AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › Pioneer Elite Pro-930HD/TV Guide Settings
post #1 of 3
I bought a Pioneer Elite Pro-930HD Plasma a few months ago and I hooked up the cable to the Ant A. I went through the TV Guide Wizard, but nothing is populating (after about two weeks of waiting for it to download - lol).
So, I hooked up a digital cable box (this is all non-HD for the moment btw), and lo and behold the cable box's TV Guide populated.
So, why doesn't it populate when the Plasma is hooked in direct to the cable?
post #2 of 3
Does the cable box use GEMSTAR's guide? Thats a very important distinction. Most cable companies use a different type of guide system where the box downloads direct from the cable stream, from the cable company.
The Gemstar system uses sub-data broadcast within specific stations. I personally have never seen a cable box using Gemstar's system...
There is a really good thread over in the rear projection forum about gemstar's guide system, I cant find the link at the moment though or I would give it to you. If you search through the official 6G pioneer thread, this discussion came up and we went through it fairly detailed. Thats where I remember the rear-projection link being posted (how I found out about it).
Gemstar's system isnt the greatest, but its the most economical for the tv manufacturers to use.
post #3 of 3
The tread in the rear projection forum is called;Poll:TV guide on Screen.As of this monent the last post was yesterday(Feb.9) at 3:55pm.Sorry don't know how to post link.I noticed the same problem.The Media box will download the Guide ,but I haven't been able to download the on screen TV Guide with the cable directly connected to the a Sony DHG HDD-500.
This thread is locked
