Originally Posted by
Scott Gammans
It looks like the AVR-2807 is HDMI 1.2,
2807 is HDMI 1.1, and doesn't have DTS-HD nor Dolby True HD decoder/decopressor, I doubt It will ever accept them (as bitstream). On another hand, Advance mode authoring prevent direct Bitstream out, and so player decompress them and send PCM over HDMI, so not an issue.
Scott Gammans
Awhile back in this thread someone asked if
7.1 channels of PCM over HDMI worked. Was this ever confirmed?
Yes, it did works, tested using PS3, no problem.
Scott Gammans
I want to run the AVR-2807 strictly as a preamp. I'm pretty sure that the AVR-2807 can be configured to send the 0.1 subwoofer output without any internal amplification, but can this unit be set up to completely bypass its internal amplification and send the remaining 7.0 channel outputs to my amplifier via the pre-outs?
Yes, no problem here again, 7.1 pre-out are there.
Scott Gammans
I already have a video processor and do not want the AVR-2807 to do any video processing on the video signal coming into the HDMI inputs. Can the AVR-2807 be set to bypass video processing?[/list]Thanks!
Yes, you can by-pass any processing, especially as there is none
(on 720p / 1080i/p signal).
BTW, I love my 2807
--Patrice
