AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › how much 4:3 viewing can be done on a 16:9 set?
post #1 of 6
I am hoping someone will take the time to clarify some issues for me.
I have read that viewing normal 4:3 format on a 16:9 set can have adverse circumstances. Can someone explain this?
I hope to upgrade both TV (TW40X81) and DSS (Dish Network - I currently have just an antenna) at the same time for HDTV programming, but will still be viewing plenty of "legacy" TV & videos, in addition to DVD. Are there STB's that can be purchased to reformat these into 16:9/anamorphic format and eliminate problems and enhance the picture?
I have also read that on these sets with satellite reception sports are often plagued by artifacts. Again, is there a separate device that will eliminate this effect (hopefully the same one as above!!)?
Thanks much.
Nethawk
post #2 of 6
test
post #3 of 6
Thanks, but I was hoping for a little more input!
Nethawk
post #4 of 6
I watch quite a bit of 4:3 NTSC on my Pioneer 510HD and I use the whole screen via Natural Wide mode. That's what I recommend.
post #5 of 6
Some sets use a combination of stretch and cropping. For example, a 14:9 "zoom" mode which stretches horizontally, but also vertically a tiny bit for about 5% overscan.
The 14:9 aspect ratio has only half the distortion of 4:3 zoomed to 16:9. You do not lose much image! Just an amount of image similiar to overscan, at the top and bottom edges of the screen.
Mark Rejhon
www.marky.com
post #6 of 6
Nethawk: I have the big brother (TW65X81) of the set you are considering. I watch all 4:3 material using Toshiba's TheaterWide 1 mode. This mode fills the screen by stretching the outer edge slightly more than the center which drastically reduces distortion.
This thread is locked
