with tech support. Fair enough. Have some of us been 'lucky' enough to have our setups go smoothly, or have you (and I'm sure others) been 'unlucky' enough to have problems (twice!)? I guess it depends on how the setup went :) |
For a list price of over $200, no one should have to deal with poor customer support and a much to be desired, user unfriendly software interface.
Originally Posted by zikronix
I do wish it would type my favorite channels faster i got the inter key as low as possible on that...
