AVS › AVS Forum › Audio › DIY Speakers and Subs › DIY Gallery
DIY Gallery - Page 9
post #241 of 1040
Hmm...
Originally Posted by Wikipedia View Post
"Bondo is a two-part putty used to fix dents in cars, created by Bondo Corporation. While the term "Bondo" is a brand name for this company's product, it is commonly used in the U.S. as a genericized trademark to refer to all auto-repair putties or so-called plastic body fillers."
Yeah, that's what I used
To get a piano finish you need to make the surface really smooth, it's a pain in the ***...
post #242 of 1040
Here's the results of my 3 years of DIY labour :
www.gattiweb.com
post #243 of 1040
Nice setup Scanspeak.
Bet they sound awesome too!
post #244 of 1040
impressive work scanspeak! well done!!
post #245 of 1040
post #246 of 1040
That is one radical setup! Nice room for HT.
post #247 of 1040
On word...SUH-WEET !!!!! All I could think to myself is "My wife would kell me if I did something like that....It's lovel y man, tear jerking at best...
post #248 of 1040
Adds new meaning to "Rock your world" 4 sure!
post #249 of 1040
My 21" sealed cube with 18" TC Sounds LMS-5400:
Finished and in its home:
Build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=816576
post #250 of 1040
Nice work Joe! That monster won't put stress cracks in that concrete wall will it? Mine claimed a lamp yesterday after shaking it off a side table.
post #251 of 1040
Originally Posted by ssabripo View Post
my twin tower subs:
design thread: http://www.avsforum.com/avs-vb/showthread.php?t=756408
Wow, that's cruel!
Quite heavy rear channels too.
jpmst3! Really nice sub!
post #252 of 1040
My Sonotube with a TC2000 15
post #253 of 1040
exojam, i love the departure from the darth vader look--way to try to fit the decor while adding something as big as a water heater to your home. very clean and neutral.
post #254 of 1040
Thanks. I was lucky enough to have the carpet and paint still around. It is not where I want it musically but I am working on it.
post #255 of 1040
9cuft, 25" cube tuned to 17hz using 6"X24" rear port. Finished in black speaker carpet.
post #256 of 1040
9.44ft3 tuned to 15hz tc2000 15"svc powered by ed lt/1300 amp.
post #257 of 1040
hey vitod, if you get a chance could you snap a couple pictures of your sub next to a bottle or person to get a better idea of size? I am thinking of building a box pretty much to those exact specs but am nervous it would be too big.
post #258 of 1040
NICE!
post #259 of 1040
Originally Posted by Matt34 View Post
NICE!
x2. excellent finish!
post #260 of 1040
That is badass! That is a cool alternative to the sonotubes...
post #261 of 1040
wickedpsi, did you have a thread showing how you built your sub? Step-by-step or anything?
post #262 of 1040
sorry, no i didnt. my wife had the digi cam with her when i built it so the only pics i have are of it completed.
i went this route because i had no way of bringing home a sonotube.
the dimensions of the box are 22x24x46 without the legs and base. the legs are 4.5" long.
theres extensive bracing every 10 inches if i remember correctly.
hope that helps.
-andrew
post #263 of 1040
Sure! Stay tuned.
post #264 of 1040
sorry, no i didnt. my wife was out of the country with the digi camera when i built it so the only pics i have are of it completed.
hope that helps.
-andrew
Too bad. Would've loved to build one.
post #265 of 1040
Design: Ported or Extended Bass Shelf (EBS)
Enclosure: 8.5cf (net) 9.46cf (gross) Tuned to 15.5hz
Driver: SoundSplinter RL-p15 dual 2 ohm
Amplifier: Behringer EP1500 (bridged mono)
EQ: Audyssey MultEQ XT
Cost: about $700 for everything
Build Thread: More pics http://www.hometheatershack.com/foru...ject-pics.html
Heres some pictures, I think it turned out great. It realy looks perfect even though the first picture makes it look worse then it does in real life. It realy does'int look like the first pic.
Before Eq
After EQ
Looks kinda familiar huh Wickedpsi
post #266 of 1040
now thats a good lookin enclosure Jerm.
post #267 of 1040
I bet that Iguana absolutly hates you now.
post #268 of 1040
Subwoofer and PR is a Danny Richie of GR-Research design, 12" down-firing woofer with 12" passsive radiator running off a 250W RMS plate amp (ApexSr). It was tough to find any analytical evidence on what to expect from the sub. I did build a 110 pound enclosure that is 21" cube ( my own design)- 1-1/2" walls with large cross brace to boot. Black hole5 on all interior surfaces. VERY solid enclosure- I figured I could put a rhtymik kit in it at a later time if the GR Research driver did not pan out. The inlay is Burl Veneer and the 1-3/4""molding on all outside edges is Brazilian cherry. The cherry started as solid 2"x2" and then painstakingly rabbeted to make it fit the MDF panels below. The 4 vertical pieces of cherryuace have no visible glue line- these had to be routered and chiseled out leaving the top and bottom corners solid wood (you can see the darker endgrain in the photos of the top. I would definitely NOT want to do it all again but it truly is something I am proud of- still needs several more coats of danish oil...
REQW JPEG below- solid line is room response in final position, dotted line is proposed curve after EQ-ing with BFD.
post #269 of 1040
post #270 of 1040
so Vitod, what are you gonna do with your lates "addition"
