AVS › AVS Forum › Video Components › Video Processors › Lumagen VisionPro HDP + SDI
Lumagen VisionPro HDP + SDI - Page 2
post #31 of 70
I know that all sdi mods are not equal. I had a dvd player from a reference company that came standard modified by them, and it needed work. Thank god i had sent the player to Jim at Lumagen and he had to make 3 additional mods to perfect it. If your sdi input doesn't look right tan you can almost guarantee that there can be improvements made to it. This is my opinion anyways , take it for what it's worth. I love my lumagen HDP, i've noticed so many improvements made with all the different downloads over the last year, it's been nothing short of amazing. Even my only hangup with this series, those dreaded SD video mode jaggies have been improved significantly. With high def i find jaggies mostly non existant and not any concern. Since everything will eventually go high def, i don't see how any other processor anywhere near this price point that can come close to the Lumagen. True value through and through.
post #32 of 70
hey guys on the subject of SDI mods
has anyone seen a SDI mod were the signal is flashing(single colored lines across screen) for the first 60 seconds or so after the player and scaler are turned on?? it's like the scaler is "calibrating" it's input to accept the SDI output of the player
the SDI output is perfect after this short period has expired when powering up equipment and the analog interlaced and progressive outputs are perfect on the player after the mod was completed, so there can't be any shorts or etc.
If I leave everything on for good it never reappears but when I down off the scaler it returns for the short period and then is gone
this one has got me confused :confused:
-Gary
post #33 of 70
Originally Posted by jrp
I would be interested in when Dave Harper looked at the Lumagen. We have been constantly improving quality over the last year, and Dave might want to look again.
Perhaps Alan Gouger is reading this and willing to comment on his VisionPro HDP combo with his Ruby. I believe he likes what he sees using the Lumagen rather than going direct.
Jim,
I have a client that bought my G90 who came from a G70 that uses the Lumagen and I also had one here last fall 2005. I had limited time with it and think I would love to try one out again now that I have a VPL-VW100 also. I think it's a great product with many tweaks that I recommend to the more advanced customers that are able to take advantage of those. We had similar issues with the Rock scalers when I did a lot of calibrations with those. There were so many tweakable features that it confused the average, non technical users.
post #34 of 70
A comment was made about changing the Lumagens black and white levels to get them correct for the Ruby. Per our manual, this is the wrong thing to do (for the first input). What should be done is to set the black and white levels using the controls in the projector. If the projector levels aren't a match to the Lumagen, it must be fixed in the projector. Then differences between inputs can be calibrated in the Lumagen. Also, the DVI levels need to be set correctly in the Lumagen for input and output. We have actually heard of DVD players saying they use one and really use the other, which affects quality and calibration.
This is good advice, of course. A correctly calibrated projector should be the starting point.
To set black level, use the Lumagen's contrast pattern (MENU->MISC->TPAT, and use the arrow keys to select the contrast pattern). Adjust so the 4 IRE bar is barely visible againt black and the 96 IRE bar is visible againt white. Then using AVIA's needle pattern adjust the DVDs black and white in a similar fashion. Note for the black level I use AVIA's pattern of 2 and 4 IRE on a solid black background. This is because black level in projectors and displays vary a lot with average scene intensity. This difference can be exaserbated by a dynamic IRIS.
I would never use any DVD source to calibrate a video chain, with the exception of the DVD part of it. To do so makes no sense other than a rough 'rubber band' setup.
Before continuing, let me say that I am not a beginner to all this, having worked professionally in audio recording, and audio/video post production for a number of years. I have done many many calibrations with a variety of products in all parts of the audio or video chain, from source to display, and have designed/engineered several pieces of audio and video equipment (mostly analog).
In professional circles, the expectation is that any piece of equipment that is inserted into an existing video or audio path, can be quickly set to conform to the signalling standards of that path (minor calibration issues are a different issue). So for example, if I took my Faroudja DVP-5000 analog video processor and inserted it between a source and the projector RGBHV input, with all its controls set to default, there would be no further calibration necessary. 0-1v in = 0-1v out, period. THEN I make changes to improve or shape the signal to my requirements. Likewise if I set it for component in and out rather than RGBHV, it would follow those standards as well. The point is that by default, it is a neutral insert into an existing path.
