AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Sony HS-60/51A Official TWEAK Thread - Please Post Here
post #1 of 486
Welcome to the Sony HS-60/51A Official TWEAK Thread.
While there many similarities between the older 51/50 and newer 51A/60 Sony projectors, there are too many differences. So, many folks agree we should establish a tweak thread specific to the new projector.
Please post your calibration & tweaking information in this thread. Maybe we will eventually achieve sticky status.
As a starter, here are the remote commands for accessing the SERVICE and FACTORY menus.
The SERVICE mode is accessed by pressing on the remote (enter) (enter) (UP arrow) (DOWN arrow) (enter), then (UP arrow) when it asks "do you want to enter the service mode?"
The FACTORY mode is accessed by pressing on the remote (enter) (enter) (LEFT arrow) (enter), then (UP arrow) when it asks "do you want to enter the factory mode?"
Any additional menus usually pop up under the main INFORMATION menu.
***WARNING***
It is possible to damage your display if you change some factory parameters. Stay way from parameter controls you don't understand, and others that you do, like Fan Temperature Threshold. You may also void your warranty.
When you 1st access the service or factory modes, take the time to write down all of the settings, just incase you get confused and unintentionally change a setting.
In many cases, of the hundred plus service/factory parameters, there are very few worth adjusting. You may find most of the parameters which benefit the calibration process are located in the service mode, so you can avoid the factory mode all together and the associated risk.
Enjoy your display and be careful if you decided to access the service/factory menus.
post #2 of 486
Thanks Byte. I'm looking forward to reading your impressions and custom settings for your 'baby Ruby'.
Cheers, Rob.
post #3 of 486
A quick question Byte. Do you know the thread size of the HS51/60 lens ? I want to fit a ND2 filter ~ I'm only using a 32" high constant height screen.
Thx, Rob.
post #4 of 486
Have you a tips to correct the Vertical banding ? It is present on the green panel
post #5 of 486
Can I assume that after using the key sequence to access the service menus that the same sequence brings up an option to leave the service menus and have just the user menus?
Thanks, going to try some of the posted setting tonight.
M./
post #6 of 486
Now that I have decided on where I will house my 51A I went ahead and replaced the AC sockets in the wall. My place was built about 40 years ago and the owner/builder cheaped out wherever he could. That means his electricians used the quick and dirty install method of jamming the solid copper conductor into those openings on the back of the duplex socket instead of taking the time to bend the conductor around and securing it to the screws. When I installed the new duplex outlet (just a normal consumer grade unit) I did use the screws and I guestimate I increased the contact surface area by at least a factor of 20, maybe 50.
I am also now feeding the DVD player and the 51A off a Transparent Isolator IV I AC conditioner I had obtained used last year. I also have a PS Audio P500 to try.
So I watched the beginning of The Big Sleep again where I had noticed the red push in the shadows and there was less of it. Blacks *seemed* blacker too. I can see where the green and red are mistracking but it is not glaring. Funny thing is that it often tints things completely in that a suit will be all the same shade of grey and so the entire suit takes a slight red tint while another characters clothing has a slight green tint.
But I really do have to work at getting concerned about it. I have driven 30 minutes one way into San Francisco for Noir festival screenings and I am getting a more pleasurable and involving presentation off my 51A then I ever have in a theater.
So looking into your AC might be worth a try if you do not know the quality of your AC outlets.
As it is now I have just a couple of tiny issues with my 51A and I only see them when watching black and white movies that should be just black and white. I also checked out Buster Keaton's The General and since it is tinted, it looked fabulous (as 78 year old silent movies go ;-).
M./
post #7 of 486
I am interested to know that too, even though the VB on this model does not bother me at all.
post #8 of 486
Here are my factory RGB values pre-calibration. I will follow up later with how well these factory settings track grayscale as well as any new post calibration values for 6500k, 7500k and 9300k.
.......high...mid....low
RG...128...128...128
GG.....46....38.....28
BG.....61....48.....28
RB...124...122...121
GB...128...128...128
BB...139...138...134
I would note these RGB settings as well as the Gamma Shading settings in the factory menu seem to keep a fixed red value and work green & blue for color temp correction. This a definite change in calibration strategy which might help overcome some of the 50/51 red bias errors thru the 0-100 range. These setting might also contribute to the dimmer bright white output some folks have observed.
