Originally Posted by notanewbie
Do the different Hz make a discernable difference in Picture quality?
Not in themselves. It depends on the source format, see below.
Do you see any studdering or stairstepping when changing Hz?
No stairstepping. But you do get studdering if you choose the "wrong" refresh rate. Basically the refresh rate should fit to your source material. NTSC is usually 60Hz (or rather 59.98Hz or something like that). However, movies were originally shot in 24fps. If you have a good scaler, it can reproduce the original 24fps from the 60Hz NTSC signal. In that case you'll get the best result by connecting your scaler with 48Hz to the Panasonic. However, that won't look good at all for television stuff which is really 60fps and not 24fps. In PAL land we have everything at 50Hz. Movies are speeded up to 25fps, so 50Hz still fits for us. So we have it a bit easier here. Television and movies can be handled with just one refresh rate. It should be noted, though, that by far most people (probably something like 99%) in NTSC land watch 24fps movies in 60Hz and are used to the slight motion judder and have no problems with it at all.
Ideally, what SHOULD the Hz setting be on an NTSC plasma?
60Hz should be fine. If you can set up your devices to do either 60Hz or 48Hz, depending on the source format, then that's even better. But that's probably not absolutely necessary, except if you're a total image quality freak... :)
In the end, could you please tell me what the timing settings are for YOUR specific display? At least i will have some sort of a baseline when teweaking mine.
I only have 50Hz timings here, so that won't help you much, I guess. The default timings are not far off. You just need to play with the timings to make the screen resync once, then you probably have it right. It's not too difficult once you know how: Just take each timing parameter, write down the old setting. Then greatly change the parameter. If you see the Panasonic resync, you probably got it right. If changing this one parameter doesn't make the Pany resync, just change it back to the old value and try the next timing parameter. I don't remember which parameter I had to change. I think it was a "V" parameter, not a "H" parameter.
But first I'd suggest that you try to achieve 1:1 pixel mapping with the default parameters. It might already work for you. Who knows?
Also, why did you settle for an analog or digital connection?
Because 50Hz 1:1 pixel mapping is only possible via analog connection. And by far most of my sources are 50Hz.
Any difference in PQ that you were able to see between the two?
I've not even tried digital (I have no digital board), because I knew from these forums (and the UK forums) that digital is no go for 50Hz 1:1 pixel mapping. I've been told that with a good scaler and a good cable there's not much of a difference between analog and digital connection. Digital might be ever so slightly sharper, while some people claim you have some more noise in shadow detail when using digital. But others don't agree. Well...
Finally, do you feel the scaling is significantly imporved going through the DVDO rather than using the pannys internal scaler?
To be honest I've not really done much of a comparison, so I can't really tell. I've simply set it up with 1:1 pixel mapping and was happy with it. What I noticed is that when I was going from analog out to SDI out I got noticably better results. Also I *think* when going from the iScan Pro (which can't scale at all) to the iScan HD+ with 1:1 pixel mapping, the picture quality was noticably better. But I didn't switch back and forth, so it was just a vague impression. I hadn't had the iScan Pro running for long, so don't take me too serious here.