For digital equipment of a similar function, the same expectation should be met. If you inserted a processing device in a digital path of a computer level signal (0-255), that device should be set to 0-255 levels input and 0-255 levels output, and be transparent assuming all other adjustments in the device are set to neutral. Likewise with video level signals (16-235) in and out, such as are typical in the home environment. And of course, when you transcode or 'map' between the two standards, the expectation is a neutral transformation.
Why then, does the Lumagen not conform to this? It imposes an input calibration for each and every input, in addition to just selecting video or computer input levels, leaving the door wide open for all sorts of operational miscalibrations and errors. Why is this? It makes no sense to me. Even SDI is a known digital standard with defined levels for accurate performance. Why then are the Lumagen settings for SDI completely off their default settings and also different from the corrections necessary to conform video level signals? There's way too much tweaking needed for basic operation.
Bill, while I assume you did not calibrate grayscale, did you at least set the color and hue and hue offsets using the AVIA color patterns? It is possible the color issues you mention are just that our out-of-box settings don't align with the Ruby. We try to have our setting be a nominal for the various requirements of the different manufactures, but since they are all different, we can't be perfect for all out of the box.
You can be extremely close right out of the box, if the above conditions were met. Obviously there's going to be an occasional piece of auxilliary equipment (like DVD players, mostly) that don't follow the standards, and for those you have the range of controls to compensate. These are not the norm, which can be anticipated.
Yes, I have calibrated grey scale on the projector with Colorfacts software, and have noted through level tests based on the calibration, where black and white levels should be on the projector (very close to those recommended in the Sony Ruby calibration section). I also have the numbers for black/white levels settings on the Lumagen to allow it to conform to a neutral insert condition.
However, none of this has anything to do with the point I have been trying to get across in previous posts. And that is, by simply inserting the Lumagen into an existing path (assuming level corrections), it degrades the image. Period. That type of degradation cannot be corrected by calibration adjustments. This the very first test we would always do with audio or video equipment under evaluation -- how does it change the signal by just being there. Then you decide based on the amount and type of degradation if you can tolerate it compared to the attributes that device brings to the table. If it can fix a major problem in the image, then the degradation might be acceptable, but if it was just added to shift an image or something minor (for example), it probably wouldn't.
And this is where I place the Lumagen. While it does some really nice improvements to interlacing, and there are a wide variety of options to modify the image, the initial degradation by just being there is too much for me. Others have commented in agreement on that point both here and to me privately. By in large those that see this characteristic have Rubys, Qualias or another very high resolution projector, usually not a CRT.
So now my question is whether this will ever be addressed in the VisionPro HDP? I think it's great that so many improvements have been made with software updates and all, but without improvement in the basics it's not something I'd want to keep. Would the next version with the Realta chip for interlacing be any better? Of course that's unknown at this time. Would the 10 bit software upgrade be better? Very likely possible, if it changed the entire video processing path to 10bit. But it won't be likely at all, except accidentally, if Lumagen doesn't realize a problem exists.
--Bill
post #35 of 70
Thanks Bill,
This is an extremely interesting thread for me. I'm in the process of selecting a suitable processor to feed an SDI signal. The Lumagen VisionPro HDP was at the top of my list, but maybe I need to take a closer look at the newer option offered by Caliber. This may have similar difficulties so I guess I need to wait for some feedback from the lucky owners who are receiving the first production units now.
In the short term the Lumagen maybe a good stop gap as I currently use a CRT pj, but may not be the best choice further down the road when I switch to a 1080 native pj like the Ruby.
post #36 of 70
This, to me, demonstrates too much 'DVD mentality' to be taken seriously. Is this processor designed for high quality HD processing, or a DVD postprocessor?
--Bill
I didn't read anything into Jim's response where he was suggesting to do otherwise. I interpreted his statements as describing the correct way to calibrate the video chain. Who cares if he chose the DVD portion of the video chain as his example? Is that any reason to launch on him in this manner?
As for the remainder of your observations about SDI and non-conformity, I think you're completely off the mark. Mine certainly doesn't "default" to non-default values, and doesn't "impose" calibration REQUIREMENTS (vs. calibration options) to every input. I have a high resolution microdisplay that I think puts the Qualia 006 to shame. I don't notice any video degradation with the Lumagen in circuit, and every source I've pumped through it thusfar, the Lumagen has improved its picture quality. So what the heck are you talking about?
