AVS › AVS Forum › Audio › DIY Speakers and Subs › DIY Gallery
DIY Gallery - Page 12
post #331 of 1040
Originally Posted by danog14 View Post
Hello all,
Here is my TC sounds OEM 10 box and sub. Have it with a gloss black finish. This is the first box I have built. I have a few questions though. I am running it with a bka but it does not seem to have enough power. I am trying to figure out if I am doing something wrong. I can turn the gain up on the amp all the way and not push the driver to extreme. Is that normal? Also have some vibration that I cannot get rid of. I think I need to put some sort of speaker gasket sealant because when I pust the frame in a little it goes away. Not perfect gloss black, but came out well considering how many times I messed up the finish. Thanks
looks great danog. might i ask how you did the gloss black finish? also thats sealed sub right?
post #332 of 1040
The gloss black was wood sealed with resin, primed and then sprayed with gloss black enamel, sanding in between each coat until smooth, wiping and then repeating the process using finer grit sand paper each time. The final two coats sanding were wet sanded. After the final coat was sanded, I used rubbing compound (a lot), wax, and polish until I was pleased. I messed up a lot and could have done a little better. It is a pain and a mess. Hope this helps.
post #333 of 1040
I forgot yes it is sealed.
post #334 of 1040
Hey Shino I think I am getting excited about finishing your enclosures. Great Job and it has made my day yet again.
post #335 of 1040
Shinobiwan: Wow!
I hope you report on how they sound, and perhaps include some specifications.
post #336 of 1040
Here is my first attempt at a real HT. I decided to use the Natalie P design from htguide. Not completely satisfied with the finish but they will do for now. The most important thing is they sound really good, to me anyway. I'm really impressed with the bass output as well. These are the sealed versions as I will be building a sub in the coming months.
post #337 of 1040
Those fit nicely with your decor. They look great from what I see.
post #338 of 1040
Wow they look really nice, Mains are next on my list, what kind of drivers did you use? and do you have any fabrication pics??
post #339 of 1040
Thanks. The pictures are deceiving because there are some glaring imperfections. I'll have to break down and hit them with some bondo eventually.
I don't have any construction pics because my camera was dead until recently. Followed the designs here http://www.htguide.com/forum/showthread.php4?t=13969. It calls for the RS180 woofers from parts express along with the RS28A-4 tweeters. Original designs call for a ported version but I read through other threads saying it was okay to run a sealed enclosure if a sub will be used so I went sealed. Internal dimensions are roughly 47''x11''x9.5''. Used 3/4'' MDF with two horizontal braces.
post #340 of 1040
post #341 of 1040
Originally Posted by cadbury8 View Post
here is a link to check out.
http://www.mundohi-fi.com/portal/ind...ub&tid=8&pid=8
heeh, that looks like it was a ton of work. I only studied 2 years of spanish back in high school (8 years ago), but I got through about 1/3 the text before I just started looking at the pictures
post #342 of 1040
Knock-off's of the B&W Nautilus speakers. Very nice though! Are you the builder or do you know the builders?
post #343 of 1040
Sure the design is a direct copy but the that series of pics is just amazing! Great craftsmanship and a LOT of work!
post #344 of 1040
Oh, no doubt about that, just wanted people to know that those are not some random idea by the guy that did all the work, but essentially a copy of a very expensive B&W design.
No way would I ever take on a task like that. Too much work!
post #345 of 1040
man i wish i had those kind of skills. but no i have nothing to do with it but wanted to pass it on to maybe give people ideas. I cant even speak spanish lol so i only looked at the pictures.
as what was said its a knock-off but kudos to the builders. Hope they sound good.
post #346 of 1040
i guess i should have posted that, but i thought it was evident so i didnt. my bad.
post #347 of 1040
Hey,
I just finished my SS Rl-p15 + EP1500 sono. It turned out better than i expected in looks and sound. Now the system is balanced.
Sono and my old sub. (Now co-located to compliment sono in 30-80 range)
This is the front stage
The surrounds
post #348 of 1040
nice job on the sono. has anyone put any screen over the port so nothing can fall in the hole? would a screen effect it at all?
Also it has great WAF. At least with mine anyway. she likes the way it looks.
post #349 of 1040
Nice work on the Sono, compliments the decor nicely.
Hey anything from Shino on the progress made, would love to see if that project is finished
post #350 of 1040
It'll prolly be a little while longer, I am sure we will find out when its done, but he won't updated us until he's done.
post #351 of 1040
Bummer, I will enjoy what you all post just as much though. I have a sub in the works right now but I am in debate whether to post a pic as it is not much like what you guys have. That is until I upgrade the driver, I am using and ED EHQS 12" and a BASH 300W plate amp in a 36"H X 16"D X 16"W downfiring with a 4" port at 18" long tuned to 20Hz. I have to wait a bit for the amp to reach though. Looking at the db500 as a replacement (still in debate) sometime in the future. Right now it's in the painting process and I can't say I am too pleased with the finish to date but there are a couple more coats to go. I will decide when it's done whether to post a pic so I will just look at what you guys have in envy.
post #352 of 1040
Don't sweat it. All DIY is better than no DIY. This was my first Sono. I dived right in and it turned out awesome. There might be imperfections, but it sounds and looks good to me. Thats all that matters, dont let other systems intimidate you. There are $20,000 + HT setups out there and yes, they look good, but i can hit >115dB with my $1200 sono. Can't complain about that.
post #353 of 1040
Good point I will consider as I tried to redeem the paint job today again. Got a little messy again after trying to redeem the first time...the weather.....I was supposed to bring it up today to add the filler and stick in the driver but I can't say if that will happen today for sure. Still deciding..and you must be really proud of that bad boy..Keep up the DIY!
post #354 of 1040
Originally Posted by ib4est View Post
Shinobiwan's main's are an absolute work of art. That is the most amazing DIY system I've ever seen. Great job!
