Maybe it would help to get your angles right on some smaller pieces first. Use some scrap pieces just for angle experimentation. I know the Bar Rail is pricey, but sparing a couple of feet for practice cuts could be the solution.
As for the platform...all you need is something to place under the Bar Rail to get it "level" (i.e. how it will be on the actual bar). For me, all that meant was placing a 2x4 in one of the notches under the Rail before I cut it. You can slide the 2x4 down out of the way so it still supports the rail while cutting, but is not being cut itself.
Hope that makes some sort of sense...
I ended up putting two Halo 5 inch can lights, one on each side of the star field above the front row. I covered the box with a plate. If I have to get access to it, I can pry the front of the star panel off. I took the power from the removed ceiling fan, so I still have the three way with the fan over the bar. That situation is working out okay for now. I can still turn the fan and lights off over the bar with the chains.
