I just received my TV yesterday and, like most other posters, I'm quite delighted with it.
Two things that earlier posters haven't quite spelled out are the exact configuration of the input jacks and the various wide screen modes so I thought I would describe them in some detail for others. Neither Niko's own site nor any of the vendors who carry the unit seem to provide much detail in this respect. Inexplicably, Niko's specification page doesn't even mention component inputs! Anyway here's the input configuration:
There are two separate audio outputs in addition to the AV3 input/output. Under the lower left of the bezel is the "secret" headphone jack mentioned earlier on the thread. This output is controlled by the volume and mute on the remote control and inserting headphones in this socket mutes the internal speakers. On the back is a line level output. With this in use, only the internal speakers are controlled by the volume control but the mute button affects both. This seems like a perfect combination.
There are four different video modes which merit some explanation.
Jstar41 asked about a humming noise when the TV is on, mine is completely silent so this is not something you have to put up with. I'd start by tracking down whether the hum goes away when you mute the sound then try disconnecting each audio input in turn to try to track down the problem.
- AV1: S-Video, Composite Video, L/R Audio, Component Video (Y,Pb/Cb,Pr/Cr), Separate L/R Audio for Component
- AV2: S-Video, Composite Video, L/R Audio, Component Video (Y,Pb/Cb,Pr/Cr), Separate L/R Audio for Component
- AV3: Composite Video, L/R Audio. Note: can be reconfigured as an AV output using the menus. There are no component or S-video inputs.
- AV4: S-Video, L/R Audio, Component Video (Y,Pb/Cb,Pr/Cr), Separate L/R Audio for Component. There is no composite input.
- DVI: HDCP capable
- VGA: Note: This appears to share a stereo audio input with DVI.
Coax: 75 Ohm, configurable for cable or over the air channels.
- 4:3 This shows a standard format picture in the central 75% of the screen with black bars on each side.
- 16:9 This stretches the picture sideways by 33% to fill the screen. The whole picture is distorted and people are fattened.
- Panoramic: As 16:9 except that only the edges of the picture are stretched to fill the screen. Faces is the middle are not distorted.
- Cinema/Letterbox: The top 12.5% and the bottom 12.5% of the picture are chopped off to give a 16:9 picture which is expanded to fill the screen. This is the mode to use for letterbox DVDs or widescreen PBS programs on analog cable.