I posted this over at Home Theater Shack so instead of rewriting it...
"Just wanted to post a solution to "build a sub to end all" that my friend and I did. We were wanting to prove not only that more bass is better, but WAY more BETTER bass is flat out awesome. And we did. Most people that are not HT nuts like us think we ARE nuts and that it is complete overkill...until they listen. Every single person that has heard this system is awe struck and usually makes the comment, "I have never heard anything that good in my life!". We had a space/dimensional issue that we wanted to "fill up" aesthetically all the while designing a powerful and dynamic system. When we looked at all the available subs, we ended up using the Dayton Quatro 15" for a couple reasons. 1-It is very inexpensive, especially when you buy 16 at one time! 2-We were designing a two box system with 8 subs in each cabinet which allowed us to address room mode issues by the sheer nature of the placement of 16 subs (see pics). 3-We had a massive amount of output, Xmax and displacement available without spending a rediculous amount of money on expensive subs and amps.
All told, this system came to a whopping $2,000. Including $450 in 1" MDF (8 sheets) and the CNC routering fee. The boxes were designed in BassBox Pro. 20cu/ft. cabinets with 2 seperate chambers at 10 cu/ft. per 4 subs. 2-6" port tubes for each chamber at 30". One on top and one on bottom tuned to 20hz. Each cabinet weighs around 250lbs w/o the subs. 2 Legion Sound Pro amps rated to 2700 watts bridged 4 ohms. Then we tuned it with a Behringer Feedback Destroyer Pro DSP1124P, REW and a RS Digital Meter.
The results are trully astonishing. 128db @ 25hz (we haven't even turned them up yet). NO ROOM NODES!!! and a perfectly flat house curve all the way up to the PSB Silvers output at 110db. Needless to say the dynamics and output are phenomenal but more importantly, they are very musical and subtle. If you didn't see them, you would know they were their until something big under 80hz happens. Then it's more of a dramatic exclamation point to the scene or music passage than an overbearing, booming bass note.
Hope you guys (and gals?) enjoy seeing our project. We are having a blast with DIY projects like this and hope this one inspires some of you to "go bigger"!
BTW - We built the center channel also with 4 Tag Bands and a Dayton Titanium Dome Tweeter. "
Nice subs. Dang. I have the Legion Amps too. Great units.
post #355 of 1040
the "Mission" ... a spouse-proof sub
Downfiring Dayton RSS315HF-4 12" driver with Dayton HPSA500 amp in sealed 2 cubic feet.
Oak veneered 3/4" MDF with solid oak trim in Mission furniture style (well, Mission furniture compatible anyway).
Double baffle = 1.5".
Double top = one 3/4" top piece fit into recess and 2nd as finished top.
post #356 of 1040
the "Gnome" ... a sensitive, yet stout and hearty wanderer of the 12 volt Super T-Amp wilds
Dayton RS-150-4 (4-ohm) 6" woofer with a Seas 27TDFC tweeter
The crossover is 2nd order LP and 3rd order HP, emulating 4th order slopes at 2kHz. ~6dB baffle diffraction compensation. There is no smoothing applied to the chart (below). It shows the unfiltered FRC combined responses and the filtered individual and combined responses, phases. The model was developed by frd/zma plots-Unibox-BDS-FRC-Speaker Workshop method (www.rjbaudio.com tutorial). Bass below 200Hz would model the direct Unibox slope (flatter to rolloff) more accurately than the FRC combined model (shown) that is intended for baffle diffraction compensation and crossover determination.
Box is 12.5(h)x6(w)x10.5(d) internally. It uses a 1-7/8 PE flared vent. Vent length is your choice. 4 is theoretically flat, (probably better indoors). 3-5/8 is my opt, a ~3/4 dB peak for an outdoor (room reinforcement free) slight boost response, -3dB near 50Hz. Tweeter centered at 2-7/8, woofer at 8, measured from top edge, woofer hole chamfered slightly inside. Vented to back at tweeter level.
Cosmetically, ¾ commercial veneered oak MDF with African mahogany (patio furniture leftover) solid edges, 5/8 roundovers. Damping is hollowed ¾ birch ply shelf brace (5/8 perimeter with 5/8 side-to-side cross-brace at depth dimension center dadoed at height between drivers), layer of B-Quiet (a foil covered bituminous sheet) and then ½ PE Sonic Barrier on back, top and sides, small teased clump of Acoustastuff behind woofer. Finish is spar-poly, a Gnome's favorite outdoor jacket. Shameful addition of burqa (grilles) for portability sake and rubber boots. (hmm, looks like leftover MDF from the Mission, posted above)
reverse polarity tweeter chart shows good phase alignment at crossover ...
balanced, smooth, detailed and great bass for a 6" driver ... impressive performance with a Super T-Amp ... about $100/each component cost
post #357 of 1040
Originally Posted by Bambus View Post
The surrounds
is that picture like from a hidden camera in your room or what?
post #358 of 1040
Actually thats a great idea, wouldn't mind having some extra security in my HT. (just in case)
but really its a fisheye lens on my camera, thats the only way i can get the whole room and all the back speakers in one shot.
post #359 of 1040
I'm finished. I can't decide what color to paint the thing, so I'll just leave it for now. I wonder if I should add some feet.
post #360 of 1040
You can just send it to me..
