Originally Posted by solidus13
on a second look, I think the capacitors are correct, so now I guess my question would just be whatever tips you guys might have for soldering, as in type of soldering iron ( mine is just a basic weller with no temp control dial) and whether it is ok to just use some radio shack desoldering braid for desoldering and cleaning up my joints.
Replacing parts on printed circuit boards that you want to work properly when done, is not the best way to go when you are also to trying to learn how to solder. Might be a good idea to find some kind of junk printed circuit boards, to practice removing and replacing parts on first. Unsolder some parts on them, and then solder them back on. Either that, or pay someone you may know that is experienced at soldering parts on circuit boards to do it for you.
