My PB10 resonates quite a bit up the wall and rattles the drop ceiling I have in my HT room. Will the subdude make an improvement? (Cement floor covered with thin padding and burbur carpeting)
Not unless you are above grade.
Not sure what the poster means but grade is ground level. Basements are usally below grade= ground. that's what I get out of it.
If you are on grade (the concrete slab is on earth, such as in a basement), the slab will not transmit vibration very well. Hence, a SubDude will do next to nothing.
However, an above grade slab is not as rigid, damped, or as massive, and much more easily transmits vibration. In that case, a SubDude will be much more effective.
Would some sort of absorbtion material behind it (on the wall) help more? Is there a fairly inexpensive way to do this? (I see the $300 12" sheet of foam)
Quick suggestion for those looking for a cheap and easy alternative isolation for their SVS subwoofers, my SVS PB-plus/2 subwoofer came very well packaged and you can use the sturdy space shuttle foam type material that supported it from being damaged when it came as an isolation platform and it works extremely well at stopping vibrations getting to the floor it's 33 inches by 23 inches and 1 and a half inches thick and its so sturdy you can stand on this material and it doesn't bend and it was obviously designed to take the full weight of the SVS subwoofer and to protect it while being shipped, it's perfect for subwoofer isolation and i was able to use other pieces of this which came with the subwoofer to isolate other equipment.
Before i used it my floorboards shook a lot as they are wooden and now they don't shake at all.
I don't think it's really foam but i don't know what the material is called.
You don't have to cut it either so if you need to return your subwoofer you can re-use it easily enough.
While that's true, he does have vibrations, so whatever his configuration, LF energy *is* being transferred. I'd spend the $50 on a Subdude. Cheapest risk he can take.
Well, it's true that at $50, it may be wortth trying. I wouldn't be surprised if his problems are due to airborne sound rather than structure-borne sound though, in which case the SubDude will do nothing.
I have Sony SAWX900 (I know Sony is not appreciarted and recognized in the audiophile community) but this sub is a different animal. 2 (12") in push pull configuration (drivers made in US) with 1000 Watt rated Amp (Ice Power). Sub used to shake the walls when played any movies with low freq contact and volme control set above 1/3 volume. I tried using the spike feet came with the sub and it helped a little not to a great extent.
I read about the Auralex and ordered one from SweetWater. Oh boy what a difference it made. Now can hear the bass rather than feel it with more authority and punch. For about 50 bucks shipped, that is a huge improvement.
My sub is 19" x 19" (Mackie), so the Great GRAMMA would be perfect for me if I could shorten the long side a bit. Esthetics aside, will I be able to use a hacksaw to trim the GRAMMA? From what I read on this thread, the GRAMMA is made of an MDF board and some foam, so it should be no problem.
Has anyone trimmed their GRAMMA or Subdude? Did you find any metal "reinforcement" parts in it?
Good answer. I guess there is always a way to trim the pad. I am mostly concerned about the amount of work required. If it's just MDF, it will be a 1-2 minute project. If the pad contains a metal sheet, I'm looking a major sawing project.
No, (assuming the Gramma is built like the Subdude) it's just MDF, wrapped in covering. Peeling the covering back would be tough because it goes under the acoustic foam. But you should be able to cut it and then peel back, then cut the wood.
Thanks. Ales
The subdude/gramma at 23"x15" is only 4" longer and 4" narrower than your sub. Put the overhang to the rear and it will provide cable clearance. Or split the difference at only 2" front and rear. The underhang for the width is fine. It will still support the box. And, no cutting involved.
This really won't work because the sub has a downward-firing driver. The sub's little feet/spikes are 16 inches apart, so a 15" wide pad is not wide enough.
Or buy aftermarket brass isolation cones. No drilling required, and you can place them under the sub where needed to compliment the Gamma's dimensions.
Guaranteed to make an improvement. I am going to order another one this week for a second sub, which has been gathering dust too long for no good reason.
Well, I ordered my second Subdude. It arrived, and much to my suprise, it was about HALF the size of my first one. The new ones are 15x15, my old one is 13x23.
I measured my old Subdude at 13x23, which fit my M&K MX-5000 perfectly. The Sweetwater rep was trying to do backflips to make me happy, but you are right. They shoulda' let a repeat customer know of the spec change. Or else I should have double checked first.
I brought my M&K VX1250 upstairs and sat it on the new mini-Subdude, and it sounded terrible. I have absolutely no other placement options, so I guess I will stick with my single sub set-up. I SMS-essed around with it for an hour, but still horrible. Even my 16yr old hip-hop loving bass addicted techno teenage son though it was bad.
That's what I get for tweaking a dialed in set up: a Minidude I can't use and a subwoofer that will never again see the light of day, banished forever by the immense capabilities of it's big brother.