And I'm just curious, have you ever called Lumagen directly to address these issues as opposed to using this public forum as some type of wierd version of technical support?
post #37 of 70
For the Ruby all of this should be done with the dynamic IRIS off (and leave it off for viewing) and the IRIS set to minimum light. The Dynamic IRIS makes it hard to get the best levels because the levels for test patterns are often different. If one insists on the dynamic IRIS - not the best choice - it is best to adjust black level with real material. Adjust black darker in the projector until the "haze" is gone, but not so much as to get any significant black crush. In my experience, this haze has always been incorrect black level.
Wow Jim, tell us how you feel about dynamic iris ;) You are not alone.
Since I installed the latest firmware, I decided last night to redo my B/W calibration, based on Gamma3 of the Qualia. Wow, what an improvement! And you are right - the haze is gone! Josh should be in Califronia this weekend getting the latest version of WmP's software for the Qualia calibration - I can't wait. BTW, I'll see if I can find out if WmP is going to provide his magic for the Ruby - last I heard, no.
post #38 of 70
You are quite off the mark. Nothing in the consumer world conforms to "standards". That means the displays (plasmas, LCDs, projectors) rarely conform, nor do the STBs or DVD players.
Just take the PC vs. Video levels and you have 4 possible problematic combinations (source=PC & display=PC, source=video & display=video, source=PC & display=video, source=video & display=PC). In two of these combinations, you're either clipping data or compressing levels. If you add a processor in the equation, you have 16 combinations (most of which are incorrect)!!!
and this is before you calibrate!
In my experience, Jim's method of calibration is the correct one. You first determine levels and match them, then calibrate the display using the processor's internal patterns. Then you use DVI or AVIA to calibrate DVD. Then, calibrate using other sources (e.g., DVHS, etc.).
After that, you need to calibrate gamma & D65.
BTW, I like DI as long as it's not intrusive (i.e., set to be done very lightly). As I understand it, disabling the DI and then calibrating gives you fairly good results afterwards, when you turn it back on.
post #39 of 70
Ofer, I think you're missing my point. The above was pretty much what I was saying, that once you have identified the correct input and output levels standard for each input and the master output, the processor should be neutral at that point. Put another way, if I have an STB with a video level (16-235) DVI output connected to the projector DVI input also set to video level, displaying a well balanced picture, then I insert the Lumagen with matching input and output settings for the projector and stb (video levels), the resulting display should have the same balance (white level, black level, etc.) as before the Lumagen was added.
If the Lumagen changes the calibration levels as seen on the display at its default settings, it is not correctly calibrated internally. At this point it has nothing to do with whether any particular device (except the Lumagen) is exactly on standard. And by the way, all the devices you mention DO follow standards. It's the occasional rogue design that may not, and it could surface in any type of equipment, but is most likely in DVD players.
My point was that if the Lumagen followed the standard, it would be what I'm calling a neutral insert. Since it doesn't, you are forced to also adjust levels of each input, possibly introducing unintended errors, especially with items such as stb's. Keep in mind that OTA HD source, as well as quality satellite HD source is not modified in levels by the receivers. Other than decoding, it is about as straight from the source and standards as you're going to get.
DVI or AVIA? I don't understand that.
My only objection to Jim's suggestion is using the DVD as a source for the 'first input' adjustment, since that becomes the one that is more-or-less a reference standard for the others. It's ok if the DVD player is known to be accurate, but not if it's an unknown. And never assume!
If the projector is correctly calibrated (by itself) and the projector input and Lumagen output video/computer levels are matched, the Lumagen's test patterns should be about right to start with. If they're a little off, you'd use the projector's black and white levels to conform them.
On the Ruby and Qualia (at least), the internal grey scale tracking is set independently for each mode, Iris Off, Iris On (fixed) and Iris Auto (dynamic). If this has been done correctly, there should be little adjustment to make for any particular mode.
--Bill
post #40 of 70
--Bill
I think ofer meant DVE (digital video essentials) or Avia (guide to home theater) dvd calibration discs.
Most people don't have a HD signal generator or Dtheater Video Essentials at their disposal. so the dvd player is the only source for test patterns.