I hope to establish at what gain/bias values for red, blue and green clip. Then it should be possible to push max brightness at each color temp.
Here are some new found factory menu items which deal with EE/ringing. Both of the following items appear to be High Pass Filter (HPF) controls.
DISPLAY ENGINE
25 DE/HPF ON = 1 Setting this to (0) eliminates EE visible around dark letters & lines. You can see an apparent shift to a softer image. Setting this control to (0) appears to be the same as setting the master sharpness control to OFF.
26 DE/HPF TAP = 1 With Line 25 set to (1), this control expands or contracts the Edge Enhancement around dark letters. The expansion occurs equally to the left and right as the value is increased. Setting to (0) completely narrows the EE, while manitaining a very slight edge detail enhancement. This control appears to be a great way to adjust the aesthetic of the master sharpness control when the master sharpness is set higher than OFF.
My factory IRIS OPEN/CLOSE REG settings are 41/222.
We all know the following has been mentioned, but I thought it worth repeating for the new tweaking thread.
DISPLAY ENGINE
04 DE/UF SW = 1 Setting the value to (0) turns off the Gamma Shading function in the factory menu.
post #9 of 486
Byte,
Interesting finds. My service codes are very close to yours. Only off by a couple of digits if I remember correctly. I will check them and respond back when I have time. Iris numbers were 221/40 so we are very close there as well. I am wondering if Sony is getting their act together on uniformity. Are you noticing the same things I am noticing on the high IREs? As I noted, I have bumped my Iris down to 212 trying to pump up the higher IREs but still am getting a bit more haze than I like. I think I am going back to the factory settings unitl we get more confirmation.
post #10 of 486
Originally Posted by awtryau89 View Post
Byte,
Please note I have not done any critical viewing. I simply turned on the OPPO and watched the OPPO screen while running thru the service mode settings.
I did play around with the IRIS open/close reg settings. You know how if you set the IRIS ADJ from 0-1, and then go to adjust either the close/open reg settings, the iris opens or closes? I found if I adjusted close/open to 0/190, the projected OPPO screen did not change value when switching the IRIS ADJ to 1 and making changes to close/open values. So I plan to put up a 10 & 100 IRE patterns and experiment with changing the CLOSE value from 41, as well as the OPEN value from 222. I had 40/205 as my close/open values on the 51.
I got the 51A in (1) day from NYC. Not bad for UPS Ground.
I'm still waiting on the Cliff probe swap before I can dive into calibrating. I also have a huge video project due Thursday night, so when I'm done here I will be diving back into editing. It's gonna be a couple of long days/nights.
Eric... it seems like the pixel structure is a little smoother on the 51A. I'm not sure why it's different, but I can get a little closer to the screen before I see SDE. Hmmmmm....
post #11 of 486
Thx for the new info Byte. I'm looking forward to your post calibration comments and settings. I'm guessing you didn't need to to use a filter with your 51.
Cheers, Rob.
post #12 of 486
Since the HS-60/51A appears to run out of RED 1st, a red filter might be helpful.
I have a Hoya FL DAY filter I could try and measure if I can get any additional contrast by being able to run green/blue a little higher.
post #13 of 486
DISPLAY ENGINE
25 DE/HPF ON = 1 Turning this to (0) eliminates EE visible around dark letters & lines. You can see an apparent shift to a softer image.
26 DE/HPF TAP = 1 With Line 25 set to (1), this control has a range of 0-3. Setting to 3 moves the EE around dark letters to the left. Setting to (0) completely center the EE, while manitaining a very slight edge detail enhancement. (note the Sony service manual says this control only works with certain signal types. 720p HDMI works for me. I will check other signal formats later.)
DISPLAY ENGINE
Who is the service manual ??
Have you a link to download this ?
post #14 of 486
I believe the manual is only available from Sony in a printed form through the Sony parts department.
