Last week, a few moments away from ordering a well regarded sub, I stumbled across steve nn's Dayton Titanic 15" MKIII kit thread which has steered me to the DIY route. After evaluating my needs aided with the driver modelling program WINISD Pro I have pencilled out a plan of attack and am soliciting a little feedback to enlighten me of any errors or omissions of material importance.
Objectives:
-Maximize value/minimize cost
-Minimize boom (target Qtc of .58) and other distortions (60/50 movies music (20 % of movies are concerts)
-Sealed sub
-Forgo HP filters and EQ if possible.
-Achieve the most natural bass at spirited SPL's, (current room is 3750 cubic feet will likely be adding doors to seal off 1500 cubic feet of that.
I've decided to build two subwoofers each with an finished internal volume of 6.5 cubic feet, each housing one Dayton Titanic 15" driver. I chose this design after being intrigued by steve nn's posts on the Dayton kit but recognizing that his kit apparently suffers primarily in two areas: 1/ FR drop off below 25hz and 2/ distortion at/below the same frequency.
More than doubling box size flattens the response, achieving a relative increase of about 3dB at 20Hz. Additionally, modelling driver excursion in this box size indicates a power amp of approx 200 watts into 4 ohms need be used to prevent over-excursion. While the driver still exceeds XMAS at about 10 Hz, further modelling indicates the natural roll-off below 20Hz of the amplifier I have in mind will maintain the drivers excursion at approx 73% of it Xmas between 5-10Hz, 80% at 20Hz and 60% at 30Hz.
Employing two subs approximately halves the driver excrusion required to produce single box SPL"s below 50 Hz and this is where I trust large gains in sound quality will be achieved over the kit.
So it appears running two 6.5 cu.ft subs powered with perhaps a Crown XLS-202b will have the same potential maximum SPL output as Daytons kit (which I'm confident will produce satisfactory SPL's in my room) while offering 3dB better response at 20 hz, all this with half the cone excrusion helping to keep things cleaner sounding and with a cost only slighty above the price of one $688 kit. I should note my room adds gain all the down to 10 Hz so am confident the Dayton driver (even with the small box relatively steep roll-off) will work well in this configuration.
Now, I understand these drivers won't elicit ooohs and aaahs from the masses but the price is right and by all indications will suit my needs well. That's the plan, if need be I will add a HP filter or FBD but would rather avoid this if possible but obviously will take some time to make the final determination.
If anyone can identify any glaring issues with this plan I'd appreciate the feedback.
Objectives:
-Sealed sub
