Yes.
Make sure you have the audio and video settings on your DVD player set to go through the HDMI connection to your TV. Hook up your TV audio to your reciever using the standard RCA cables to get the stereo sound and you're good to go!
Gotta love Indiana Jones Trilogy as well being played on this upconverted... Something has to hold me off until they are released on Blu-Ray...
My Samsung has this feature called Dnie which also enhances the image even further (turning it on and off to test it). This DVD player does a better job at playing SD-DVD's than my PS3...And I have the movie Phantom of the Opera in both Blu-Ray and SD-DVD and I have to tell you that there isn't that much of a difference if you use the DVP-NS75H to play it vs the Blu-Ray being played on the PS3. However when playing POTO SD-DVD on the PS3, it looks like crap since at the moment the Ps3 does not upconvert...Hopefully that is updated with firmware sometime in the future.. Hoever even if it does, I doubt it will do as good a job as the 75H....
