jrunr, you are getting seaton submersives, correct?
you will not need isolation... the submersives are inert... using an isolation pad is trying to solve a problem that doesn't exist in the slightest...
personal example...
my room in on the second floor of a 107 year old brick house. it has pine wood floors, nailed into the joists... things WANT to pick up physical vibrations in here...
my previous sub was (is, still have it) a paradigm servo15v2... no slouch in it's own right... stuffing a great gramma under it eliminated a lot of rattles in the room, due to decoupling the sub from the floor...
however, my submersive doesn't vibrate a BIT... there are no vibrations to transfer to the floor... i'm not unique in this... one of the things that "makes" a submersive is the inert cabinet....
i WOULD suggest you put them on furniture sliders until you get them basically where you want them... that makes them a LOT easier to move...