I have often thought as you do however, what is the point using my highly out of whack dvd player as the basis of a sound calibration.
post #41 of 70
I was expecting the same type of performance from the Iscan DVDO VP30, neutral when adding in the chain, I didn't quite get that, but I really don't know if we can expect this can we??
boy oh what a SDI DVD image it gives off with the new 10 bit's it has, DVD's are another level between DVD and True HD, sdi DVD playback is better than the Iscan HD/+
I cannot seem to get a levels issue worked out either though, my DVD test patterns show that the 10 IRE level is crushed down to the 7.5 IRE level(I am not using PC levels) raising brightness to uncrush the blacks results in washed out black level
My set has been cailbrated to perfection and is right on the dot, I had a pro with proper equipment come in and help
what I need is a point gamma adjustment, of which the VP30 doesn't have :(
Bill I would say other than the Iscan throwing everything off just a smidge that it actually improves video, mostly in the form of the underscan creating a smaller sharper picture(I am using a 9" CRT RPTV with 5% overscan) this would not apply to the ruby, but the Iscan really did improve all my video, HD to DVD, "1080i in" to "1080i out" is what I am using
just my 2 cents on the Iscan, sorry the lumagen isn't working out for you
dvi is digital video essentials
-Gary
post #42 of 70
The 21906 update is excellent in the limited testing I've done so far. The SDI picture is MUCH improved. Smooth diagonals....
post #43 of 70
Amen! A great release for me! :D
post #44 of 70
Hi,
I didn't want to start a new thread on my Lumegan question so I will post here. I am thinking about getting the original Lumegan Vision. Does it support 800 x 600 or 1024 x 768 or 1280 x 768 Computer resolution ? I didn't see this being mentioned at Lumegan website. Thanks.
post #45 of 70
Yes, you can dial in any resolution you like:)
post #46 of 70
A couple of general comments.
I recommend calibrating with the Lumagen interal patterns first as this matches our frame buffer to the display.
I recommend DVD as the first source to calibrate since generally (as mentioned by someone else) it is the only source most users will have test patterns for. If the user has HD sources that they also have test patterns for, they would be even better as the first source calibrated.
The calibration per input is a feature, but not one that is forced on people. We see a lot of differences between displays and between sources - including DVI/HDMI sources. Still, generally the DVD sources are a good starting point for other sources. For example calibration of the DVD will all most always give a good approximation for color/hue and color/hue offsets for other sources. So, copying the DVD to other source memories is generally a good way to get them close. Of course if test patterns are available for the other sources they should be used.
We intend to have a 1:1 map of input to output levels. However, it's a minor point as calibration will correct any errors. We are a small company and I have choosen to spend our efforts on the best post-calibration image we can achieve. When we get time we will look at this level issue. It is most likely an offset in our software palette equations, as the math in the logic blocks is level preserving.
We strive for the best image quality possible, and the vast majority of our customers and dealers I have talked to say we improve the image quality over internal processing, and other video processors, including with the Ruby and including using HD sources. We will continue to work on improvements of course, and we do find feedback from our customers helpful in letting us know what areas to look at.
Cutomers with questions, issues and/or suggestions should email us at support@lumagen.com. We work hard to be responsive to questions and comments and try to respond quickly to them. On many occasions we have added a feature or worked on an issue after a single user's feedback, becuase we felt it would improve our product. We are working our tails off here and I think we have already succeeded in producing an exceptional product that continues to get better.
post #47 of 70
Jim,
That's a very even and diplomatic response. Thanks.
On the 10-bit software update, any realistic estimate of when that might be available (beta or otherwise)? I suspect it will resolve most of the video quality issues I have.
--Bill
post #48 of 70
Just to add. The original VISION is NOT capable of outputting 1024 x 768, 800x600. It has a fixed pixel clock. The amount of samples per line is set dependant on the vertical resolution and refresh rate.
Gordon
post #49 of 70
^^^ That's why it would seem to me that if you're going to go the SDI route from the get-go, it would make sense to buy your SDI-modified scaler and player from the same dealer... presumably they would test for that sort of thing before shipping. (Or at least you'd have only one company to look towards for problems like this.)
post #50 of 70
Gordon
Gordon,
So this is different from a HTPC where I can send 800 x 600 resolution to match my SVGA projector ? I though all scalers should be able to do this ???