Please note I am still using the HS-51 service manual. I have not checked on a new manual for the 51A/60 yet.
post #15 of 486
Service Menu Values
GG.....49....44.....35
BG.....69....55.....34
RB...122...121...123
BB...135...136...137
post #16 of 486
I am very concerned too.
Thanks to my hero !!
post #17 of 486
It's funny, but I also noticed the same thing going from my HS50 to the HS60. And I was almost sure that the pixels on the HS50 were rounder. In the HS60 they seem much more like squares or rectangles. I am not sure, though, that this less SDE isn't because of something else... At least in my case, my HS50 had almost perfect pixel alignment - although the green was off, it was off by one pixel exactly. My HS60, on the other hand, has much better convergence, but the pixels are not so perfectly aligned - I can see something like less than 1/4 of a pixel off between the 3 panels. This is actually a good thing, from my point of view. This "micro misalignment" is only visible with nose-close distances to the screen, and has the effect of making the pixels seem larger, effectively masking the SDE.
Anyway, this was probably more due to luck than actually on purpose by Sony, I guess...
Dave.
post #18 of 486
I think I found something related to the bright corners issue, which the 51A/60 apparently shares with the Ruby..
Under the OTHER menu, it involves the IRIS CLOSE REG = ? control near the end of the menu range.
On the HS-51A, as I move the setting lower than 222 , I begin to see bright corners on dark black fields. Increasing the the value to just 225 cause the iris to close down just enough to eliminate the bright corners.
I still see the bright corners when going from a bright scene to a total black out, as the IRIS slowly closes down. I haven't seen an adjustment for controling the speed of the IRIS when closing down. Even setting the IRIS CLOSE REG at a maximum value doesn't affect the speed of the iris.
I also see that turning the IRIS to ON, ends up not being as dark as when in AUTO mode, and the IRIS ON mode will also produce bright corners on a black field. Does anyone know of a control for the IRIS condition when in the ON mode, as it does not seem to be fully closed?
post #19 of 486
I finally got around to some calibrating last night. I'll call it the mother load of calibrations as I calibrated for 9300K, 7500K, 6500K, at master contrast values of 70, 80 & 90.
I also calibrated for 9300K with IRIS OFF in both the HIGH & LOW lamp modes. I like to use these settings for watching sports with friends.
I have confirmed factory GAMMA 2 provides near perfect gamma 2.2 tracking, with the least amount of bump (2.8 at 40) on the bottom. I hope to try some custom GAMMA tweaks using the Sony Image Director software. Maybe I'll be able to achieve a flatter top to bottom gamma response.
Using a 100 value white screen, I found the clipping point for RED at each contrast setting. I then calibrated using only using GREEN and BLUE to achieve the color temps.
Post calibration, a contrast = 90 provided the most uniform grayscale tracking, with 80 the next best and 70 the worst. Oddly enough, contrast = 70 was marginally brighter (54 vs 52 FLs) at 100. But I'll take the flatter gray scale response over a touch more contrast at this point. I suspect this is due to the way gamma for red, blue and green track differently at different contrast settings and how red runs out on the high end differently at 70 vs 90 contrast.
One thing I tried different while calibrating the 51A versus the 51, I set the AUTO IRIS CLOSE/OPEN values at 0/255. This allowed for the gray scale patterns to be least affected by the IRIS state. Note, this is not the same as IRIS OFF, which does require a little different RGB tuning. I ran out of night, and with the sun coming up I'll have to wait to check out how the grayscale tracks when I return my IRIS CLOSE/OPEN values to normal.
I confirmed there is slight shift to RED when switching from LOW lamp to HIGH lamp. It's not much and maybe even something you would not notice as it only took a couple of (-) clicks of blue & green to compensate.
One thing I might try in the next session, is finding where GREEN clips and calibrating RED and BLUE to spec. This approach will likely let RED begin to run out at 90 and above, which makes for a little more blue at 90 & 100, but it also allows for a bit more contrast.
I think I will try to use the spreadsheet approach to posting my settings and I'll put it up when I finish up the next round.
I'm wondering if I could run an even higher contrast of 95 or 100, and still be able to achieve proper calibration and maybe see even better grayscale tracking. hmmmmm....
post #20 of 486
Thx for the update Byte. I'm interested to try your settings for 6500 and 7500K.
