Hey guys,
I am in the process of building a 2cu sealed cube enclosure first DIY project. The MDF is sitting downstairs in the living room and cut to proper dimensions. Some guy at the local lumber store suggested "Polyurethane Premium Construction Adhesive" for glueing my 3/4" mdf together. Is this ok or should i return it for some elmer's wood glue? Also, do i need to purchase a sealent like silicon filling to make sure things are airtight if i do end up using the polyurethane adhesive?
And about bracing...is bracing a 2cu enclosure THAT important? So far, this is my plan. I have two peice of MDF cut to 17"x17" for the top and bottom. The side pieces are cut to 15.5"x17" to join the top and bottom pieces. I have two more peices cut to 15.5"x15.5" for the front and back. The driver and amp will be installed into the smaller 15.5" squares. How do i go about bracing this box without using too much internal volume? I have a lot of unused MDF, so I want to make some use of it.
Here is all the wood i have available for the enclosure:
a total of 4 peices cut to 17"x17", 2 peices 15.5"x17", and two peices 15.5"x15.5".
