Originally Posted by AtlPaul
I realize that you asked who has the purple-ish-black but I thought I'd respond in any case. I do have the green blob, but I don't have purple-ish black. My set was professionally calibrated. I find blacks are generally as good as my prior CRT set. I run Pro mode, Warm setting, Low Noise reduction. Practically all of the other basic video settings (e.g. color, etc.) are the defaults with the exception of sharpness cut to 25 (which he measured and explained). Primarily, the service menu items are what the calibrator changed. Practially all of the advanced options are off except for Gamma Correction (low) and Advanced Iris (low) - all else Off. White balance settings are all zero because he adjusted all of that at the service menu level. Despite the blob the picture is spectacular even with very dark scenes. Hope that helps.
I'm just trying to determine if my set is somehow defective.