When you post them please itemise the changes to the service/factory menu in sequence, I don't want to screw this up ! (I'll take note of the current settings before making any changes.)
Cheers, Rob.
post #21 of 486
Dave.
Doesn't the HS60/51A(US model), use the D5 PANELS, versus the D4, in last years(hs50)model? That is supposed to have better fill factor (50 versus 60% on the D5). Wouldn't that account for the perceived "smoother" looking pixel structure?
CHEERS, TC
post #22 of 486
Same panels as the HS-51 it just has no added scaling if you send it 720P so the image is sharper.
post #23 of 486
Hi Kris...
I hope you had a good boat ride.
post #24 of 486
Sony did not use D5 panel n they made their own. That's why VB is not a problem for Sony.
CHEERS, TC
post #25 of 486
OK...
Once you make your way into the service menu, pull up the main menu and look for W/B at the bottom. Inside you will see High, Mid, Low, Custom 1, Custom 2 & Custom 3. I suggest changing one of the Custom menus until you're sure you like the new settings. Note at the bottom the SAVE SETTINGS option. You will want to use that when you're done. Also note, you may have to go back to the USER menu to reset to the color temp you have elected to change. You should also note factory settings for Custom 1, 2 & 3 are equal to high, mid & low respectively.
When you click on Custom 1, the 1st of two available screens will come up. This 1st screen is for RGB GAIN settings and the 2nd screen comes up as you work down past Blue Gain. The 2nd screen is RGB Bias.
The 1st group of calibrations are for:
contrast = 80
brightness = 45
color = 50
hue = 50
Gamma 2
IRIS Auto
Low Lamp
.........6500K.......7500K.....9300K
RG......132...........132..........132
GG........28............32.............33
BG.........27...........39.............54
RB.......121.........121............117
GB.......130.........129............127
BB........136.........136...........134
The following are for Contrast = 95, the other main controls are the same.
RG......104...........105...........105
GG.......12..............16............17
BG.......14..............27............40
RB......103...........105..........104
GB......117...........122..........121
BB......123...........125..........124
Give these babies a whirl and post your thoughts.
post #26 of 486
OK...
contrast = 80
brightness = 45
color = 50
hue = 50
Gamma 2
IRIS Auto
Low Lamp
I tried your settings above for 7500 and they made a nice improvement to my image.
Thanks for posting them. I still have a slight red push in certain shadows but everall the 51A is looking great. Between your settings above and my custom eyeball settings for B&W movies I get a great picture.
Just that last bit of red to work through. I talked with a friend and he said some DVD players from a few years back (my DVD players era) had a slight red push in their software and that could be the issue. I have an Oppo on order and who knows, maybe that will trim the red back a little more and then I will be home free.
I am designing a manual masking system for my screen and will post pictures and a "howto" for the thread. Guestimate right now is about $50-$70 in materials and setup/takedown of less than 2 minutes each way.
I am also just about done with my calcs for placing the projector inside this Ikea table for the stealth look I prefer.
http://www.ikea.com/webapp/wcs/store...64*15797*15799
I will try and take some photos of the table with the projector sitting on it and my overhang calcs so folks can see if it would fit their needs in their room.
Finally, is there a generic designation (1/8?, etc.) for the plug I would use to get the 12V power out the back of the 51A? I want to use it to run a CPU fan I bought to pull air into the Ikea table. I guess I will assume it is positive on the inner pin but will double check.
M./
post #27 of 486
Originally Posted by wyattsdad View Post
I tried your settings above for 7500 and they made a nice improvement to my image. I still have a slight red push in certain shadows but everall the 51A is looking great.
I am designing a manual masking system for my screen and will post pictures and a "howto" for the thread. Guestimate right now is about $50-$70 in materials and setup/takedown of less than 2 minutes each way. M./
If you want to tweak for the red push, try adjusting BB (+) 1 or 2 clicks. I would then adjust BG (-) 1 click for every (+) 2 BB clicks. If you need 3 clicks of BB, also give GB (+) 1 click as this will bring the color geometry back to the center.
