AVS › AVS Forum › Display Devices › Screens › EluneVision screens
EluneVision screens - Page 42
post #1231 of 1236
Originally Posted by DTI View Post
own the 100 Reference Studio 4K Tab-tensioned mine is noisy too if you look on
top of the canister you will see two mounting tabs that can slide side to side if you tape those
down it can dampen some of the sound that's if your not using them as mounts
thanks, will look into that.
post #1232 of 1236
Just noticed on their website it states "whisper-quiet motor operation" not sure how thats measured, but I'll have to take a drive to their show room to verify if theirs are "whisper-quiet", I might just have a defective motor!
post #1233 of 1236
Originally Posted by Angus.Young View Post
I'm working on getting a projector setup in the basement.. and have some questions about screens....
Specifically looking at Elunevision screens... how good/bad are the Elara screens compared to the Reference screens.. would be looking at 100-120 inch.. yet to be determined exactly..
I guess he question is almost 4x or 5x the price for the reference worth it... is the Elara that bad per say? It is an old projector.. a JVC RS1X source material will be from my Blu Ray/DVD collection and a HTPC...
Thank You!..
I owned an Elara II Grey, and now a 4k reference. If I could have seen the 4k way back when I was entertaining the idea of the Elara I would never have bought the Elara.
Hands down, my image is way way better off on the Reference. Dig deep, sell your wedding band, break the piggie bank, find a way and get the reference.
(Okay, don't sell your wedding band. But make it happen)
No regrets here other than I bought an unnecessary screen in the beginning. Love my reference 4k.
post #1234 of 1236
I don't own the screen, but I thought there is a tightening screw that you can tight down the slide?
post #1235 of 1236
Thanks for the advice.. I will probably go with the Reference then.. I think I will go with the 100"... I could go a bit bigger.. but I think this should work well as it leaves me some adjustment room...
post #1236 of 1236
I was looking at EluneVision for my basement. I am working on the remodel now and doing framing and insulation. At a stopping point regarding the screen because I can't decide between building a finished box up in between two joists and going with the ceiling/wall mount EluneVision (the 4K model) or taking some measurements of my spacing (exact joist locations, etc) and plan for the in-ceiling version of the same screen. The primary issue is that I don't have a ton of space between the joists because of some conduit and HVAC issues. I can probably get a 5.5" x 6" rectangle in-between the joists (inside finished space, drywall or real thin plywood finished like the rest of the ceiling w/ texture and paint).
Can anyone with the 4K model look and get some measurements of the total HxW needed to comfortably fit the on-wall version into a space? Elune says that the housing is 4 inches by 4 inches, but I can't tell how big the two mounting pieces are. Also, it 'appears' that the screen has power and control coming off the right (so stage left)? presumably the motor, height set controls and the motor control is loaded on one side?
Regarding the in-ceiling version, it's a bit more money (and a bit bigger all together) and oddly, I think it might look more commercial than just having a finished, inverted soffit between the joists. Also, with the inverted 'box' I can paint the ceiling and have it all match where the in-ceiling looks like it might be a bear to paint the plastic trim (not sure I would even try).
Any thoughts on any of this?
  Back to Forum: Screens