I also have a NEC crt projector, the VISION should be able to send 1280 x 720 signal to the projector, right ?
post #51 of 70
The original Vision range of scalers from Lumagen worked as I posted. The current range do allow you to input any timings you wish. So yes. it is different from an HTPC. If you ask Jim he'll explain that for an analogue display chain he believes their method is actually beneficial and it's stll an option for how you can drive the outputs on the current models
Gordon
post #52 of 70
Hi... sorry to revive this thread but it seems to have a bearing on a problem I'm experiencing.
I have a VisionHDP scaler and Denon 2910 DVD player that both were modified by Lumagen for SDI (and that's how they're connected to each other), and what I am seeing is that every few minutes the entire picture will "neonize" or "solarize" and then everything will black out, and then the picture comes back a few seconds later. This happens over and over and over.
This is the second VisionHDP scaler in a row that I've had problems with--the first scaler would do the same thing after about two hours or so, but this unit starts freaking out almost as soon as you start watching a DVD. Then again, it could be the Denon 2910 SDI modification that is faulty. But one or the other (or both!) of these units are definitely broken.
Is Lumagen quality control really THIS bad? :mad:
post #53 of 70
Originally Posted by PencilGeek
I had Jim @ Lumagen (jrp) personally mod my Denon 3910 and test it before sending it back. I have the 3910 concurrently plugged in to the Lumagen via SDI and driving 1080p to my Brillian 6580iFB TV and the 3910 via 480i component to the Brillian Input-1 (dedicated 480i circuitry). The good news is the Brillian does a much better job on jaggies than the Lumagen -- it's a a flat 0 degree on HQV tests. However, even this input doesn't even come close to the picture quality and depth of colors I receive from the SDI->Lumagen(1080p)->Brillian combination. After the A/B comparison everybody I've shown never wants to switch away from SDI to watch DVDs. So it would appear that not all SDI mods are equal and/or the quality of work jrp did on mine is better than other people's mods.
I've never tried the DVI output of the 3910 into the Lumagen or to the TV for comparison because it can't output 480i -- and anything else wouldn't be apples-to-apples. If somebody has some suggestions for another way to test the 3910 vs. the SDI->Lumagen->TV path, I'll give it a try and post the results.
{Pencilgeek, can you send a 480p DVI from the Denon into the Lumagen and compare that with the 480p DVI directly into the Brillian?
post #54 of 70
Anyone? Anyone? Bueller? Anyone?
post #55 of 70
I have a SDI modded VisionPro HDP and a SDI modded Sony 777 changer (from JVBdigital), and I've never had a problem. ever. (knocking on wood)...
Have you contacted Lumagen? Maybe they will send you another DVD player to test.
post #56 of 70
It sounds like the SDI mod on the DVD player is the problem. Are you having problems with the other inputs?
post #57 of 70
I'll see what I can do; I just came down with some nasty head/lung thing -- hope it's not pneumonia...so I don't know when I'll be feeling up to it.
post #58 of 70
Scott,
My experience is that each release of firmware will fix some stuff.... and break some stuff. The latest firmware I'm not happy about - colors are way off at low IRE and I too have noticed the solarization (but only on one DVD title, never on broadcast). I might go back to the previous one.
post #59 of 70
^^^ I don't think this is necessarily a firmware problem since the intermittent solarization/neonization appears to stop happening after the player and scaler have been on for a couple of hours.
After the intermittent solarization/neonization started happening I unplugged the DVI connection between the scaler and the projector and plugged it directly into the Denon 2910's DVI output, and that's how we watched the first DVD movie. When the first movie was finished, I decided to give the SDI signal path another chance and plugged the DVI cable back into the scaler... and the intermittent solarization/neonization didn't occur once during the second half of our double-feature.
Believe me, when it works I'm very happy with the SDI modificaton that Lumagen did for my Denon 2910 and VisionHDP... the picture quality on the SDI signal path (sans solarization) is far, FAR superior to what I get when I feed the Denon 2910 directly into the projector. But since I only have one SDI source (the player) and one SDI processor (the scaler) I have no way of telling whether it's the SDI modification in the player or the scaler that is freaking out. My ISF technician (through whom I bought both of these units) is in communication with Lumagen; hopefully I will have a resolution to this problem before opening night next Saturday the 22nd.
post #60 of 70
does it look like this:?
  Back to Forum: Video Processors
This thread is locked