If you get a minute, give the 7500 contrast = 95 calibration a whirl. I'd love to know if you see a difference. If you have Sin City, it might be a good candidate because of the dramatic B&W scene dynamics.
I am interested in your DIY masking system.
post #28 of 486
I will try the 7500/95 as your settings I tried last night blew past my best THX/eyeball color settings so I have that memory slot to fool with now. Prior I had some of the custom settings for different tries at colors adjustments.
I am aiming to have 4 custom settings
1) Cinema - current movies (your settings will probably work for this)
2) User 1 - older color movies that need to be bumped up in some way
3) User 2 - current B&W movies, Dead Man as a prime example
4) User 3 - older B&W movies, all the old Noir & Hitchcock etc. The older stuff needs some black compensation vs. newer films and although the shadows start to block up the overall presentation is superior with some enhancement.
I will stop by the local JoAnns today to get the product # for their black velvet. It is not shown on their site but they say you can call and order if it's not shown. Their site has 40% off until the 28th.
I will try and post my CAD drawing for the system. It is based on my trying to continue use of my existing 7 foot diagonal screen since it is mounted and paid for. At 4:3 I get 84 inches and at 16:9 I get 72. A larger screen would completely dominate the room and entail lots of futzing and many $$.
If you have a 16:9 screen to start you can probably just change the sliding panels to be the side units. In my install it will be the top and bottom panels that move.
Thanks again for the settings, my red issue is mostly at the lower right of the image and along the lower portion of the screen so these global settings might not get rid of it completely but I only notice it on B&W films and I may just decide it is too slight to warrant a big effort to get rid of it.
post #29 of 486
I tried your 95/7500 settings and they are better than the 80/7500 on the couple of color movies I looked at. A bit cleaner with better definition and skin tones are very natural. I always keep the oldest setting in a memory so I can do A-Bs of newer settings and it has steadily moved in a good direction using your settings. So perhaps it is that the projectors are actually pretty similar in capability from one unit to another.
As for B&W I think Sin City is too high contrast to see errors (looks great tho'). I have been using the beginning of The Big Sleep as it has a very nice scale of greys. In the opening scene where Carmen Sternwood tries to sit on Philip Marlowe's lap while he's still standing there is now just the smallest amount of red push in just a very narrow band of grey. The narrowness is such that there is almost no splay of red across a series of greys, a part of the image is either in the band of error or it's not and so her sweater has the slighest red cast but there isn't the ragged red in the shadows that I had with the OEM settings. In that scene there used to be some red in Marlowe's suit but it is gone now. When they go into the hot house it also offers a nice sampling of greys to test with.
So I'm hoping that the OPPO might clean that last little bit up. The newer design, better decoding and higher quality input (from component to DVI/HDMI) might just be enough to push the problem into the noise of a normal lifestyle. As it is I really have to work at being concerned as the picture quality for the $$ is just amazing. And so I will only be abe to get myself to put a bit more effort into eradicating it and then I will just say, "that's the way it is" as this price point.
For a modern high quality B&W image to test with I think you will be hard pressed to find a better one than Jim Jarmuschs' Dead Man. It's a great movie to boot.
I will try your BG/BB tweaks above tonight.
M./
post #30 of 486
I have done some minor checking between 70, 80 & 95 contrast calibrations.
95 seems to provide a more uniform grayscale of white titles fading on a full black background. Contrast 80, and 70 even more so, has the titles shifting slightly red just before the fade to black.
I watched Zathura and Stewart Little 3 with the kids, and I also liked 95 the best. I was looking for and didn't see any negative artifacts using 95, such as any clipping of white highlights.
I'm like you Wyattsdad, I prefer 7500K over 6500K, and on occassion I don't mind 9300K. Zathura was a little better at 9300K because of the over saturation of red & orange in the film. Then when the space fileds scenes come on with the dark blue nebula mist, it feels very 3 dimensional.
I have a couple more films to check, but I'm leaning toward sticking with the 95 contrast calibrations.
I will also try recalibrating with the HOYA FL-Day filter, which should be perfect for the inherent color biasing of the 51A lamp. I'll post those numbers down the road.
