The cosmetic differences are subtle dependent upon lighting and the luck of the draw with the the grain, etc. I think whatever process Dali is using to create the finish, they are getting better yields with the new finish as there were some comments about "orange peel" effect. All the speakers I owned never had this situation.
The binding posts appear to be heavier and stronger in the series 2 and the positioning is different of course. I am no binding post expert. I kind of prefer the look of the older series with the front finished the same as the balance of the speaker, rather then the piano black. I also prefer the Dali logo in black and gold, rather then silver and black on the II series. You can't really notice the difference in the photos. I always leave the covers on anyway, so that difference is not a factor for me. The new series is still a "knockout" eye turner and they all have excellent build quality and aesthetics. Sonics though is what sells speakers and with a limited amount of time listening, they are excellent monitors!!
Edit: I was cruising around Audiogon and saw a Pair of Dyn Confidence C1's that sold and there was a photo of the binding posts. It appears without a real life comparison the binding posts on the MKII's are similar or the same as the Dyn's. At least they are in good company at that level if my suspicions are correct.
